1st gen leaf spring options
Discussion in '5 Lug' started by 00black5lug, Nov 5, 2017.
  1. Nov 5, 2017 at 7:37 PM
    00black5lug
    00black5lug [OP] DCSSM18
    Dalton
    2018 DC Sr5
    Need to replace my leafs as they are 17 years old. Heard that 01-04 5 lugs sat higher and am wondering if I could put an stock replacement for those years on my 2000. Looking for a little more lift on the rear.
  2. Nov 8, 2017 at 9:17 AM
    00black5lug
    Dalton
    2018 DC Sr5
    Bump bump bump. Anyone?
  3. Nov 8, 2017 at 3:32 PM
    TacoBunny
    TacoBunny Well-Known Member
    AZ
    1997 5 Lug 5VZ
    ive got a stock 97 pack with a 3" aal for a 6 lug. it added about an 1 1/2" of lift and its still nice and plush. It'll be on sale pretty soon, im getting a custom leaf pack being made by springworks.
    You could always get an aal or shackles.:notsure: Some people even do blocks but i wouldn't recommend that.
    00black5lug[OP] likes this.
  4. Nov 19, 2017 at 7:48 PM
    00black5lug
    Dalton
    2018 DC Sr5
    Awesome thanks man. I just wonder if 01-04 leafs for the 5 lugs are taller than pre 01 5 lugs
  5. Nov 19, 2017 at 8:09 PM
    TacoBunny
    AZ
    1997 5 Lug 5VZ
    I wanna say yes, the later first gens have more ground clearance
  6. Nov 19, 2017 at 8:27 PM
    00black5lug
    Dalton
    2018 DC Sr5
    Sweet thanks!!!
  7. Nov 20, 2017 at 3:06 AM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    I've been thinking about putting prerunner springs on mine.
  8. Nov 20, 2017 at 3:18 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Don't quote me...but I thought 5 lugs were spring under and prerunner and 4x4 were spring over.
  9. Nov 20, 2017 at 3:26 AM
    BikerinBlak909
    SoCal
    96 LT 5 lug
    Doesn't mean you can't mount them under the axle
  10. Nov 20, 2017 at 9:42 AM
    TacoBunny
    AZ
    1997 5 Lug 5VZ
    You can but if you use 6 lug springs you'll only lower the truck. I put a 3" lift 6 lug aal and got just under 1" of lift from it
  11. Jan 3, 2018 at 9:24 AM
    Ghilliegreen215
    Ghilliegreen215 Tanto Leash
    Bedminster
    2001 Tacoma Trd
    Generic cold air intake, procomp 51 Series 16 x 8 4.25 Backspacing dee cutz, dorman 610-463 (Longer wheel studs To accommodate the1/4”spacer need to clear Caliper), Rancho quick lift loaded(Temporarily till proper coil over set found, LED head light up grade, BAMFA LCA skid plates, Optima marine grade battery, Universal billet battery holder,AND MUCH MORE TO COME
    Does anyone know how much lift over stock you will really get from the deaver j59 leaf pack it says 1.5 but I heard people complain about more then 3 inch’s. I just got some shity rancho quick lift coil overs up front will that be to much lift for the reer? looking to get new beefier than stock leaf springs with out a huge lift. How did you make out with with those 5 lugs leafs?
  12. Jan 3, 2018 at 5:39 PM
    BikerinBlak909
    SoCal
    96 LT 5 lug
    I put a 3" aal on my flat 5 lug leafs n it gave my truck the stink bug look. That was before I did anything to the front.
