  1. Aug 26, 2018 at 9:23 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I think one would be enough
  2. Aug 26, 2018 at 9:25 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    True. It’s not really that big in a extra cab. But still 400$ for one is pretty crazy, ill just wait till it gets old and price comes down some lol
  3. Aug 26, 2018 at 9:34 AM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    Get a 10" Kicker Comp C I'll post pics in a bit
    Sperrunner likes this.
  4. Aug 26, 2018 at 9:36 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I want it hidden in the panels, not a box in the back seats
  5. Aug 26, 2018 at 9:38 AM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    You have an Xtra cab? I saw a setup where some guy put the sub in the back where the jack goes, or the one on the passenger side because it's a little bigger. Was a clean install
  6. Aug 26, 2018 at 9:40 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Ive seen that, but i keep tools in there lol
  7. Aug 26, 2018 at 9:49 AM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    I just put some kicker 5×7's in the stock location. Lil more thump. And you can't tell there under the rear panel.
  8. Aug 26, 2018 at 9:51 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I have new speakers all around just no sub
    lucky13don[QUOTED] likes this.
  9. Aug 26, 2018 at 9:56 AM
    eon_blue
    Azusa, CA
    Alright so I've got a pretty bad brake pull going on when I hit the brakes relatively hard...it pulls right. Been going on for a little while and thought maybe it was the alignment but that's good. Definitely something with the brakes. Every morning when they're cold they make a lot of noise too which I've attributed to them not having been "bed in" properly when installed 6 months ago but now I'm wondering if maybe I've got a caliper issue.
    How would I go about checking on the health of a brake caliper? Aside from doing the Tundra swap...that'll happen someday.
    Running Board Man likes this.
  10. Aug 26, 2018 at 9:58 AM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Might slide a 8" sub under the passenger seat. It won't sound like my old lowered chevy with 6000 watts and 4 15's, but it'll be a improvement
    Sperrunner[QUOTED] likes this.
  11. Aug 26, 2018 at 9:58 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    All hoses are fine?
    Was the caliper bleed fully? Could one be stuck?
  12. Aug 26, 2018 at 10:01 AM
    eon_blue
    Azusa, CA
    SS brake lines I put in maybe 4 months ago. They look fine...system was bled when I installed them. My brother and I bled the brakes the old fashioned way for probably 30 min but we were kind of rushed since the SS lines took longer to install than we planned. Maybe I should go back and re bleed the system again and take more time with it?
  13. Aug 26, 2018 at 10:01 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    ABS?
    There was a TW member that was having a similiar problem. He un plugged his ABS module and it went away.
  14. Aug 26, 2018 at 10:01 AM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Pop the wheel off and give it a once over. Take a green scrubby and brake clean and hit the rotor and rebed the brakes.
    eon_blue likes this.
  15. Aug 26, 2018 at 10:01 AM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Didn't think about that...good call
  16. Aug 26, 2018 at 10:02 AM
    eon_blue
    Azusa, CA
    Yep I have ABS. I'm not hitting them hard enough to activate it though. Just a good solid press of the brake and I can feel it pull right.
  17. Aug 26, 2018 at 10:03 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Worth a shot re bleeding.
    Or possibly a metal hard line is smashed? (Doubt it)
    Also maybe a warped rotor? I would check pads for uneven wear
  18. Aug 26, 2018 at 10:03 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    See edit^
    Sperrunner and lucky13don like this.
  19. Aug 26, 2018 at 10:06 AM
    eon_blue
    Azusa, CA
    Yeah I'd be surprised if the metal line was bad already and I haven't really done any hard wheeling lately but I'll check them over just in case.
    Pads and rotors are new but I never bed them in because I didn't know about that process at the time. Gonna do what @lucky13don suggested and clean the rotors/re-bed the brakes today if I can. If that doesn't work I'll pick up one of those bleeder kits and try to fully bleed the system.
    Ah good to know...if the re-bedding doesn't work I'll give that a try thanks
  20. Aug 26, 2018 at 10:09 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Day old rotors can warp if they get hot the cold fast.
    And to bed in breaks the “right” way is kinda scary, requires you doing like 50 then hard stops to 10 and repeat. Lots of people ik just drive it normally but never come to a full stop to not transfer material onto the rotors
