  1. Aug 3, 2020 at 9:07 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    No thats probs rubber from the spark plug socket grommet. I sprayed it off and cleaned it, then tried to re put it in the fuel rail and the oring fell apart at the seal. I was wondering if all that debris would cause my missfire symptoms
  2. Aug 3, 2020 at 9:08 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Lemme get it running first
  3. Aug 3, 2020 at 9:08 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Running good that is
  4. Aug 3, 2020 at 9:09 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Ah ok. Probably not. Seems like the debris would be a symptom more than a cause. Any chance you've got an intake valve that isn't closing all the way? Thats all I can think of.
    Das it mang[QUOTED] likes this.
  5. Aug 3, 2020 at 9:09 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Have a set like this. They usually run 5 loads a day.
  6. Aug 3, 2020 at 9:10 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    If you get a 2 cylinder engine you cant have a misfire in cylinder #3
  7. Aug 3, 2020 at 9:10 PM
    0xDEADBEEF
    Whats the specs on one of those?
    And why the runway lights?
    Kwikvette likes this.
  8. Aug 3, 2020 at 9:13 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    runway lights help at night loading a car. you never think youd use them.. but the few trailers ive loaded cars onto with them its actually awesome
  9. Aug 3, 2020 at 9:15 PM
    0xDEADBEEF
    That makes sense. I'm not a hardcore(?) trailer guy, so I usually load in the daylight. :laughing:
  10. Aug 3, 2020 at 9:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    xtremewlr likes this.
  11. Aug 3, 2020 at 9:17 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    The only time I've ever noticed anything wrong is when the grommets or orings have gone bad and it's leaking fuel. I've also never done that 9v battery trick wulf shared with you awhile ago, I would do that while you have it out and before you swap injectors. That way if it was just debris or something and it runs good and the code doesn't follow then you won't have to take it apart again. It'll also tell you that if it follows the injector itself is crud and clean all 4 professionally (or buy new if you can afford it) and if it stays in cyl 3 then you've got bigger more internal problems
    Das it mang likes this.
  12. Aug 3, 2020 at 9:17 PM
    Empty_Lord
    Dan
    i'll be on in 10-15
    the tundra was a fun one loading it up at 2 am one night to get it ready to get to the dealer to do the original rack it up and figure out what i need
    then the cross wind out in the middle of nowhere i felt like the fucking truck was going to blow over!
    0xDEADBEEF[QUOTED] likes this.
  13. Aug 3, 2020 at 9:20 PM
    Abeyancer
    Jimmie
    PNW
    Damn, sorry I was so late with my response earlier.
    Ebay
  14. Aug 3, 2020 at 9:25 PM
    Empty_Lord
    Dan
    scratch me getting on. woman decided shes not going in to work tonight. sowie.
  15. Aug 3, 2020 at 9:26 PM
    Abeyancer
    Jimmie
    PNW
    I knew what black dog meant with the boats but I'm sooo glad you brought those up, I used to take those honda "360 degree" motors from the scrap pile at work when they'd show up on dead tillers (the gearbox craps out before the engine ever does... unless it's run out of oil) I used those motors for all sorts of weird projects.... you want margaritas in the middle of the woods, cool here's a gas powered blender :D
    A motorized drift trike was my favorite... cut a bike in pieces weld a straight axle where the back tire used to be and put pvc pipes on the back lawnmower tires.
    cruiserguy[QUOTED] likes this.
  16. Aug 3, 2020 at 9:54 PM
    Running Board Man
    Running Board Man Well-Known Member
    Working on my camry is always a pain
    cruiserguy and 04Pre_Runner like this.
  17. Aug 3, 2020 at 9:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No worries, we placed 2nd.
    Got some crazy kills captured :rofl:
  18. Aug 3, 2020 at 10:03 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    I have something wrong with me, so operation 3rd gen 4Runner front end is in progress. Core support barely fit in my double cab bed. @Empty_Lord The salvage yard didn't sell that long bed 3.4 Tundra and have started parting it out. So I guess the title is destroyed now. Also found what appears to be a 70s Yota Chinook in the back of the yard.
  19. Aug 3, 2020 at 10:06 PM
    Running Board Man
    I threw all the bolts for everything into a 4 runner hub cap, wish me luck putting it back together
    cruiserguy likes this.
  20. Aug 3, 2020 at 10:16 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Worst case you end up with extra parts :laughing:
