  1. Jul 26, 2020 at 12:41 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I heard it depends on what department you are in. Some are slave drivers, other departments it seems pretty laid back. Their base pay isnt really that great, they load you up with sign on bonuses and stock options that vest overtime to get you to stay. I interviewed with Amazon air, they went with someone else who had less qualifications, their loss.
    esxcli and 0xDEADBEEF[QUOTED] like this.
  2. Jul 26, 2020 at 1:03 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    The closest I can relate is a post on installing rear LC upper and lower control arms. I'm going to be doing this in a couple of weeks when the new adjustable types arrive.
    I want to install these and test articulation and adjust to remove any binding before I install the new rear springs. Trail Tailor is out of Panhard rods at the moment. So I'll be starting off with the old ones.
    I wish I had more to offer today. I should know more in a couple of weeks.
    https://forum.ih8mud.com/threads/rear-upper-and-lower-control-arms.520027/
    I understand with a 3" lift the rear lowers should be run out 3/4 of an inch.
    Uppers..
    cruiserguy and Kwikvette[QUOTED] like this.
  3. Jul 26, 2020 at 1:21 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That looks like a sharp setup as well.
    In my situation, not having the vehicle in my possession really limits me but I know this much;
    2" of lift limits the coil I'll run in the back; I don't want to run 3"-4" like most do because that'd mean I would have to preload the front coilovers quite a bit to get to that height up front.
    Next, the coil I plan on using is an OME 906 since they apparently ride better, being progressive, versus the Dobinson C59-131 which offer the same lift. Dobinson springs are linear.
    A 22.37" extended shock length will provide enough droop to allow the OME spring to fall out; Dan suggested limit straps but I may just find a way to keep the coil in place instead.
    With the above setup, the link kit sounds like a waste of money almost but it's not very expensive anyway. Plus if I prevent the coils from falling out I can make use of the full droop the rear shocks will offer.
    You might get your setup before I get started on mine; would love to see before and after articulation shots if you can!
    CS_AR[QUOTED] likes this.
  4. Jul 26, 2020 at 1:38 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    INB4 @Running Board Man says junkyard LC springs and tundra or LC used shocks :luvya:
  5. Jul 26, 2020 at 2:02 PM
    Running Board Man
    Running Board Man Well-Known Member
    Just wore upfront a bomb nap
  6. Jul 26, 2020 at 2:05 PM
    Running Board Man
    Fj cruiser springs seem like what you're looking for, I ran them it was about 2 inches of lift and rode great, Soo much nicer than stock or landcruiser springs
    The ass end on these trucks is very unstable driving around when you go higher
  7. Jul 26, 2020 at 2:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Actually the Dobinson should be the better choice being that they are 15.5" in length for the droop issue.
    FJ Cruiser springs are 14.88" in length and the OME are 14.96" in length.
    But yes you are correct that FJC can be used, I just wish to discard the idea.
    Btw, I'll wait until you want to get rid of those Solo LCA's for cheap. ;)
  8. Jul 26, 2020 at 2:23 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I already dibbed
    Running Board Man likes this.
  9. Jul 26, 2020 at 2:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I dibbed before that dib :burp:
  10. Jul 26, 2020 at 2:24 PM
    JKO1998
    Utah
    False
  11. Jul 26, 2020 at 2:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    We could bet
    Just need to look at our post history here :rofl:
    I win, I get James solos and one of your photographs you've got up for sale.
    You win, you get James solos and some gun ammo or accessories
  12. Jul 26, 2020 at 2:26 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    @Sperrunner thats smart, its something thats not viable to ship here.... Will check sears/craigslist/marketplace too.
    On a sidebar its raining like vietnam, hurricane should be next to maui around 2pm.
    IS IT TIME TO FINALLY TAKE THE 4wd FOR ROOSTERTAILS?
    Sperrunner and Running Board Man like this.
  13. Jul 26, 2020 at 2:27 PM
    JKO1998
    Utah
    How bout I just share my photo album with you And I get LCAS
  14. Jul 26, 2020 at 2:28 PM
    slander
    Hickory, NC
    Inb4 "shit I think I hydro locked my motor"
    0xDEADBEEF and esxcli like this.
  15. Jul 26, 2020 at 2:28 PM
    JKO1998
    Utah
    Wat
  16. Jul 26, 2020 at 2:28 PM
    Sebz13
    Shane
    Maui Hawaii
    haha yeah fuck that, going to go get coffee and drive around for a bit to see it.
  17. Jul 26, 2020 at 2:29 PM
    Running Board Man
    My houses street is under 4 ft of water
  18. Jul 26, 2020 at 2:29 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Fify
    slander[QUOTED] likes this.
  19. Jul 26, 2020 at 2:30 PM
    Sebz13
    Shane
    Maui Hawaii
    Luckly my house is on a hill, only needed to sandbag garage.
    Watched through all the episodes of this, the mad lad is making his own wiring harness.
    https://www.youtube.com/watch?v=dNhZ_aP467c&t=384s
  20. Jul 26, 2020 at 2:31 PM
    CS_AR
    Will do.. Here's the kit that I will be installing. I'll be going with a steel rear bumper and drawer unit, will carry lots of tools.
    cruiserguy and Running Board Man like this.
