  1. Feb 12, 2020 at 9:22 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  2. Feb 12, 2020 at 9:23 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
  3. Feb 12, 2020 at 9:23 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    ya no fucking shit its not
    thought people were more friendly to step in and help out is all
    the 'goodwill' of people you know what i mean
    i would bend over backwards (within reason) for someone that needed assistance that i was able to provide
    in which i most recently did for someone
    Kwikvette[QUOTED] likes this.
  4. Feb 12, 2020 at 9:25 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    so now i must figure out what savings i will need to withdraw and get my stupid truck fixed properly
    it could be 4 or 5 thousand dollars at first estimate, depending on what i do exactly
  5. Feb 12, 2020 at 9:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm pretty sure that's just at the individual level, not specifically a 2nd/3rd gen thing.
  6. Feb 12, 2020 at 9:26 PM
    Empty_Lord
    Dan
    the hell is 4-5k to fix?
  7. Feb 12, 2020 at 9:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You need no fixing of your truck.
    Unless you're due for a timing belt and water pump, which in total seems to average about 600-700 with parts and labor, you're good to go.
  8. Feb 12, 2020 at 9:28 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    idk
    no comment on this either
  9. Feb 12, 2020 at 9:33 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    So, is that new 2014 Tundra engine getting installed on it?
  10. Feb 12, 2020 at 9:35 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    idk anymore, it just seems a 2nd/3rd gen thing as there are basically NO active 1st gen Tacomas anywhere in my region, its a sad FACT
    or maybe just regional
    but the feeling i get from posts around the region is just plain old BS from around here
  11. Feb 12, 2020 at 9:37 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    the bullshit frame coating needs fixed properly and thoroughly as possible before it gets any worse! its at the surface peeling away now that i have found
    there are still a number of places i have not thoroughly inspected up close
  12. Feb 12, 2020 at 9:41 PM
    Empty_Lord
    Dan
    the 4.7 would be a tight fit.
    the 5.7 would be ALOT OF CUTTING. i dont even think the frame is wide enough to mount it at a normal height
  13. Feb 12, 2020 at 9:41 PM
    Area51Runner
    So when you doing your interior @Kwikvette ?
    I'm going to order a different color. Think I'm going to try to put together an old school toyota green look. Not sure.
    cruiserguy and Kwikvette like this.
  14. Feb 12, 2020 at 9:42 PM
    Empty_Lord
    Dan
    theres only one way you'll get that frame 100%. EVERYTHING has to come off and it needs to be acid dipped.
  15. Feb 12, 2020 at 9:42 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    If @madmax700r can fit a 4BT in his truck, I'm sure you can mount a 5.7l in yours. Lol.
    I think he got away with a body lift.
  16. Feb 12, 2020 at 9:43 PM
    Empty_Lord
    Dan
    im going from green to white in the tundra. thinking amber to green in the Taco. im not a fan of white with white gauge faces.
    might go to black faces and do white.. hmmm who knows
    Area51Runner[QUOTED] likes this.
  17. Feb 12, 2020 at 9:43 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    the labor rate to remove the stuff i need removed, depending if i goto toyota mechanic or body shop, body shop labor rate is much cheaper than mechanic
    and then the storage time if i choose to not have a trailer haul it all back to my place for 2,3 or more weeks to get done whats needed
    probably will need a towtruck since i don't think its wise to drive without a bed, will be going back most likely without a fuel tank attached but I have not even gotten to that point yet!
    then haul it all back to the toyota shop to get it all reinstalled properly with absolute NO FUCK JOB, everything back in its place for another decade of happy motoring :)
    the bulk of that guesstimate is the storage time of the bed taking up a lift in a bay for the several weeks it may take me
    i would prefer to trailer the bed back so i can flip it over and do some minor fixing and proofing underneath easily
    so it 'may be' less than the original guesstimate
    idk
  18. Feb 12, 2020 at 9:43 PM
    Empty_Lord
    Dan
    the 5.7 is a MASSIVE engine. DOHC 90 degree v8
  19. Feb 12, 2020 at 9:43 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I've got plenty of Sawzall blades.
    What did you get from that truck anyway?
  20. Feb 12, 2020 at 9:43 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It isn't, can't even mount a 1gr
