What would you rather listen to instead of Cold Play
Poll closed Today at 7:20 AM.
  1. Nails on a chalboard
    5.6%
  2. Bass boosted memes
    55.6%
  3. Rod knock
    50.0%
  4. Political discourse
    11.1%
  5. That one annoying drunk gal at a comedy club
    11.1%
  6. No i really do like Cold Play and I'm not writing this under duress (help Cold Play is in the room)
    11.1%
Multiple votes are allowed.
  1. Apr 3, 2020 at 10:29 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    TGIF
    Tomorrow need to change the oil on the 5.0
    Contemplating the winch install on the Tacoma, just out of boredom?
    CS_AR and Running Board Man like this.
  2. Apr 3, 2020 at 10:29 AM
    Running Board Man
    Running Board Man Well-Known Member
    I saw the thread where the guy sells em for $360?
  3. Apr 3, 2020 at 10:30 AM
    Running Board Man
    Low key dissappointed, you pay like 1200 for some lcas and the bushings come without grease
    at least they came with stickers
    Im looking at you @truenorthfabrications
  4. Apr 3, 2020 at 10:31 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :worthless:
  5. Apr 3, 2020 at 10:37 AM
    Running Board Man
  6. Apr 3, 2020 at 10:40 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Them feet tho :boink:
    I used Superlube with great results on my poly LCA bushings; can find it anywhere.
    Though I also have Prothane Super Grease which is thick as hell; was supposed to use it on my poly bushings for my leaf springs but only when I get bored enough to do it. Supposed to stick pretty damn well.
    Here's a comparison -
    https://www.suspension.com/blog/the-best-grease-for-polyurethane-bushings/
  7. Apr 3, 2020 at 10:40 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    did you reach out to them to ask or did you just @ them? :luvya:
  8. Apr 3, 2020 at 10:43 AM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Who makes these LCAs? are they standard length? I need to upgrade.
  9. Apr 3, 2020 at 10:45 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Solo
    Running Board Man likes this.
  10. Apr 3, 2020 at 10:45 AM
    Running Board Man
    Solo motorsports, stock length but push the tire a full inch forward in the wheel well, limit strap mounts, and bump stop strike plates
    Wulf likes this.
  11. Apr 3, 2020 at 10:45 AM
    Wulf
    rock raisin
    What is the issue with factory LCAs? they're pretty damn beefy
  12. Apr 3, 2020 at 10:45 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's the millennial way :burp:
  13. Apr 3, 2020 at 10:45 AM
    Wulf
    rock raisin
    interesting
  14. Apr 3, 2020 at 10:46 AM
    Running Board Man
    I bought a bumper and sliders from them
  15. Apr 3, 2020 at 10:46 AM
    Wulf
    rock raisin
    I guess I'm old because I'd turn to social media shaming only after reaching out to the company
  16. Apr 3, 2020 at 10:48 AM
    Running Board Man
    I went through it when i put energy suspention bushings on my tacoma... didnt get any squeeks on my ucas where i put SL but they it had nowhere near the surface tension (stickyness) that energy suspentions propriatery herbs and spices did
  17. Apr 3, 2020 at 10:48 AM
    JKO1998
    Utah
    Check your lower shock mounts, they start to tear there, working down through the arm until
    Tour991 and Running Board Man like this.
  18. Apr 3, 2020 at 10:50 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh same.
    I had several recommendations to a specific shop/vendor here when I was ordering my Fox 2.5 front, 2.0 rear, and OME Dakar's all at once.
    Called, two different times left vmails.
    Tagged, two or three times in the forum.
    Emailed, once with no reply...included in the content of my inquiry my attempts to reach.
    Messaged them via forum to no avail.
    Haven't shamed them at all but hey, if they don't want my money that's fine by me.
    Pyrifera and Running Board Man like this.
  19. Apr 3, 2020 at 10:50 AM
    Running Board Man
    Thay are, and theres nothing wrong with them but... you saw how my rear shock broke so i wanted a place to put a limit strap up front once i get some coilovers i care about
    And with the t4r limited flares my tires rub them at full compression which usually happens when going fast so its not pleasent to hear or see the damage
  20. Apr 3, 2020 at 10:51 AM
    Running Board Man
    Im not shaming them just throwing shade
