  1. Apr 16, 2020 at 10:01 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    well now you just jinxed him :luvya:
    Kwikvette[QUOTED] likes this.
  2. Apr 16, 2020 at 10:01 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    What’s “shims”
  3. Apr 16, 2020 at 10:03 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh you can actually prep the truck and cut your install time in half!
    Lift truck, remove rear tires, remove rear shocks, undo u bolts, remove bolts for leaf spring, loosen leaf spring bolts on ends, finalize removing u bolts, remove leaf spring bolts and remove leaf pack.
    Once new leaf pack arrives, move forward with install and done.
    Wulf likes this.
  4. Apr 16, 2020 at 10:03 AM
    Wulf
    rock raisin
    those bastards are so full of life and a bit of a pain in the ass but they are adjusting well to human interaction
  5. Apr 16, 2020 at 10:04 AM
    eon_blue
    Azusa, CA
    Got some 2.5° or 3° axle shims over a year ago and never installed, can't remember which. But my pinion seal has a slow leak from the rear lift angle.
    JKO1998[QUOTED] likes this.
  6. Apr 16, 2020 at 10:04 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :rofl:
    IN before the "HALP LEAF SPRING BOLT BROKE" thread
  7. Apr 16, 2020 at 10:04 AM
    Wulf
    rock raisin
    Pinion seal shouldn't leak at any angle, it's going bad or your vent is clogged and it's pushing oil through the seals when it heats up
    eon_blue[QUOTED] likes this.
  8. Apr 16, 2020 at 10:04 AM
    eon_blue
    Azusa, CA
    You know, that I could do... Not like I really need to drive anywhere
    Actually shit that reminds me, I am supposed to go into work next week but don't know which day yet
  9. Apr 16, 2020 at 10:05 AM
    JKO1998
    Utah
    Huh, weird
  10. Apr 16, 2020 at 10:05 AM
    Wulf
    rock raisin
    bro I don't spend more than a few minutes trying to unbolt them. If they're being a dick they just get cut
  11. Apr 16, 2020 at 10:05 AM
    eon_blue
    Azusa, CA
    Hmm maybe I should finally install that rear diff breather ext too
  12. Apr 16, 2020 at 10:06 AM
    eon_blue
    Azusa, CA
    Never had issues with the leaf spring bolts, plus mine have been on/off so many times the last few years they just zip off pretty easy
    Wulf[QUOTED] likes this.
  13. Apr 16, 2020 at 10:07 AM
    Wulf
    rock raisin
    That sounds like an easy project win
    u bolts too?
  14. Apr 16, 2020 at 10:09 AM
    eon_blue
    Azusa, CA
    Yep had Alcan make them for me, they wanted specs so I just copied the OME Ubolt specs off their website lol. Those are the ones I have on now anyway so they should work
  15. Apr 16, 2020 at 10:10 AM
    Wulf
    rock raisin
    did you account for any difference in pack thickness? :luvya:
    Kwikvette likes this.
  16. Apr 16, 2020 at 10:10 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  17. Apr 16, 2020 at 10:12 AM
    Wulf
    rock raisin
    gib us the money lebowbski
    se7enine[QUOTED] likes this.
  18. Apr 16, 2020 at 10:12 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh that's right, skeleton crew.
    Just hope your leaf pack gets there early enough.
  19. Apr 16, 2020 at 10:12 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
  20. Apr 16, 2020 at 10:13 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh they're super easy.
    I was picturing this scenario where the head broke flush with the leaf spring hanger, and the other end didn't have enough threads past the nut :rofl:
    Especially on the driver side where the fuel tank is.
