  1. Feb 29, 2020 at 11:54 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Impossible.
    By then engines will be obsolete and I’ll be long
    Gone
  2. Mar 1, 2020 at 4:58 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    No wonder there wasn't much difference between Utah and Washington between the spoken English. At least not near as different when I go to Texas or Virginia. Interesting crap. I do remember growing up in VA and calling the little things roly polys. And then moving to Washington and sure enough it's a potato bug. Utah also calls it potato bug. Funny little weird language or culture stuff like this is cool:D:cool:5a4d0f80cf698a1d008b49ce.jpg
    04Pre_Runner and 01x4 like this.
  3. Mar 1, 2020 at 5:03 AM
    Running Board Man
    Running Board Man Well-Known Member
    Went to bed at 3am... woke up at 7... if only i could do that when i work
  4. Mar 1, 2020 at 5:20 AM
    Running Board Man
    You guys ever plug up the vents to your headlights cause they let shit inside?
  5. Mar 1, 2020 at 5:25 AM
    cruiserguy
    Elijah
    SEKS
    That's a different cab and bed and the transition between em and stuff is throwing me off... Is it a custom chopped 4runner cabin with a Hilux bed?
    Black DOG Lila and 01x4[QUOTED] like this.
  6. Mar 1, 2020 at 5:33 AM
    cruiserguy
    Elijah
    SEKS
    Oh nice. That extra part chunk of body after the rear door was throwing me off but sounds like it's just me not being used to seeing those around
  7. Mar 1, 2020 at 7:02 AM
    cruiserguy
    Elijah
    SEKS
    We had 55 degree days the last couple days but no matter, seems we always get a snowstorm in March(oh oops, pic doesn't show the flakes, just imagine crap load of flurries in the pic lol) :Dtmp-cam-6685685917677765212.jpg
    CS_AR and Black DOG Lila like this.
  8. Mar 1, 2020 at 7:13 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    RIGHT NOW:curls::mudding:
  9. Mar 1, 2020 at 7:13 AM
    Hooks98tacoma
    Hooks98tacoma Well-Known Member
    Georgia
    98 Tacoma 2.4
    Just ordered a heater core, blend door, new headlight housings, corners, blinker lights, shift knob, and clips for the grill. Now the fun part......WAITING:spending::woot:
    Black DOG Lila and cruiserguy like this.
  10. Mar 1, 2020 at 7:18 AM
    cruiserguy
    Elijah
    SEKS
    I never saw the follow up, so was the core plugged up then? Were you able to identify what/where the issue is?
  11. Mar 1, 2020 at 7:19 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I think my LC is getting temperamental starting in the cold, it always starts but it's begun to fire up and then die and then it'll start on the second try. Sometimes it catches itself and keeps going though. I need to see if the airflow meter is sticking or something, if the flap on that doesn't move then the fuel pump doesn't turn on.
    cruiserguy and Running Board Man like this.
  12. Mar 1, 2020 at 7:26 AM
    cruiserguy
    Elijah
    SEKS
    You already did all new ignition components didn't you? Not trying to tell you what's wrong, just trying to remember what you've done as PM already
  13. Mar 1, 2020 at 7:27 AM
    Speedytech7
    It had plugs, wires, cap, and rotor a couple years ago.
    cruiserguy[QUOTED] likes this.
  14. Mar 1, 2020 at 7:28 AM
    Speedytech7
    I should mention it's only on an actual cold start, like 30° and below when the engine is also cold.
    Running Board Man likes this.
  15. Mar 1, 2020 at 7:33 AM
    cruiserguy
    Elijah
    SEKS
    Definitely sounds like what you're saying could be possibility. Stuff like that, that ages and moves in all ambient temps, gets sticky and stuff. I don't remember reading about that 'flap' though. You know if it was only on the 93-94 1FZs?
  16. Mar 1, 2020 at 7:36 AM
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    It is clogged pretty nasty. The valve is fine. The hose temps going in is hotter than coming out. Was gonna flush it but it’s 21 years old so...
  17. Mar 1, 2020 at 7:39 AM
    Speedytech7
    Yeah it's a pre 95 thing for almost all non performance Toyotas. Performance Toyotas used the Karman infrared MAFs. The ones with the flap like I have are honestly crap, they're called a VAFM (vane airflow meter). More Air comes through them as the throttle blade opens and it pushes a flap that actuates a potentiometer. The issue is they're extremely inaccurate at low air speed, part of the reason the LC runs rich at idle, since it knows the meter is inaccurate and defaults to the computer map. They're also highly restrictive. Anywho the VAFM has a built in switch to cut off fuel pumps, a remnant left over from the days of early fuel injectors, but Toyota decided to still implement it and it may be the culprit here.
  18. Mar 1, 2020 at 7:40 AM
    cruiserguy
    Elijah
    SEKS
    Cool, glad you verified it was clogged before dropping the coin on it:cool:
  19. Mar 1, 2020 at 7:41 AM
    cruiserguy
    Elijah
    SEKS
    Yeah yeah, I follow you. Makes sense.
  20. Mar 1, 2020 at 7:41 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    We got like an inch I think,
    iso 80$ to go home for the night :rofl:
