  1. Apr 2, 2020 at 10:50 AM
    eon_blue
    Azusa, CA
    Ftfy
    Kwikvette likes this.
  2. Apr 2, 2020 at 10:51 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Badass, how many tanks do you guys have? All fresh water?
    I've done fresh water only, though I love salt water species (but not the cost, or maintenance it'll bring).
    Tarantula enclosures normally don't require cleaning but instead small maintenance such as removing substrate that may have dead, partially eaten critters and the sort. That more applies to a terrestrial species. Fossorial live underground, and arboreal will never touch the ground.
    Its more about maintaining specific humidity levels for those that require it, and having the right ventilation and substrate will limit, if not prevent, the growth of mold.
    Das it mang[QUOTED] likes this.
  3. Apr 2, 2020 at 10:52 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    slow and low that is the tempo
    se7enine likes this.
  4. Apr 2, 2020 at 10:53 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Let it flow
  5. Apr 2, 2020 at 10:54 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    eon_blue[QUOTED] likes this.
  6. Apr 2, 2020 at 10:57 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So normally they're shipped in a vial or small enclosure of some sort.
    Slightly moistened papertowels to line the the enclosure, and the spider is then "encouraged" to go in the pocket of the papertowel wrap.
    Vial/enclosure is then placed in a styrofoam box with a heatpack (if needed based on ambient temps) to maintain hospitable temps while being shipped.
    And no, definitely not flat rate!
    Overnight is required for something like this that's alive.
  7. Apr 2, 2020 at 10:57 AM
    Wulf
    rock raisin
    magic mushroom starter kit
    FLBAdrian[QUOTED] and Kwikvette like this.
  8. Apr 2, 2020 at 11:01 AM
    Wulf
    rock raisin
    take a trip?
  9. Apr 2, 2020 at 11:01 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Wanna talk about?...
  10. Apr 2, 2020 at 11:03 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  11. Apr 2, 2020 at 11:04 AM
    eon_blue
    Azusa, CA
    Remember Infected Mushroom from back in the day? Saw them live once ~13 yrs ago, don't really remember it though lol
    https://youtu.be/nJDpXPVFRUo
  12. Apr 2, 2020 at 11:06 AM
    Wulf
    rock raisin
  13. Apr 2, 2020 at 11:07 AM
    Wulf
    rock raisin
  14. Apr 2, 2020 at 11:07 AM
    Wulf
    rock raisin
    I do not
  15. Apr 2, 2020 at 11:09 AM
    eon_blue
    Azusa, CA
    Should check them out, one of the original Psy-trance/Psy-rock music groups out of Israel.
    Wulf[QUOTED] likes this.
  16. Apr 2, 2020 at 11:16 AM
    Running Board Man
    Running Board Man Well-Known Member
    Ok guys problem with the t4r
    Pertaining to the abs/vsc if i start it up and put it in drive and you know try to drive it just clicks and ticks i floor it and it doesnt go anywhere the abs vsc and trac lights are on
    But reverse acts like normal and once the system shuts itself down its normal just no driver aids and lights galore
    If it isnt a wheel speed sensor im deleting the system cause aint nobody got time fo dat
  17. Apr 2, 2020 at 11:22 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    *reads between the lines and discovers you're simply trying to confirm Jake's real age through the use of trivia*
  18. Apr 2, 2020 at 11:22 AM
    Wulf
    rock raisin
    did you ever listen to Ra? they are american but this post totally reminded me of them lol
    Running Board Man likes this.
  19. Apr 2, 2020 at 11:23 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    As in, won't physically move forward?
    Kind of hard to understand with the lack of punctuation.
  20. Apr 2, 2020 at 11:24 AM
    Running Board Man
    No, it wont move while im giving it gas, all its doing it clicking from what seems like the abs pump even if i try to floor it to get the 30% mechanical overide... no response whatsoever
    After i installed my spcs i felt like the abs sensor wire was too tight
