  1. Jul 7, 2020 at 10:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ha don't sell yourself short; I'm 5' 6.5" but got rounded up to 5'7 :rofl:
    Empty_Lord[QUOTED] likes this.
  2. Jul 7, 2020 at 10:43 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    ive got a oil thermostat for my future trans setup.. dont want to run -an lines.. going to run hard line to rubber line with quick connects, then the other side quick connect on the stock cooler lines... but apparently finding push connector fittings (or hell i'd take regular hose barbs!)
    Running Board Man likes this.
  3. Jul 7, 2020 at 10:44 PM
    eon_blue
    Azusa, CA
    Lol
    Kwikvette[QUOTED] and Empty_Lord like this.
  4. Jul 7, 2020 at 10:45 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    He lurks in the shadows :rofl:
    eon_blue[QUOTED] likes this.
  5. Jul 7, 2020 at 10:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So you want to use a transcooler at a specific temp but bypass it when temps are cooler?
  6. Jul 7, 2020 at 10:47 PM
    Empty_Lord
    Dan
    since i wont be using the factory cooler in the radiator and we get cold winters. i want to have the trans up to 160 degrees relatively fast. so yea. ideal trans temps are 160-180 for fluid life. the 40,000 gross vehicle weight cooler is complete overkill. so without the t-stat i'd be overcooling the trans
  7. Jul 7, 2020 at 10:49 PM
    Running Board Man
    Running Board Man Well-Known Member
    Tell me how the fluid tstat works i wanted to put one on my tacoma
  8. Jul 7, 2020 at 10:50 PM
    Empty_Lord
    Dan
    its a thermostat... 2 lines in.. 2 lines out.. when the t-stat is closed. it bypasses the output so the fluid just goes back into the trans...
  9. Jul 7, 2020 at 10:51 PM
    Empty_Lord
    Dan
    they're not cheap..
  10. Jul 7, 2020 at 10:52 PM
    Running Board Man
    I know how it works, just like how it operates once installed, like if it actually does a good job regulating temps
  11. Jul 7, 2020 at 10:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I remember that conversation, makes sense.
    Definitely not your guy to rig something like that up; if it were me I'd probably end up putting the transcooler in an area that isn't out and up front like the radiator. It'll allow heatsoak as needed but not remain as hot seeing how it's not attached to a warm radiator.
  12. Jul 7, 2020 at 10:53 PM
    Empty_Lord
    Dan
    it should.. i mean.. ive installed them on old air cooled bugs that had over cooling issues with bigger oil coolers
  13. Jul 7, 2020 at 10:53 PM
    Running Board Man
  14. Jul 7, 2020 at 10:55 PM
    Empty_Lord
    Dan
    trans cooler goes right out front. i dont want to see anything above 190 when towing. so i'll try my best to make sure it doesnt. I might just do hard line to the thermostat and put an AN fitting on the hard line.. then AN hardline out with bundy connectors on the end... make it one unit to remove should i need to... i over think things... alot
  15. Jul 7, 2020 at 10:55 PM
    Empty_Lord
    Dan
  16. Jul 7, 2020 at 11:01 PM
    Running Board Man
    https://youtu.be/YvlujvwNOE8
  17. Jul 7, 2020 at 11:02 PM
    Empty_Lord
    Dan
    i would not trust a ebay knock off t-stat. the catch can? sure. but t-stat. no
  18. Jul 7, 2020 at 11:08 PM
    Running Board Man
    The derale one i linked is made in the usa, wouldnt doubt the mishimoto is overpriced name brand chinese like they did with the catch can
  19. Jul 7, 2020 at 11:13 PM
    Empty_Lord
    Dan
    derale is fine. i have the mishimoto. so why not use it.. i didnt pay for it.. kid doesnt want it.. so fuck it.
  20. Jul 7, 2020 at 11:15 PM
    Running Board Man
    It was free to you, but probably not worth what it costs to us heathen
