  1. Aug 5, 2020 at 8:35 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Yes. But it’s not silicon based
    xtremewlr[QUOTED] likes this.
  2. Aug 5, 2020 at 8:35 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    3 years is the typical, that or after you suspect water ingress
  3. Aug 5, 2020 at 8:37 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yeah that's a way to play too, as kids in the 80s and especially like on family road trips, whoever got jinxed had to stay silent until their name was said by somebody
    Wulf and Abeyancer[QUOTED] like this.
  4. Aug 5, 2020 at 8:38 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    I need to do this on the 4R. Fluid in the reservoir is pretty dark and I have no idea when the system was last serviced. Also need to replace all the rubber brake lines with braided hose.
    Running Board Man likes this.
  5. Aug 5, 2020 at 8:42 AM
    Wulf
    rock raisin
    I need to start buying gear for elk season so I can break it in
    High Noon and Das it mang like this.
  6. Aug 5, 2020 at 8:42 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    It's definitely time for me as well.. i got a real spongy brake feel. Thinking of being preemptive and buying the extended SS lines cause ill probably do the lift kit in the winter.
    Can you run extended length brakes lines without a lift installed or is gonna get caught on something and possibly get torn out?
  7. Aug 5, 2020 at 8:42 AM
    Abeyancer
    Jimmie
    PNW
    Don't forget your pantyhose
    High Noon likes this.
  8. Aug 5, 2020 at 8:43 AM
    Empty_Lord
    Dan
    Use the scan tool to do the rear brakes.
  9. Aug 5, 2020 at 8:43 AM
    cruiserguy
    Elijah
    SEKS
    So when I was first learning the forum, after I learned about the email notification setting and changed it, the threads that I had responded in or watched PRIOR to changing the setting still sent me a notification that there was a new post in the thread.
    And I still get an email notification if one of those old threads get necro'ed. Only a couple of them though before I learned of the setting......
    Imagine getting an email notice for each post in this lunchtable thread!!
  10. Aug 5, 2020 at 8:43 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Black means its working
    Running Board Man and Empty_Lord like this.
  11. Aug 5, 2020 at 8:44 AM
    Empty_Lord
    Dan
    I have a joke for that but it’ll get me banned
  12. Aug 5, 2020 at 8:44 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Probably need your guidance on that.
  13. Aug 5, 2020 at 8:45 AM
    Empty_Lord
    Dan
    It’s under ABS. Utility and brake blee. It’ll guide you through it
    High Noon and xtremewlr[QUOTED] like this.
  14. Aug 5, 2020 at 8:45 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    My brakes are working fine, I just don't know the service history on them.
    Yes you can. Just use zip-ties to keep them out of harms way.
    Abeyancer[QUOTED] likes this.
  15. Aug 5, 2020 at 8:46 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I'll take a peek this weekend.
    Empty_Lord[QUOTED] likes this.
  16. Aug 5, 2020 at 8:47 AM
    Wulf
    rock raisin
    stay strapped or get clapped
  17. Aug 5, 2020 at 8:47 AM
    Empty_Lord
    Dan
    You know how to reach me. Basically the abs pump pumps the fluid out the bleeder. If you try to do it normal you end up with an air pocket because of the valves in the pump being closed
  18. Aug 5, 2020 at 8:47 AM
    Empty_Lord
    Dan
    The fronts can be done normal
  19. Aug 5, 2020 at 8:48 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    So funny i can spy on them from the bedroom now. Was watching him this morning lol
    CS_AR likes this.
  20. Aug 5, 2020 at 8:52 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Cool.
    I was a bit intimidated by this system because of the funky pump on it but didn't realize it was only for the rears. Also annoying that most brake line kits are only 4 lines whereas there are 6 rubber lines in the system. The rear calipers have a rubber line each, not just the lines running to the axle hard lines. Guess I'll have to determine length and connection to replace the 2 rear caliper lines.
