  1. Aug 9, 2020 at 1:55 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    No, this mount he sent me.
    But if you have the blanks that go in the lower center console piece in the newer trucks lemme know
  2. Aug 9, 2020 at 1:55 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm at the range for the first time in over a decade.
    Sperrunner likes this.
  3. Aug 9, 2020 at 1:57 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Ill have to take a look. I think i have a few of those panels at the shop. But idk if they are the ones you need
    JKO1998[QUOTED] likes this.
  4. Aug 9, 2020 at 1:57 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I thought you despised guns
  5. Aug 9, 2020 at 1:59 PM
    Speedytech7
    No, I'm indifferent. I think it's fun to shoot every once in a while but I've got better stuff to waste my money on. If other people wanna piss away money assembling their fourteenth AR, so be it. I think they're a boring topic to talk about, so I don't talk about them much
  6. Aug 9, 2020 at 2:01 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    You can’t bolt a winch to rust
    Kwikvette likes this.
  7. Aug 9, 2020 at 2:02 PM
    Wulf
    rock raisin
    Yep, I shouldn't be surprised but I didn't even think twice about the idea of a filter kit being junk when I ordered it.
    Guess I will have to order from one of the other actual dealers next time.
  8. Aug 9, 2020 at 2:03 PM
    JKO1998
    Utah
    Guess we’re getting a couple cow elk tags.
    so I’ll have a deer and 3 elk tags, too much work
    Sperrunner, Wulf and Speedytech7[OP] like this.
  9. Aug 9, 2020 at 2:03 PM
    Wulf
    rock raisin
    Speaking of junk filters I bought a Toyota filter for the truggy to replace the STP one I just put on. It came with one of those oil change deals and figured it would be fine for an old 22r. Wrong.
    Engine knocks on startup now til the oil flows again
  10. Aug 9, 2020 at 2:03 PM
    Wulf
    rock raisin
    I put in for cow first and bull as second choice. Got another bull tag :bananadead:
  11. Aug 9, 2020 at 2:22 PM
    Running Board Man
    Running Board Man Well-Known Member
    Just delete them
  12. Aug 9, 2020 at 2:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Last thing I want in CA is a higher tax expense :frusty:
  13. Aug 9, 2020 at 2:23 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    LOLWUT
    That's going into the 4R :boink:
  14. Aug 9, 2020 at 2:23 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Sounds like you need an oil pump?
  15. Aug 9, 2020 at 2:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's the problem; gun enthusiasts don't care for AR's
    cruiserguy likes this.
  16. Aug 9, 2020 at 2:26 PM
    JKO1998
    Utah
    Woot for private land permits
    High Noon likes this.
  17. Aug 9, 2020 at 2:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  18. Aug 9, 2020 at 2:29 PM
    Abeyancer
    Jimmie
    PNW
    I used to be all about deleting shit I didn't like in vehicles... like EGRs and punching out the CAT but as I get older I care for that approach less and less.
    From what I've read its more effort than it's worth to delete that airbag switch
  19. Aug 9, 2020 at 2:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @JKO1998
    White is constant +12V, which connects to pin #2 on the switch.
    Blue is from your lights/relay, and connects to pin #3 on the switch.
    I opted to wire in an "Add A Circuit" coming from the fuse panel under the driver dash. I chose "IGN", which means, this tap will receive +12V whenever a key is in the ignition. This way, whenever the vehicle is on, my switch will light up as it's connected to pin #8 on the switch.
    Black is negative, which connects to pin #7 on the switch.
    Old pictures of the setup while lights off
    Setup with lights on
  20. Aug 9, 2020 at 2:33 PM
    eon_blue
    Azusa, CA
    Noooo
    It's just gonna sit in his garage for 2 years :annoyed:
    Sperrunner and Kwikvette[QUOTED] like this.
