  1. Aug 10, 2020 at 9:23 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    also truck nuts
    I sent that for both you and your fiance...... @BartMaster1234
  2. Aug 10, 2020 at 9:23 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    You need help
  3. Aug 10, 2020 at 9:24 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    You need a sense of humor
  4. Aug 10, 2020 at 9:28 PM
    esxcli
    esxcli Keyboard Warrior
    Sean
    Reno NV
    Bruhhhhhhhh. My carpet was nasty.
    I pulled the passenger panels to half ass push out that dent. Carpet smells like old person.
    Pulled that shit out too.
    Wulf, BartMaster1234, CS_AR and 2 others like this.
  5. Aug 10, 2020 at 9:31 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Dents add character
    esxcli[QUOTED] likes this.
  6. Aug 10, 2020 at 9:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Uhm....:luvya:
  7. Aug 10, 2020 at 9:47 PM
    esxcli
    Sean
    Reno NV
    Mothballs and mildew is not a great smell.
  8. Aug 10, 2020 at 9:47 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    I just spent like 30 minutes pressure washing the underside lol
    Sperrunner[QUOTED] and esxcli like this.
  9. Aug 10, 2020 at 10:22 PM
    esxcli
    Sean
    Reno NV
    Wulf, xtremewlr, CS_AR and 2 others like this.
  10. Aug 10, 2020 at 10:45 PM
    Sebz13
    Shane
    Maui Hawaii
    Swapping in the new gas tank and straps on Wednesday. Gonna paint the gas tank skid too while I’m under there.
    CS_AR, cruiserguy and 04Pre_Runner like this.
  11. Aug 10, 2020 at 11:24 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    @Black DOG Lila
    It's so hard to tell when your serious but you asked a question I love to answer and have had to do so many times its rehearsal is second only to my small engine ethanol speel
    For the sake of keeping this post shorter than it can be almost all small 4stroke engine decompression valves regardless of manufacturer function with this principle:
    The mechanism on the base of your camshaft is spring loaded and the pin you see to the left (in normal operation) rides at the top of the lobe in order to keep the exhaust valve lifted only during start up to make it easier. The tension on the spring is such that after it starts and is spinning at full operational rpms the weight of the mechanism flings the pin out of the way and the exhaust valve can close completely.
    The reason I attached that particular picture is because some wahoo at Briggs decided for cost cutting measures they'll do away from casting then grinding the lobes as a complete cam and instead turn and spline the shaft and press the cams on after the fact. I've had to warranty countless camshafts because some monkey at the factory would assemble the cams just a few splines off and the exhaust couldn't decompress and the under powered starters wouldn't be able to overcome the initial compression stroke
    Here's a picture of an older style engine that shows the decompression mechanism better as well as what a quality cast and ground camshaft should look like.
    @cruiserguy I know you'll get a kick out this info as well
  12. Aug 10, 2020 at 11:27 PM
    Abeyancer
    Jimmie
    PNW
    back in the 70 and 80s for American made small engines the decompression function was taken care of by an extra little nub on the tip of the exhaust lobe and sure that allowed it to start much easier but it was always open so they really polluted like a 2 stroke. Honda came along in 84 (... I think?) And changed the small engine game completely!
  13. Aug 10, 2020 at 11:38 PM
    Wulf
    rock raisin
  14. Aug 10, 2020 at 11:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The fuck :rofl:
    what road likes this.
  15. Aug 10, 2020 at 11:44 PM
    Wulf
    rock raisin
  16. Aug 10, 2020 at 11:48 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  17. Aug 11, 2020 at 12:06 AM
    Wulf
    rock raisin
    Sperrunner, cruiserguy and what road like this.
  18. Aug 11, 2020 at 12:15 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Seriously lol
    cruiserguy likes this.
  19. Aug 11, 2020 at 2:28 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Dude that's great, very well written. Decompression valve is the word I couldn't remember. I read about it when I was looking up adjusting the valves for that Honda washer engine. I still don't grasp it entirely but have a much better picture of it....
    But bruh the cams are set in place with those splines and a set screw?!?! :eek:
  20. Aug 11, 2020 at 5:02 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
