1st gen going all synthetic
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bs 02 Taco, Sep 2, 2008.
  1. Sep 2, 2008 at 12:16 PM
    Bs 02 Taco
    Bs 02 Taco [OP] Well-Known Member
    Amelia, Ohio
    02 Tacoma 4x4 regular cab 5 speed
    Swiss cap Deckplate Stupid door chime Synthetics AFE pro dry JVC Ipod compatible head unit Vanilla air freshener :) 25%tint
    I have an 02 regular cab 2.7 liter and I am wanting to change ALL of my flids to synthetic...
    What all can I change, and what products (names and product numbers) should I use?
    Also changing plugs and wires, any thoughts?
  2. Sep 2, 2008 at 12:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    change the motor oil, transfer case, both diffs....and if you really want to, you can go as far as changing the brake fluid and power steering fluid over to syn. too. mobil1 and royal purple are good and you can get them locally......amsoil is good too, along with redline.
    spark plugs and wires.....stick with denso or ngk plugs.
    just remember....transmission fluid may be the type t-iv....only from toyota. you'll need to stick with this if this is what your tranny calls for.
  3. Sep 2, 2008 at 12:30 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    ^^^^ Dont forget the blinker fluid too.....
    Sorry... dont want to derail the thread hehe
  4. Sep 2, 2008 at 12:58 PM
    Bs 02 Taco
    Amelia, Ohio
    How did I know this was coming :D
  5. Sep 2, 2008 at 12:59 PM
    Bs 02 Taco
    Amelia, Ohio
    Thanks Taco, means a lot...
    Got to take care of my baby :rolleyes:
    You have any idea on a ballaprk price for all excluding the labor?
  6. Sep 2, 2008 at 1:06 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2002 Tacoma Xcab
    i think i ended up spending close to $200 when we did my truck
  7. Sep 3, 2008 at 10:24 AM
    Bs 02 Taco
    Amelia, Ohio
    Thanks a lot
    Do you remember how much of each application you used?
    Oh and what products did you use?
  8. Sep 3, 2008 at 11:41 AM
    JimBeam
    JB
    2002 Tacoma Xcab
    ask tacomaman...
    i do know my gear oil and my engine oil is mobil 1 but i couldnt tell you the weights
    my tranny fluid is the type t-iv
    bought the dealership spark plugs...
    and we used seafoam deep creep to clean the throttle body
  9. Sep 3, 2008 at 12:40 PM
    Bs 02 Taco
    Amelia, Ohio
    Hey man, do you remember what type of fluids you used and how much you used of each?
  10. Sep 3, 2008 at 1:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    for the engine oil.......5.5 quarts with the 3.4 v6.....and we used mobil1 5w30, for the diffs and transfer case....mobil1 75w90, rear diff was about 3 quarts, front diff was a little over 1 quart, and the transfer case was a little over 1 quart....get 6 quarts to be sure you have plenty, then you'll have some left over if needed. on the transmission fluid.....toyota type t-iv, and it was about 4 to 5 quarts....just depends on how much drains out. buy about 6 quarts to be on the safe side(you can come out cheaper buying a case of the toyota tranny fluid...just a heads up).
    anything else i can answer...just ask.:)
  11. Sep 3, 2008 at 4:09 PM
    emglishe30
    emglishe30 Well-Known Member
    NJ
    2010 SR5 Base 4x4 DCSB
    Pioneer Touch Screen, Sub, Diode Dynamics SS3 Sport amber fogs, Oem skid plate, led accent lights, led 3rd brake, 2011 color matched honeycomb grill. Plasti dipped pieces.
    sorry to jack this thread, I have a 01 2.4 cyl 4x2 and was wondering what fluids I could change and how much of each will be required other than the Oil..Thanks
