1st gen elocker diff into 2nd gen elocker axle housing?
Discussion in 'Technical Chat' started by TireFire, Apr 18, 2017.
  1. Apr 18, 2017 at 7:13 PM
    TireFire
    TireFire [OP] Superunknown Member
    Olympic Peninsula
  2. Apr 19, 2017 at 1:43 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I don't believe the drive shaft patterns are the same. I suggest you call up East Coast Gear Supply and ask, they are very knowledgeable on the subject. I had to get a double drilled flange for my 99 and I believe that the other bolt patter is for the 2nd gen 3rd. They told me that the stock 29 spline flanges for my year bolt pattern are rare but do exist.
    Brie and TireFire[OP] like this.
  3. Apr 19, 2017 at 1:57 PM
    TireFire
    Olympic Peninsula
    Yeah I spoke to Chase at ECGS and it fits. Only need the flange if the diff is 2002 or older. 2003 & 2004 will boot right up to the 2nd gen drive shaft. Mistery solved.
  4. Oct 3, 2017 at 11:03 AM
    im4u2nvss
    im4u2nvss Well-Known Member
    Jesse
    2012 DC
    Are the wiring plugs the same also?
  5. Oct 3, 2017 at 11:14 AM
    TireFire
    Olympic Peninsula
  6. Jul 18, 2022 at 7:10 PM
    BrownTaco12
    BrownTaco12 Well-Known Member
    Tyler
    Mendenhall, MS
    2012 Tacoma, TRD Off-Road
    OME 884, Bilstein 5100, Generalspringskc HD leaf springs
    Did this project turn out okay for you? Were you able to bolt the 1st gen elocker 3rd right into the 2nd gen axle and have it all work out fine?
  7. Jul 18, 2022 at 11:39 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    the Elocker part of the housing hasn’t changed since they’ve been introduced with the exception of the 2016* tacos.
  8. Jul 18, 2022 at 11:49 PM
    BrownTaco12
    Tyler
    Mendenhall, MS
    I guess, more or less what I’m asking is:
    I have a 2012 DCSB TRD OR. I realize the rear 3rd member is 8” w/ elocker, but I’ve been trying to find out specifically which models, years, etc. would basically direct plug and play into my rear axle housing. So far (from this thread) I’ve learned that the 03-04 TRD OR Tacoma 3rd member will plug and play, but I’m trying to just learn which all would be able to do so. I plan on only trying to use 4.10 gear ratio just because I have 285/75r17 and drive from Indiana to Mississippi and back every few weeks from school to home. Ive researched the past couple of weeks on this topic and most threads are of non TRD OR trucks, and the ones that are TRD OR, the thread was never updated with results. (Forgive me if I misspoke on any information, Literally all I know about this topic is the little I’ve read the past few weeks.) But any help or direction is much appreciated.
    6 gearT444E[QUOTED] likes this.
  9. Jul 19, 2022 at 2:18 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    they should all be plug and play. The only difference is the drive shaft bolt pattern which was mentioned above. That can easily be overcome by drilling the flange to match the new pattern. The motors for the elocker and the diff lock indicator switch from first gen taco all the way to the end of the 2nd gen years are all the same connectors.
  10. Jul 19, 2022 at 9:10 AM
    TimberTiger
    TimberTiger Get Western! ... ig @tcave87
    Tanner
    Arlington, Wa
    2014 DCSB Trd off road , 2002 Ext Cab Trd
    2014 DCSB: nitro 4.30 gears, Eaton/Harrop front locker, Bilstein 6112's w/ 650#, Camburg ball joint UCA's, Marlin cam tab gussets, Wheelers superbumps, Deaver U402 stage 2 leaves, bilstein b110's, u bolt flip, Archive hammer hangers, ADV weld co hybrid sliders, ADV weld co bed rack or Leer 180 w/ windoors, full RCI skids, SCS stealth 6, 35x10.5 kenda RT, ATH fab HC rear bumper, US offroad stealth front winch bumper, Smittybuilt x20 10k winch, ARB simpson III rtt, plenty of dents and scratches Now Sold 2002 TRD ext cab: 06 TRD Tundra coils, tundra 5100s, wheelers HD 3 leaf AAL, rear 5100s, ARB front bumper, SkidRow front skid, Leer commercial cap with windoors, 285/75r16 Kelly Safari TSR
    I have a 98 4runner 4.30 Elocker in my 14, plug and play besides changing the pinion flange.
