  1. Apr 15, 2020 at 9:16 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    yea, i got to wait another week for my scope and upper :(
  2. Apr 15, 2020 at 9:17 PM
    Running Board Man
    Running Board Man Well-Known Member
    Finally got a rear cup holder
  3. Apr 15, 2020 at 9:18 PM
    Running Board Man
    Are torsens any good offroad?
  4. Apr 15, 2020 at 9:19 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    :censored:
  5. Apr 15, 2020 at 9:21 PM
    Area51Runner
    pfft.
    25MB down my ass... at least not with ATT UVERSE <-------> BattleNet
  6. Apr 15, 2020 at 9:23 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Not the worst they actually achieve a full lockup side to side like a Detroit Locker but they release easy and allow mild turns under pressures without hopping and skipping. They're entirely geared. The most famous use of a Torsen design is a Detroit TruTrac. I've noticed this Toyota Torsen is pretty aggressive if I leave hard on the pedal in a turn, it'll chirp the inner tire indicating it's locking 100%, even if I leave in a hurry it might, but I can be soft and it'll be quiet too. Quite sporty, I like it. It'll light em both up for a burnout easy
  7. Apr 15, 2020 at 9:31 PM
    Running Board Man
    Its just ive seen vids where the true track goes open diff when lifting a tire off the ground but locking up with brake application sometimes other times not
    But from what ive read they seem like the perfect diff
  8. Apr 15, 2020 at 9:38 PM
    Speedytech7
    They still are a "limited" slip, they will slip if the imbalance is too great. They aren't lockers, however they don't freewheel 100% either, unlike an open diff something is still going to the side with traction, whether it's enough depends on weight and the situation. I don't think they're good locker replacements, plus toyotas are often overlanding and camping rigs, heavy... but they have little baby diffs and that doesn't leave a ton of room for a limited slip to do it's thing in a robust way, when up against 4k+ lbs. However on a light little car with car diameter tires where traction is often within 1-1.5:1 ratio side to side, no worries, other than straight up drag racing at super high HP I'd way rather have a torsen than open or a spool. And clutched LSDs are just annoying and they wear out.
  9. Apr 15, 2020 at 9:41 PM
    Running Board Man
    https://youtu.be/OIe9XGrPtmw
    https://youtu.be/uMy7az5rPWs
  10. Apr 15, 2020 at 9:44 PM
    Speedytech7
    I don't know about that first one, that actually seems kind of normal given the big tires. The one in that second video is broken. You couldn't even begin to do that with my Lexus, it would have taken off right off the jack
  11. Apr 15, 2020 at 9:47 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    a torsen is what the tundra will eventually get when the clutch packs finally give in the diff. surrpised it still works like its suppose to at 200k
    Running Board Man likes this.
  12. Apr 15, 2020 at 9:48 PM
    Speedytech7
    Does Toyota still sell clutch rebuilds? I know you used to be able to get Kevlar clutches for the 2nd and 3rd gen supra
  13. Apr 15, 2020 at 9:49 PM
    Empty_Lord
    Dan
    i cant find the rebuild kits listed. but i havent looked too far into it
  14. Apr 15, 2020 at 9:50 PM
    Empty_Lord
    Dan
  15. Apr 15, 2020 at 9:52 PM
    Running Board Man
    I was thinking about copping but i saw the jeep video and decided to hold off, with my 4 runners A-TRAC (locks wheel thats spinning) it should aid the true track though right?
    04Pre_Runner likes this.
  16. Apr 15, 2020 at 9:59 PM
    Empty_Lord
    Dan
    @Speedytech7 no rebuild from toyota.. oh well. it still works like it should at least when i gas it when turning i get the shudder of a working clutch pack.
  17. Apr 15, 2020 at 10:01 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That was not cheap to make.
    I dig it
    Before you commit though, ensure the butt stock and other little odds and ends are the pattern you seek.
    AR10 is not standardized as there are 2 platforms they're built off of.
    Empty_Lord[QUOTED] likes this.
  18. Apr 15, 2020 at 10:02 PM
    Empty_Lord
    Dan
    @Kwikvette i;ll be back on the game in a wee bit. gotta do some small "housekeeping" things
    Kwikvette likes this.
  19. Apr 15, 2020 at 10:03 PM
    Empty_Lord
    Dan
    DPMS is the most common and the one im going for, the armalite stuff is harder to come by
    Kwikvette[QUOTED] likes this.
  20. Apr 15, 2020 at 10:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Take your time seeing as how @Area51Runner super high speed low drag ultra tactical uber 1337 pwnage interwebz is blazing at over 9000 :jerkoff:
    what road and Empty_Lord[QUOTED] like this.
