1st gen Head Unit suggestions/install help
Discussion in 'Audio & Video' started by pyroskier, Oct 29, 2011.
  1. Oct 29, 2011 at 9:08 PM
    pyroskier
    pyroskier [OP] Well-Known Member
    Jacob
    Laramie, WY
    2004 Ext Cab TRD 3.4
    Hey all,
    Interested in buying a head unit for my taco. Any recommendations for a decently priced head unit (less than $75)? I'm no audiophile, but I want something better than stock that I can plug in AUX instead of using a cassette adapter. Also, are there any threads that have detailed install instructions for 1st gen? Thanks! Oh, and I would like it all to be from Amazon.com since I have about $130 in gift cards there.
    I have been looking at head units, and found these that have great reviews:
    http://www.amazon.com/gp/product/B004EG0LS2/ref=ox_sc_act_title_1?ie=UTF8&m=A1WRTEG7T8P2CK
    http://www.amazon.com/Kenwood-KDC24...ef=sr_1_1?s=car&ie=UTF8&qid=1326305981&sr=1-1
    http://www.amazon.com/Pioneer-DEH-1...ef=sr_1_7?s=car&ie=UTF8&qid=1326305981&sr=1-7
    I want something around those price ranges, so if you have any other suggestions, that would be great.
    I want to also change the front and rear speakers, I don't quite have the money for subs and amp (will do later down the road)
    I don't really know what to look for in speakers, all I know (I think) is that they are 6x8", correct me if I'm wrong.)
    These have pretty good reviews, but it says they don't fit my truck? :notsure:
    http://www.amazon.com/Pyle-PL683BL-...004&vehicleType=automotive&newCar=1&carId=001
    I don't know anything really about them, I saw that there are component, coax, 2-way and 3-way and many other kinds. I'm not looking for top-of-the-line, I just want ones that sound better than stock, and have more bass than stock so I don't have to buy subs. If you can recommend some, that would be awesome. I'd like for the whole setup (head unit + speakers) to be under $150. I know it's low, but I'm no audiophile, and I'm on a budget.
  2. Oct 29, 2011 at 9:10 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I have a pioneer premier that I need to get rid of. Model DEH-660. Its an older radio but they have really good sound quality and control. 6 channel output. I had a harness as well, but donno if I brought it with me in the move.
    I'll do 65 shipped if you want.
    EDIT oh btw, I do have the aux input plug for it too.... I loved the radio, just didn't have bluetooth, without spending an arm and a leg.
  3. Oct 29, 2011 at 9:12 PM
    brian
    Elizabeth City, NC
    I also have an alpine Type S 10" DVC sub and JL JX 250/1 amplifier (only used for a few weeks) to get rid of if you are interested. 250 shipped package deal for all....
  4. Jan 11, 2012 at 10:26 AM
    pyroskier
    Jacob
    Laramie, WY
    Bumping for help
  5. Jan 11, 2012 at 10:51 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Do you have an ipod? If so i highly recommend getting a unit with a USB port and ipod control. Lets you charge your Ipod and control it from the head unit. Or just charge and control it via ipod all while playing music.
    I HIGHLY recommend Pioneer stuff man. I like them a lot, very well built units where the buttons aren't cheap and pop off. Good sound quality as well. WAY WAY better then the Kenwood you posted.
    as for speakers, just get 2 way or 3 way. Once you add a sub you'll add a HPF to them and they will only play highs/mids anyways. anything more then just a woofer mid ranger driver and tweeter is a marketing scam. 4 and 5 way speakers are pointless.
    im not totally sure what size of speaker your truck takes :notsure: Sorry i can't help there...mine help 5 1/4s all the way around..so idk..
    Those Pyles are pretty cheap..but they will be better then stock..i don't really like Pyle stuff but whatever man haha The biggest part that will make the biggest difference is getting a 4 way amp to amp the speakers from the head unit. The head unit will only put out 20-24w RMS at most per channel. Your speakers are 180w RMS..so your way under powered. You will want to amp them when you get a sub anyways to get the most out of the system and to balance well with a sub. But if you can't get one now, it'll be fine. But an amp will make the speakers sound much better.
    I reommend checking out Sony, Infinity, Alpine speakers. I have a pair of Kickers that a awesome as well and i highly recommend all the above companies as i have seen and heard them all in person.
    Also check out sonicelectronix.com. Much better place with better info and review...and maybe prices too.
  6. Jan 11, 2012 at 10:52 AM
    Rhino
    Rhino Well-Known Member
    Laurel, Mississippi
    03 TRD SR5 4x4
    gray wire mod, blacked out, debadged, toolbox foglights, cb in dash, system, bilstein 5100's in front wrapped in eibach coils, 5125's in the rear with 2 inch aal and 1 inch shackle, diff drop kit, extended rear brake line, 8000 lb smittybuilt winch on a custom winch bumper, 2 4 inch 100 watt kc's and 2 6 inch 100 watt kc's on the bumper, sometimes a ladder rack,much more to come
    i didnt find any detailed thread when i installed mine but all you do is remove the climate control knobs, pop that plate off with a flat head screwdriver, remove the screws holding the dash in up there, go down to the ash tray, remove it, there is another screw behind it holding the dash in, remove this screw as well then go to the very top of the dash and begin popping it off, after this you should be able to see the screws holding in the stock head unit, remove them and take the brackets off the radio, then attach the brackets to the side of your dash kit and aftermarket radio and it should be a perfect bolt back on
    and im not sure about the stock sizes either but i put 6.5s in my door and they screwed into the stock holes even though they werent the same size, my backseat i put in 6x9s which were WAY bigger than stock so i had to build a custom place to mount them, so im thinkin its gonna be more like 5x7 for your stock size
  7. Jan 11, 2012 at 11:00 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh and you want to buy in advance for preamp outputs. Will make your life WAY easier when you get amps.
  8. Jan 11, 2012 at 12:14 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    I'd get the Kenwood out of the one's you posted. I'd recommend something like a Kenwood KDCX395 the reason why is because it has dedicated 4v subwoofer pre-amp outputs, I have this HU and have had it for 4 years and still love it. For speakers stock size is 6x9 but I bought some and had to cut the back of the basket out to make it fit as the stock speakers are a lot shallower than an aftermarket speaker. If you buy a speaker from crutchfield.com they will send you the mounting material needed to mount any speaker you want. If you plan on running the speakers off of Head unit power then try to find something that has a high sensitivity. I'd stay away from Pyle audio I've heard some of their stuff and you get what you pay for. I have kicker DS60's in my doors and they are great they can keep up with my subs without a problem off of hu power because they are 90db sensitivity.
  9. Jan 20, 2012 at 8:28 AM
    pyroskier
    Jacob
    Laramie, WY
  10. Jan 20, 2012 at 8:53 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i dont know why you ordered that stuff. when i put the deck in my last truck the brackets for the stock deck fit right on the new deck and bolted back in the same spot. I guess if you want a harness go for it but i just cut the wires from the factory harness and connected them to the wires out of the after market deck.
  11. Jan 20, 2012 at 9:39 AM
    pyroskier
    Jacob
    Laramie, WY
    Why did I order a dash kit? Because there will be a huge gaping hole in the console without it... the factory stereo is a double din, and I ordered a single din... And the wiring harness was cheap, and it's a good backup in case I mess something up.
  12. Jan 21, 2012 at 8:59 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    That's exactly what most of us do, OP. I installed very similar (if not identical) components with my aftermarket HU, and I'm very happy with the result. :thumbsup:
