  1. Apr 30, 2020 at 6:02 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    My neighbor is a doctor.
    they just laid off doctors at the hospital here because there’s an abnormally low amount of patients.
    good news is we’re out of sip next week
    eon_blue[QUOTED] likes this.
  2. Apr 30, 2020 at 6:02 PM
    eon_blue
    Azusa, CA
    Got some new U-bolts today from Headstrong, got here fast... Ordered them on Tuesday.
    The Alcan ones I got with the springs were the wrong size, I sent them the specs for the OME ones off OME's website, but it turns out OME measures u-bolts differently than Alcan and that's why mine were off. So technically it was my fault and I couldn't ask them to send me another set for it.
  3. Apr 30, 2020 at 6:05 PM
    eon_blue
    Azusa, CA
    That is good news in a way because that means the virus isn't affecting you guys so bad. But it sucks to get laid off no matter the circumstances.
    Once the SIP order is lifted and people go about their normal routines again I'm sure hospitals will get busier and the docs will get their jobs back
  4. Apr 30, 2020 at 6:05 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yes, P0141 indicates there is a problem in the heating circuit of the O2 sensor bank, sensor 2, so the after cat sensor. I too don't believe that would contribute to a miss that stays all the way through the RPM line. I also don't think the miss would be caused by the cracked exhaust manifold. If anything you may hear ticks on cold startups and then as the manifold gets hot the crack swells up and can quit ticking.
    How about a vac leak? You guys already gone through the vac hoses and intake stuff?
  5. Apr 30, 2020 at 6:08 PM
    eon_blue
    Azusa, CA
    Ya I had that code but for the first sensor, no change in performance at all just a check engine light. I did notice my closed loop AFRs were off but that was the only abnormal thing. New O2 sensor fixed it
  6. Apr 30, 2020 at 6:09 PM
    Hooks98tacoma
    Hooks98tacoma Well-Known Member
    Georgia
    98 Tacoma 2.4
    Sprayed all vacuum lines with brake cleaner and no leaks. I know that leak caused the code. I was pretty sure it didn’t cause the misfire. No ticking on cold start or anything noisy so I think the leak isn’t too bad. I have parts to change the fuel pump out but don’t think that’s the issue. How do I know it’s not the IAC? Cleaned MAF before and new plugs and wires. Again I have no codes for a misfire. I’m stumped....guess I need a break.
    cruiserguy[QUOTED] likes this.
  7. Apr 30, 2020 at 6:09 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    60% = spacer
    35% = Billy’s/ OME
    5% = coilovers
    Kwikvette[QUOTED] likes this.
  8. Apr 30, 2020 at 6:14 PM
    Empty_Lord
    Dan
    My spare frames on spacers,
    My taco is on icons
    My tundras on billies with springs.
    I’ve covered all the bases
    Kwikvette and 04Pre_Runner like this.
  9. Apr 30, 2020 at 6:14 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    I see what you're trying to say and no
    cruiserguy likes this.
  10. Apr 30, 2020 at 6:16 PM
    cruiserguy
    Elijah
    SEKS
    Yeah I'd say it's a good idea to hold off on fuel pump for now as well.
    The symptom you describe is most commonly caused by sparkplug, or sparkplug wires, or coil packs. You've looked at the 4 spark plugs right? You've tested the coil packs? A miss caused by any of those things doesn't always throw a code. It USUALLY does, but not always.
    How's the intake tube and air box and that stuff? I've seen hairline cracks in the bottom of intake tubes that would've drove me nuts trying to find but already had been told to check there
  11. Apr 30, 2020 at 6:18 PM
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    New plugs and wires. They’re good and when i took the intake tube off to change the plugs and wires I didn’t see ant issues with it. Maybe it is the coils. Do you have any info on testing the ohm load on them to see if they’re good? Also may try recleaning the MAF and clean the IACV
  12. Apr 30, 2020 at 6:21 PM
    eon_blue
    Azusa, CA
  13. Apr 30, 2020 at 6:21 PM
    cruiserguy
    Elijah
    SEKS
    Yeah couldn't hurt on cleaning those.
    With the snap-on scanner it'd be interesting to see the fuel trim numbers to make sure they stay good through the rpm band. Once you know the injector and gas side of it is fine......wait a sec. It could be an injector couldn't it?
  14. Apr 30, 2020 at 6:22 PM
    Empty_Lord
    Dan
    cruiserguy and eon_blue[QUOTED] like this.
  15. Apr 30, 2020 at 6:22 PM
    Empty_Lord
    Dan
    In rare cases yes. Break up at higher rpm could be a crank sensor dropping out, ive had that happen before
  16. Apr 30, 2020 at 6:22 PM
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    Possibly. Ain’t that common on these trucks? Need info on testing them and testing the coils.
  17. Apr 30, 2020 at 6:22 PM
    eon_blue
    Azusa, CA
    Dress it up to look like the Back to the Future truck and sell it for $60k
  18. Apr 30, 2020 at 6:23 PM
    Empty_Lord
    Dan
    Na, it’s a 65k mile cream puff that looks like it rolled off the line yesterday. Completely stock
  19. Apr 30, 2020 at 6:23 PM
    cruiserguy
    Elijah
    SEKS
    What about a miss from idle through all rpm?
  20. Apr 30, 2020 at 6:24 PM
    eon_blue
    Azusa, CA
    Then you could definitely get a pretty penny for it. Assuming he sells it to you cheap. Got pics?
