  1. Apr 10, 2020 at 4:14 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Considering the rack uses much less fluid than the old boxes this makes sense. Just get a 3vz-e pump
  2. Apr 10, 2020 at 4:14 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    It's weird I have a friend running bone stock 3.4 pumps from autozone on his 4runner with hydro assist and it works fine. Meanwhile mine hates life with a ford box and a cooler damn near the size of my radiator. That also may be because my ps steering box is like .5" (literally) from the exhaust manifold.
    CS_AR and Wulf[QUOTED] like this.
  3. Apr 10, 2020 at 4:15 PM
    Wulf
    rock raisin
    Yeah it seems to be a real gamble
    slander[QUOTED] likes this.
  4. Apr 10, 2020 at 4:16 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    @Kwikvette Yup the Slash is dying, probably gonna get a new JBL to replace it. I had great luck with them in my last three rigs.
    Wulf likes this.
  5. Apr 10, 2020 at 4:18 PM
    slander
    Hickory, NC
    To add another layer of confusion to this, I had a hydraulics expert on my old team at work telling me we are all running waaaay too high of a gpm through the system and that's why everything overheats and doesn't work right. He then went into a bunch of terms and calculations that I was way to dumb to follow.
    Running Board Man likes this.
  6. Apr 10, 2020 at 4:18 PM
    Wulf
    rock raisin
    Am I right in remembering that they mount the same? Just different reservoir and the high pressure output location different?
  7. Apr 10, 2020 at 4:19 PM
    Running Board Man
    Running Board Man Well-Known Member
    My cat was inside for a whole 32 hours and started getting pist at everything
  8. Apr 10, 2020 at 4:20 PM
    Wulf
    rock raisin
    Hmmm, that is interesting, I thought it was the opposite
    What are you running for fluid? I know PSC/TG say not to use ATF
  9. Apr 10, 2020 at 4:20 PM
    Empty_Lord
    Dan
    I honestly am not sure it’s been so long. But the 3.4l and 3.0l were the same block. Should be able to make work
  10. Apr 10, 2020 at 4:29 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Hahahahaha
    No plan aside from laundry, and cutting my own hair if my clippers arrive.
    Based on the forecast this weekend, I'll be doing some light wheeling with the possibility of staying the night if LEO don't kick me out.
    Wulf[QUOTED] likes this.
  11. Apr 10, 2020 at 4:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oof
    Is it not putting out the right current?
    I've always adjusted the amp based on the signal output with the volume at 3/4 off max by measuring the voltage/current from the speaker output on the amp
  12. Apr 10, 2020 at 4:38 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Any chance an aftermarket high pressure line was installed? I've seen some Nissan pumps scream bloody murder when an aftermarket high pressure line is installed.
    cruiserguy and Running Board Man like this.
  13. Apr 10, 2020 at 4:40 PM
    Wulf
    rock raisin
    I am running an aftermarket high pressure line, you may be onto something with it causing issues
  14. Apr 10, 2020 at 4:40 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Running Board Man and Kwikvette like this.
  15. Apr 10, 2020 at 4:42 PM
    Speedytech7
    It's acting almost like someone is turning the gain down, and then it'll come back randomly for a bit. I had it adjusted perfectly, had the oscilloscope on it originally to dial it in to max before clipping. And I hadn't touched it since setting it. It's just had it. Had an easy life with me too, I use it hard but it's only driving a 350w sub.
  16. Apr 10, 2020 at 4:45 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    The girl calls me “miguel my bell”
  17. Apr 10, 2020 at 4:52 PM
    Speedytech7
    Found a 500w Alpine, that'll do
  18. Apr 10, 2020 at 4:58 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Interesting....wonder if heat has anything to do with it.
    Thermal protection could be kicking in to save itself, prematurely
  19. Apr 10, 2020 at 4:59 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    :rofl:
  20. Apr 10, 2020 at 5:02 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Kinky?
