1st Gen Genuine OEM Carrier Bearing for $79
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Dec 19, 2018.
  1. Jun 27, 2019 at 10:12 AM
    #101
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    All I know is nine says Toyota, and the box said made in Japan. So a Koyo or NSK bearing, which are both great. The housing is whats most likely made by spicer.
    ThunderOne[QUOTED] likes this.
  2. Jun 27, 2019 at 10:29 AM
    #102
    eon_blue
    Azusa, CA
    Picking mine up from the local Amazon locker tonight, I'll let you guys know what it looks like. If it's not stamped Toyota I'm sending it back
    ThunderOne likes this.
  3. Jun 27, 2019 at 10:30 AM
    #103
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Yep, the only way this debate can be proved is for someone to look inside a recent "new in box" Toyota service replacement and see the manufacturer of the bearing. Still, not going to be 100% proof.
    Just because a part says Toyota on it means nothing. In fact Toyota suppliers such as Aisin and Denso go out of their way to not say Toyota on their aftermarket replacements. For example, an Aisin water pump purchased in the aftermarket will have the Toyota name (cast on the housing) ground off. A Denso MAF has a blank cover plate where the Toyota sold part says "Toyota". They are likely the same parts but Toyota does not want the after market selling Toyota branded parts at cut rate prices.
    Now, with Spicer increasingly supplying Toyota OE, are they now supplying 1st gen service replacements? Did they start it later in 1st gen production? Both are entirely plausible. Only way to tell would be to pull a recent "Toyota sold" one apart.
    I'm not saying the Spicer is good or bad. I would likely choose the Spicer for my next one and suggest it to clients.
    Folks have had "mostly" good results with both Spicer and Timken replacements at good prices since before this forum was created, really old news.
    This is an OE bearing (99).
    Finally, it is obvious that the Spicer bearing is mounted in the rubber differently than the OE. The FSM says to align the "line" created by the sheet metal bearing cups (for lack of an official term) to a specific position/range. Is this "line" present on the Spicer?
  4. Jun 27, 2019 at 10:33 AM
    #104
    eon_blue
    Azusa, CA
    I'm only going by the "Toyota" stamp in this case because everyone in this thread that's had a positive experience with this bearing has one with that stamp. The ones that haven't had a good experience ordered the same bearing from a different supplier and got one without the stamp. But I do agree in general I wouldn't go by that alone on everything.
    In fact on most everything else I just buy OEM, either from my local dealer or a cheaper online source.
    There wasn't any real doubt about this bearing in this thread until a couple days ago, of course right after I bought it lol. If I had read this stuff beforehand I probably would have just gotten the OEM one and bit the bullet on the price. But we'll what the Spicer one looks like when it arrives tonight.
  5. Jun 27, 2019 at 10:51 AM
    #105
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    You're going to be just fine. Its not a balljoint that's going to catapult you into a ditch when it fails.
    eon_blue[QUOTED] likes this.
  6. Jun 27, 2019 at 10:56 AM
    #106
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    yours meaning one you got from Toyota.. or..?
  7. Jun 27, 2019 at 10:58 AM
    #107
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Seems like Koyo bearings are on all sorts of things on these trucks. Excellent post as usual!
  8. Jun 27, 2019 at 11:01 AM
    #108
    tony2018
    tony2018 Well-Known Member
    OH wow, didn't know those were rebuildable.
  9. Jun 27, 2019 at 11:02 AM
    #109
    OneWheelPeel
    Phoenix, AZ
    They make good Bearings
  10. Jun 27, 2019 at 11:03 AM
    #110
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Toyota bearing in a spicer box. The Toyota PN on the bearing is for a T100 or Land Cruiser, but it fit fine on my tacoma. Even says made in Japan right on the box.
  11. Jun 27, 2019 at 11:07 AM
    #111
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Any Koyo, NSK, SKF, FAG, timken, rbi, etc bearing will be good to go. Its the rubber that fails on these carrier bearings not the bearing itself. Like I said earlier its very likely that the bearing inside the spicer one is made by one of those manufacturers, as there are only several manufacturers of quality ball bearings out there. Spicer is likely only making the rubber housing on these.
    OneWheelPeel[QUOTED] likes this.
  12. Jun 27, 2019 at 11:15 AM
    #112
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    gee whiz that sure does make a $200 price tag for a carrier bearing sound steep now
    Blue92[QUOTED] likes this.
  13. Jun 27, 2019 at 12:30 PM
    #113
    Dirty Pool
    99 XCAB V6 MT TRD
    Toyota is definitely proud of their stuff, and getting prouder every day. These things were outrageously priced when they were $116.
    Then there is the Denso AC compressor for $180 vs $313 for one in a Toyota box, or the Denso fuel pump for under $100 vs $337, MAF's, FPR's, O2 sensors and so on.
    I suppose the bearing could be replaced as they do fail but I would only classify the whole thing as "take apartable", like a fan support bracket.
    Or a fuel pump.
    Or daddy's electric drill.:oops:
  14. Jun 27, 2019 at 5:27 PM
    #114
    eon_blue
    Azusa, CA
    From Amazon and says Toyota on it
    cruiserguy and Blue92 like this.
  15. Jun 27, 2019 at 5:32 PM
    #115
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Lmaooooo :rofl:
  16. Jun 27, 2019 at 5:32 PM
    #116
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Run it. I doubt you'll have any issues.
  17. Jun 27, 2019 at 5:34 PM
    #117
    cruiserguy
    Elijah
    SEKS
    I'll bet you have a good experience with this one. Thank goodness we found out about looking for the parts direct from the manufacturers, I couldn't stomach OEM parts prices. Whoever first did any searches in general and figured out we had options, a huge thank you
  18. Jun 28, 2019 at 9:06 AM
    #118
    1Fine40
    1Fine40 Well-Known Member
    Rich
    Great Northwest
    04' Ex.Cab TRD
    Grey wire, deck plate, 2-Lo, Toytec front, All-Pro rear, 4.88's (Hi rpms!)
    From Post #103 above:
    "Finally, it is obvious that the Spicer bearing is mounted in the rubber differently than the OE. The FSM says to align the "line" created by the sheet metal bearing cups (for lack of an official term) to a specific position/range. Is this "line" present on the Spicer?"
    It was on mine. A side by side comparison with the OE unit proved that they appeared to identical in every way, so I installed it...I'm only at 11K + miles right now, but it is totally quiet and smooth. The real reason I replaced the OE one was that the rubber was rotted! The bearing part was still good as far as I could tell...as usual, YMMV:cool:
    cruiserguy likes this.
  19. Jun 28, 2019 at 7:53 PM
    #119
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Yeah, I you look at my post #54, you'll see the parts are carbon copies, the Spicer and the OEM i took off.
  20. Jul 14, 2019 at 3:01 PM
    #120
    TacosConQueso
    TacosConQueso Well-Known Member
    Brian
    1999 Sierra Beige Tacoma 4x4
    Saw the price dropped to $71 so I pulled the trigger. Thanks for putting this together OP!
