  1. May 9, 2020 at 2:20 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    NC (atleast my city) used to be big on recycling. Until they had massive warehouses full of recyclable goods without anyone to buy it/process it. Now the city is very strict on what can go in the recyclables bin.
    Recycling anything is a very expensive process. Why would a manufacturer pay more money to use material that they have to spend more time on processing then they would new material? Its a simple business decision to make your product from new raw material instead.
    BartMaster1234[QUOTED] and Wulf like this.
  2. May 9, 2020 at 3:03 PM
    Wulf
    rock raisin
    Blew off the new IC pipe and blacked out an intersection on the highway :bananadead:
    Put it back on on the shoulder of the highway, then limped the truck home, cleaned everything with brake cleaner, and put it back together with hair spray for extra fit
    :fingerscrossed:
  3. May 9, 2020 at 3:17 PM
    Hooks98tacoma
    Hooks98tacoma Well-Known Member
    Georgia
    98 Tacoma 2.4
    Here’s where I’m at on the skipping issue.
    Fuel Pressure is at 47psi
    Compression is:
    Cyl 1 @190psi
    Cyl 2@180psi
    Cyl 3@175psi
    Cyl4@180psi
    On top of all the new goodies.
    Leaves me to one thing....maybe clogged injector(s)??????
  4. May 9, 2020 at 3:25 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Dude at the exhaust shop I went to was a lazy prick, I pulled it off the lift and left. Didn't wanna take the time to do it right, glad I didn't cancel my appt with my regular guy, he's worth the wait.
    Wulf and 04Pre_Runner like this.
  5. May 9, 2020 at 3:27 PM
    Speedytech7
    Bad cam or crank sensor maybe? I've had that happen
  6. May 9, 2020 at 3:54 PM
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    Will check that as well
  7. May 9, 2020 at 3:55 PM
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    What kind of crap was he trying to skimp out on?
  8. May 9, 2020 at 4:02 PM
    Speedytech7
    Was almost acting like he can't make his own hangers or bend pipes. Just said the muffler is too big... It's physically smaller than stock and the only real hurdle is the inlet is centered instead of offset
  9. May 9, 2020 at 4:10 PM
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    Just lazy... wants the money but don’t wanna work
    Wulf likes this.
  10. May 9, 2020 at 4:11 PM
    Speedytech7
    If I had the tools to bend my own pipe I'd just do it myself chances are I weld better than that bum anyway. Actually about to weld right now
    Hooks98tacoma[QUOTED] likes this.
  11. May 9, 2020 at 4:16 PM
    Wulf
    rock raisin
    Check the injectors with a multimeter
  12. May 9, 2020 at 4:25 PM
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    Yeah man. I have 2 friends that own shops and they tell me all the time that their tools are at my disposal. Great friends
    Tour991 likes this.
  13. May 9, 2020 at 4:26 PM
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    As in the wiring? I’ve used a noid light for testing the wiring. Thinking that one or more may be clogged
  14. May 9, 2020 at 4:31 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    I've done the PS3. It's probably your hard drive in it failing. That's the only moving part other than fans. Guess it could be one of the fan bearings going bad too. Lots of youtube vids on how to open them.
    SouthernYoder and 04Pre_Runner like this.
  15. May 9, 2020 at 4:34 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Oil/filter change and finally did the t-case fluid on the 4runner. Made sure the 4wd and center diff lock solenoids were still working after. All is good. Hopefully the Lucas 75w-90 gear oil helps still the minor leaking of the t-case. I think working the 4wd/diff lock solenoids is helping too by keeping the seals lubricated. Someday I'll swap in a FJ t-case that has actual shifters and not worry about the stupid solenoids again.
  16. May 9, 2020 at 4:52 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I can’t open a ps4. Not certified.
    Need your engine rebuilt? I gotchu fam
  17. May 9, 2020 at 4:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  18. May 9, 2020 at 5:11 PM
    Wulf
    rock raisin
    If you can access the back usually you can peel a sticker off and expose a bearing. A drop of oil would do it.
    I've kept fans running that way
    xtremewlr likes this.
  19. May 9, 2020 at 5:12 PM
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    Dang am I the only person in the world without a PS4 or Xbox?
  20. May 9, 2020 at 5:13 PM
    Speedytech7
    Couple of bits of c-channel and some welded in studs to make some hi lift jack mount pads
    Lazy fab work with shit I've already got
    Wulf likes this.
