  1. Feb 10, 2020 at 10:48 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    cruiserguy and Kwikvette[QUOTED] like this.
  2. Feb 10, 2020 at 10:48 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I have an 8ft bed tundra.
    Sperrunner[QUOTED] likes this.
  3. Feb 10, 2020 at 10:53 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  4. Feb 10, 2020 at 10:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    cruiserguy likes this.
  5. Feb 10, 2020 at 10:57 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    10.8 for 80 series on stock baby tires, with a bonus of 34 degree side angle before tipping over
  6. Feb 10, 2020 at 10:58 PM
    Empty_Lord
    Dan
    Noice.
    I’m actually impressed with the tundra angles and shit
    04Pre_Runner likes this.
  7. Feb 10, 2020 at 10:59 PM
    Speedytech7
    Most folks don't usually wheel anything with an 8-foot bed because of the breakover angle being kind of rough
  8. Feb 10, 2020 at 11:03 PM
    Empty_Lord
    Dan
    22.9 degrees.... or 24. Depends on what model. The double cab is 22.9. 24 on reg and access cab.
    Meh. I don’t plan on wheeling hard in it. But it can do it.
  9. Feb 10, 2020 at 11:11 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Watching a timing belt guide for the 2UZ-FE. So my to do list is quite long now. I'll be very busy this summer :bananadead:
    Right now the Tundra is having it's passenger airbag replaced under recall. @Empty_Lord Apparently humidity is a major factor and my truck lived it's entire life in New Orleans.
    • Valve cover/Cam Plugs/Half moons/clean throttle body/new injectors - 04 Taco
    • Replace transfer case with a newly sealed low mile one - 04 Taco
    • Paint and install <100K stock 4WD rear driveshaft - 04 Taco (removing the crappy shortened one)
    • Brake job - Elderly neighbor's 07 Rav4
    • Timing belt - 03 Tundra
    • valve cover seals and spark plugs - 03 Tundra (this one is easier than I originally thought)
    • Body mounts - 99 Taco
    • Weld front bumper - 99 Taco
    • Weld rear bumper - 04 Taco
  10. Feb 10, 2020 at 11:13 PM
    Empty_Lord
    Dan
    Tundra valve covers are easy. your lucky on the cam seals. Non vvti can be done easily. The vvti motor like mine, I had to pull the cams and disassemble to do the seals.
    04Pre_Runner[QUOTED] likes this.
  11. Feb 10, 2020 at 11:14 PM
    Empty_Lord
    Dan
    Hmm. Apparently the tundras stock approache angle since I have the steel front bumper is 29 degrees. 24 departure. 24 break over... it’s not that bad really now is it.
  12. Feb 10, 2020 at 11:15 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    My wheel barrow has better angles
  13. Feb 10, 2020 at 11:16 PM
    Empty_Lord
    Dan
    I’d hope so.
    Kwikvette likes this.
  14. Feb 10, 2020 at 11:59 PM
    Empty_Lord
    Dan
    looking like brute force fab is going to be the sliders i'll rock... theyre the cheapest for something that appears to be quality
    xtremewlr likes this.
  15. Feb 11, 2020 at 12:32 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Just ordered one of those fly by wire throttle pedal modifier gadgets for the 4runner. Hopefully it does as stated and eliminates the lagy throttle.
    Also waiting on a response from an ebay seller about the plastic intake, fuel rails and throttle body. Said he had the fuel rails and intake from a 2006 4runner but not the TB. Same seller has a 2005 Tundra so I asked if he had the TB from that still. If not, I know which one I need at least. Then I just need to order the 12 hole injectors from Dirty Deeds. Oh, I need to get a set of valve covers too. Clean and paint them before swapping when I do the timing belt and intake stuff.
  16. Feb 11, 2020 at 12:33 AM
    Empty_Lord
    Dan
    The pedal commander? I’ve heard good things
  17. Feb 11, 2020 at 12:33 AM
    Empty_Lord
    Dan
    Clean and paint.
    Or be like me and powder coat em.
    It was 100 bucks and came out beautiful
  18. Feb 11, 2020 at 12:34 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
  19. Feb 11, 2020 at 12:34 AM
    Empty_Lord
    Dan
  20. Feb 11, 2020 at 12:35 AM
    Empty_Lord
    Dan
    I was just out in the garage figuring out how I’m going to carpet the cap. And I’m thinking about making some aluminum trays to make use of the wasted space where the topper is on the bed.. nice ledge, bend some aluminum to use it to older tie downs and small stuff and keep it off the bed
    Area51Runner and xtremewlr like this.
