  1. May 10, 2020 at 6:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  2. May 10, 2020 at 6:18 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Bad at hide and seek*
  3. May 10, 2020 at 6:18 PM
    JKO1998
    Utah
    Percolator*
  4. May 10, 2020 at 6:20 PM
    eon_blue
    Azusa, CA
    Oh...yeah that
    Hide and seek is all fun and games until someone zero dark thirties your ass
    JKO1998[QUOTED] likes this.
  5. May 10, 2020 at 6:23 PM
    JKO1998
    Utah
    I have 30 hound dogs around me that bark at a mouse so fuck you
  6. May 10, 2020 at 6:24 PM
    eon_blue
    Azusa, CA
    you're one of those angry drunks huh
  7. May 10, 2020 at 6:38 PM
    Running Board Man
    Running Board Man Well-Known Member
    Aye yall... whatchu think about me replacing just the timing belt on my camry
    Wow, the tensioner setup is just a little spring that slots into a peg protruding from the block
  8. May 10, 2020 at 6:47 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yeah pretty simple set up. You'll know if you can reuse the tensioner
  9. May 10, 2020 at 6:50 PM
    Running Board Man
    I have no idea what the t belt is like on the car or even how many miles it has
    Odo broke before the car
    I need to take the motor mount and shit off just to see the belt so may as well replace it if im going that far
    nothings leaking or making noise so why bother its supposed to be cheap, reliable, efficient transportation which its proving to be
    cruiserguy[QUOTED] likes this.
  10. May 10, 2020 at 7:19 PM
    Hooks98tacoma
    Hooks98tacoma Well-Known Member
    Georgia
    98 Tacoma 2.4
    On something that you’re gonna be dailying I’d go ahead and do the the timing belt and water pump at one time. Fluid flush everything and make sure brakes, tires, suspension, and other small things to make it better and more reliable. Some of the things I go through when I’m looking at buying a car or just got the car for being my daily
  11. May 10, 2020 at 7:26 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  12. May 10, 2020 at 7:27 PM
    Running Board Man
    Im not looking to spend 3k in stuff on a 1k car
    Value per dollar is what im after
  13. May 10, 2020 at 7:46 PM
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    What’s all wrong with the car?
    I’ve always bought a vehicle and went through everything that needed to be changed and took care of it first thing. Just the way I’ve done it.
  14. May 10, 2020 at 7:51 PM
    Running Board Man
    Not much if your standards are low it has no speedometer or odometer a couple door handles are missing so that would be nice to have but doesnt bug me
    Only code it has is an o2 sensor, could use a torque strut mount, the voltage reg tested bad but its good enough to keep driving every day
    Coolant is very clean no overheats to date
    Ive ordered a bunch of shit but only gotten and installed front suspention joints
    Getting all 4 struts, sway bar bushings, an intake boot, pads, rotors, and plugs... pretty sure a surprise package i forgot will show up
    Hooks98tacoma[QUOTED] likes this.
  15. May 10, 2020 at 9:03 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    too bad all that will fail before 150k miles.
    Speedytech7[OP] likes this.
  16. May 10, 2020 at 9:10 PM
    Empty_Lord
    Dan
    replace that torque strut before it destroys the back mount. those rear mounts are a pain. The torque mount ive replaced for less than 10 bucks before. ive seen those rear mounts go and pop the radiator hose off the radiator on the highway.
  17. May 10, 2020 at 9:47 PM
    Running Board Man
    Will do, im looking for a polyurethane insert type mount to hold the powertrain in place better
  18. May 10, 2020 at 9:48 PM
    Empty_Lord
    Dan
    dont waste your time. theyre great engines. but they'll rattle your teeth out with poly mounts. get a cheap torque mount and live happy.
  19. May 10, 2020 at 9:50 PM
    Running Board Man
    Ok than
  20. May 10, 2020 at 9:57 PM
    Empty_Lord
    Dan
    aisin timing belt kit is inbound for the 4runner engine, Toyota gasket kit should show up within a day or 2 at work... then this next weekend im going to try and get the engine up on the engine stand and get it all resealed. might even paint the block to look pretty. Also thinking about gasket matching everything just to see what a 252k mile 4runner engine can do with headers, airaid tube, and camry cams.
