  1. Aug 9, 2020 at 1:10 AM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    So you're running a 2.7 4Runner, 3.4 4Runner and that Camry now? What a fleet.
  2. Aug 9, 2020 at 1:31 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    What type of injectors are you finding to be more modern?
    I've seen some green Camry injectors recommended to replace the Brown Aisan injectors that come on 3.4L with a slightly higher CC volume.
    I've upgraded injectors on Nissans to use more modern injectors with more offices while staying with the same CC.
    There is a very lengthy thread on MUD about the difference between 4 hole to 12 hole injector performance.
    https://forum.ih8mud.com/threads/12-hole-injector-upgrade-finally-tested.1192988/
    For a 1993 LC, I did find that Rock Auto is selling new Intermotor FJ375 injectors for $135.79 each. New OEM Toyota (23209-74080) at Partsouq is $140.63
    No real difference in price between Intermotor (reboxed) and OEM in price.
    I'm at a similar crossroad with my 100 series injectors. I want to clean up the intake and service the injectors. Though I'm not crazy about servicing (cleaning, o-rings, and screens) injectors with 235,000 miles. Though I might do it. I can get new Intermotors for $91.79 each.
    https://www.rockauto.com/en/moreinfo.php?pk=443921&cc=1276668&jsn=826&jsn=826&jsn=826
  3. Aug 9, 2020 at 6:03 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Woke up to a 5.1 mag earthquake this morning. Didnt know what the hell was happening haha.
    Largest in NC in over 100 years.
  4. Aug 9, 2020 at 6:39 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    I was wiped out from Friday night and waking up at 5:30am yesterday, then spending all day working on the body lift. I called it quits at 9:45 last night.
  5. Aug 9, 2020 at 6:47 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    When I did the intake on the 4R, I swapped injectors from the stock 4 hole to 12 hole. I haven't really seen that much of an improvement in gas mileage and my driving habits are the same. It does run great and I know performance has improved but I couldn't tell you it was from the injectors or not since the manifold swap alone also improves performance. @Empty_Lord and I determined they were from a Solara or something like that. They are pink injectors, Toyota part # 23250-0A020.
    CS_AR[QUOTED] likes this.
  6. Aug 9, 2020 at 6:54 AM
    CS_AR
    Thanks Todd. I would like to do the 4.7 intake manifold swap like you to reduce heat transfer. Though I don't know what I'm getting into on that with a 99 model.
    xtremewlr[QUOTED] likes this.
  7. Aug 9, 2020 at 6:55 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
  8. Aug 9, 2020 at 8:38 AM
    Running Board Man
    Running Board Man Well-Known Member
    I after I make the 98 4 runner 4x4 with Tacoma parts than I can scrap it... There won't be anything left but a bent frame and bad body considering swapping the dash from the Tacoma to the 4 runner because I liked it
    04Pre_Runner[QUOTED] and CS_AR like this.
  9. Aug 9, 2020 at 8:50 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    my current fleet is a 2001 tacoma in pieces, half another tacoma, my 06 avalon, the 05 tundra, an 10 ford escpae, and a 2000 camry 2.2..... oh and the heep.
    04Pre_Runner[QUOTED] likes this.
  10. Aug 9, 2020 at 8:51 AM
    Empty_Lord
    Dan
    keith from dirty deeds industries is the guy to talk to.
    CS_AR[QUOTED] and xtremewlr like this.
  11. Aug 9, 2020 at 9:01 AM
    Running Board Man
    Question about the 2.2 Camry when timing it
    I didn't see a mark on the crank gear or shaft only the mark on the harmonic balancer and timing cover
    Is there one beneth the timing cover or do we just set it tdc at the ballancer than don't move it
    I believe I moved the crank when putting the belt on so I'm going to redo it as my mpg took a hit after that job
    Just wanted to know if there was a timing mark there or if I'm supposed to set it at tdc with the harmonic balancer than try my best to not move it
  12. Aug 9, 2020 at 9:06 AM
    Empty_Lord
    Dan
  13. Aug 9, 2020 at 9:06 AM
    cruiserguy
    Elijah
    SEKS
    @Wulf so you got any video clips of your crawler in action man?!
    You're such a tease, you just wanna hear us beg for it huh? :wink::rofl::D
    Wulf likes this.
  14. Aug 9, 2020 at 9:06 AM
    Empty_Lord
    Dan
    if your belt was a tooth off you'll have a check engine light
    Running Board Man likes this.
  15. Aug 9, 2020 at 9:09 AM
    RapidRoy
    RapidRoy Well-Known Member
    1999 3.4L SR5 4WD MT
    I didn't know this. I've always thought the vehicles I've driven with Bilstein shocks were harsh. I just looked on the Toyota TRD site and there don't appear to be any TRD parts available for a 1999. Is there somewhere these are available or some kind of aftermarket equivalent?
  16. Aug 9, 2020 at 9:10 AM
    cruiserguy
    Elijah
    SEKS
    That could be a tough mark to see if you don't know what you're looking for, especially FWD mounted. But I've learned there is ALWAYS a reference mark
  17. Aug 9, 2020 at 9:11 AM
    Empty_Lord
    Dan
    tell ya the honest truth.. i get FWD belts done quicker than the trucks....
  18. Aug 9, 2020 at 9:12 AM
    Running Board Man
    Amazing resource
  19. Aug 9, 2020 at 9:15 AM
    Running Board Man
    the mark would be clearly visible if it weren't coated in oil leak residue
    cruiserguy[QUOTED] likes this.
  20. Aug 9, 2020 at 9:17 AM
    cruiserguy
    Elijah
    SEKS
    Even the V6 FWD ones? Or that doesn't affect the amount of time it takes really?
    Which timing belt job(Toyota) has been the worst that you've had to deal with so far?
