  1. Aug 11, 2020 at 10:19 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Hint, it isn't supposed to have a trans pan gasket
  2. Aug 11, 2020 at 10:21 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    S/O to @Kwikvette for the new Winch I can use to get myself over the parking barriers when I need to go to Macy’s :luvya:
    I also had the chance to use my Vintage Swingline industrial staple remover:
  3. Aug 11, 2020 at 10:21 PM
    Running Board Man
    Running Board Man Well-Known Member
    I know it's supposed I have the correct rtv, but I'm lazy... the only reason the last one leaked was because all the bolts were finger tight I was loostening them with my fingers on a socket... Probably why one bolt walked itself out
  4. Aug 11, 2020 at 10:22 PM
    Speedytech7
    @Kwikvette you shoulda hit that cable with a vinegar and salt spray before you gave it to him
  5. Aug 11, 2020 at 10:23 PM
    Speedytech7
    If the pan isn't made for a rubber gasket, it's not BTW, it's gonna leak with one cause it can't apply the pressure everywhere. Notice the indent around the perimeter on the pan
  6. Aug 11, 2020 at 10:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That Winch looks badass :drool:
  7. Aug 11, 2020 at 10:25 PM
    Running Board Man
    Meh, we'll see I would think that indent around the entire pan would make a better deal against the *rubber* gasket
    I didn't get a quark or paper gasket I got a rubber one figured it would deform and create a good enough seal
    Shitll be fine
  8. Aug 11, 2020 at 10:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @eon_blue said give it 2 years before it gets installed :anonymous:
    what road likes this.
  9. Aug 11, 2020 at 10:31 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    what leak?
    huh? the camry has a cork/rubber gasket from the factory.
  10. Aug 11, 2020 at 10:32 PM
    Empty_Lord
    Dan
    oh.. 4runner yea.. no gasket.
  11. Aug 11, 2020 at 10:37 PM
    Running Board Man
    The Camry had an oil leak changing out the oil pump housing gasket, oil pump shaft seal, oil pump gasket with some black rtv, oil pan gasket out of rtv and front main seal and there were still puddles under it
    Checked it out again the trans pan had a missing bolt and was saturated but my care for the car ran out
    I drove the 4 runner I also noticed it had red atf and black oil leaking out of it as well
    :sadviolin:
  12. Aug 11, 2020 at 10:38 PM
    Empty_Lord
    Dan
    oh. if the thing had the leak at the back of the valve cover i was going to say is the head plug and the semi circle.. theyre famous for that.. oil pump Oring is famous for leaking too.
  13. Aug 11, 2020 at 10:41 PM
    Running Board Man
    I've removed, cleaned, and put black permatex rtv on the cam half moon things because the guy before me used permatex grey (on everything they could have) which isn't meant for oil contact so it all got brittle and leaked
    Just sucks to have to work on a shitty car I don't care about furthermore fix someone's mistake
    Only to have it still leak (atf this time)
    But with the engine oil leak fixed and trans pan gasket on let's hope I can move on with more noticeable fixes like control arms/cvs
    Maybe even progress down the checklist to painting it
  14. Aug 11, 2020 at 10:43 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    If you decide not to use it I'll take it off your hands.
    Running Board Man likes this.
  15. Aug 11, 2020 at 10:45 PM
    Empty_Lord
    Dan
    i think everyone here has called dibs on that only for the one guy that will literally never use it, buy it
    then the first time he needs it the solenoid will be shot because he never used it.
    Tour991[QUOTED] and Kwikvette like this.
  16. Aug 11, 2020 at 10:49 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Could be worse; could've posted it for sale in the marketplace for more money :luvya:
  17. Aug 11, 2020 at 10:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Forgot I have a bunch of extra frozen shrimp
    Tour991, what road and 04Pre_Runner like this.
  18. Aug 11, 2020 at 11:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Running Board Man
    Still waiting for you to dump those Solo LCAs
    I don't need them, just want them...
  19. Aug 11, 2020 at 11:06 PM
    Running Board Man
    What do you value them at?
    They'd look good with all the other money you're throwing at it
  20. Aug 11, 2020 at 11:07 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Are they really? I bet with enough practice trying to read that i could teach myself Spanish.
    Then this happens
