  1. Jul 9, 2020 at 9:48 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I figured the res. may be the issue; same part numbers for non-res. coilovers between both vehicles.
  2. Jul 9, 2020 at 9:50 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You've lost sight of the good stuff
  3. Jul 9, 2020 at 9:53 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Thank you for your personal experience, that makes me feel a little better. I'll be sure to jack it up and check em every week :thumbsup:
    Did yours whistle tho? :rofl:
    Running Board Man likes this.
  4. Jul 9, 2020 at 9:53 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    Must resist
    Kwikvette[QUOTED] likes this.
  5. Jul 9, 2020 at 9:54 PM
    Running Board Man
    Running Board Man Well-Known Member
    Nope the 3 holes on top are clocked something like 15 degrees differently
    so the solid aluminum top hat thing coilovers use has to be 4 runner or tacoma specific because theres only soo much misalignment heims can take
    any other shock you just rotate the top hat the right way before releasing the spring because they can rotate 360 degrees on the shock rod
    5100s are the easiest, just stick a screwdriver in the shock bushing and rotate once assymbled and bolted onto the frame cause the spring perch and shock are seperate so you can turn the shock without the spring and top hat moving
  6. Jul 9, 2020 at 9:54 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Always traded mine for the bacon whenever someone got it; never cared for the jalapeño as much.
  7. Jul 9, 2020 at 10:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @cruiserguy
    Since you had asked; I get everything pristine before getting it together.
    Here's the clutch pawl assembly
    Hub cover dial assembly on bottom left; new o ring and gasket
    Inner hub and spacer installed in hub body; that snap ring is a pain in the ass
    All assembled
    I only put one together seeing as how the detent spring on the other manual hub was broken. Ordered one from Yotamasters
  8. Jul 9, 2020 at 10:09 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    That stuff is therapeutic :D
  9. Jul 9, 2020 at 10:10 PM
    Abeyancer
    Jimmie
    PNW
    Beautiful work man! You've inspired me to try and find a used sent and rebuild em myself!
    I still need to find bare spindles to press new bearings and my manual wheel hub thingy
  10. Jul 9, 2020 at 10:20 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Disassembling and cleaning guns does the same for me; since I haven't been shooting for some time, manual hubs will have to do :cool:
    cruiserguy[QUOTED] likes this.
  11. Jul 9, 2020 at 10:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh they're super easy.
    It's just a bit of a pain getting them all cleaned up, especially if the o ring failed and the grease inside is contaminated.
    Only parts you can media blast are the hub cover and dial which I get done so I can paint them.
  12. Jul 9, 2020 at 10:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Abeyancer
    You can use Prerunner spindles as well since they're identical to 4x4 spindles; you'll just use your own axle hub to make it work with the manual cv axles.
    Only difference you'll find is some have the tab for abs whereas others don't.
    04Pre_Runner likes this.
  13. Jul 9, 2020 at 10:31 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I thought using snap rings were impossible till I realized I was using the wrong pliers.
    You’ve got snap ring pliers for snap rings with holes in them, you’re supposed to use Lock Ring Pliers.
    Stanley Proto J250G Proto 9-Inch Lock Ring Horseshoe Washer Pliers https://www.amazon.com/dp/B00209ETSS/ref=cm_sw_r_cp_api_i_L0.bFbCPR0W3P
  14. Jul 9, 2020 at 10:32 PM
    Running Board Man
    @Speedytech7 theres an 800 dollar 2000 lexus 300 auto with A 2jz is it worth it as car
    Runs drives has a title
  15. Jul 9, 2020 at 10:32 PM
    Abeyancer
    Jimmie
    PNW
    Oh fuck yea! That'll help widen the search thank you :thumbsup:
    If I dont have an ABS idiot light then I don't have ABS correct? While I was changing ball joints today I didn't see a sensor... but then again I wasn't looking
  16. Jul 9, 2020 at 10:33 PM
    Running Board Man
    You likely dont have it
    Abeyancer[QUOTED] likes this.
  17. Jul 9, 2020 at 10:37 PM
    Abeyancer
    Jimmie
    PNW
    There's never anything in junk yard around here :annoyed:
  18. Jul 9, 2020 at 10:39 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Wow, that’s pretty bad. I’ve seen FAR more intact ones come up here.
  19. Jul 9, 2020 at 10:40 PM
    Abeyancer
    Jimmie
    PNW
    That was with a 250 mile radius picked from my zip code lol I usually check every 2 or 3 days and nothing comes up... or it's always a 2wd if it does
  20. Jul 9, 2020 at 10:41 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Oh the trucks that pop up here are always 5-lugs. But every now and then a 4WD will appear. Rare though.
