  1. Aug 17, 2020 at 9:06 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I changed the air filter on my DD 1999 camry one day and found a few chicken bones in the airbox WTF!! Our 2015 Camry, that was driven evreyday and kept in a garage had a massive mouse nest under the engine cover as well, popping that thing off is now part of my oil change routine. Funny part is, no rodents in my tacoma that gets driven less than 5000 miles a year these days, must be the smell of gear lube that has soaked into the cab along with evreything under the hood being covered in powersteering fluid.
    Abeyancer[QUOTED] likes this.
  2. Aug 17, 2020 at 9:08 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    the 35/36 mm depends on whether the nut is factory or aftermarket
    what road likes this.
  3. Aug 17, 2020 at 9:09 AM
    eon_blue
    Azusa, CA
    I guess I haven't run into an aftermarket one that required a 36 yet but at least I have both now just in case lol
  4. Aug 17, 2020 at 9:14 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just buy the socket and replace it!
    what road[QUOTED] likes this.
  5. Aug 17, 2020 at 9:15 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    Inner broke and outer lol. Outer broke when I turned to sharp and inner gave way when I tried to get it on flat ground.
  6. Aug 17, 2020 at 9:15 AM
    eon_blue
    Azusa, CA
    wtf were you driving around the parking lot in 4lo or what, lol
  7. Aug 17, 2020 at 9:16 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Mall crawlin' :burnrubber:
  8. Aug 17, 2020 at 9:16 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Drive shaft was coming in and had to drive around in 4hi
  9. Aug 17, 2020 at 9:17 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Only the most extreme crawling of malls
  10. Aug 17, 2020 at 9:18 AM
    eon_blue
    Azusa, CA
    Oooooh...but you didn't have a rear driveshaft in when the CV broke? weird, guess it was already on it's way out.
    Yeah I can see your issue now...if you're only relying on the front driveshaft to get around then you're SOL if you busted a front axle.
    not really anything you can do that I can think of except replace it where it is, or get it towed somewhere.
  11. Aug 17, 2020 at 9:18 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Do you have to undo the uca as well? Never done this. Go ahead and make fun of me
  12. Aug 17, 2020 at 9:19 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    It's on flat ground now just the one socket I don't have
  13. Aug 17, 2020 at 9:21 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    It ain't hard getting the spindle undone to get to where the CV would be. I just feel like you might run into some rusted bolts.
    May as well get your LT kit installed since its one of those "you're already there" kind of things
  14. Aug 17, 2020 at 9:23 AM
    eon_blue
    Azusa, CA
    Nope, just have to unzip the axle nut then undo the 4 lower ball joint bolts so you can swing the spindle out of the way. Pop the old cv out using a pry bar between the CV and the diff. Put new CV in with C-clip facing down (?) as far as you can by hand.
    Thread the axle nut on to the new CV then hammer it in the rest of the way. Put spindle back into place and bolt in the LBJ again. Replace any front diff gear oil that spilled out
    axle nut torque is 174 ft/lbs, lbj bolts 59 ft/lbs
  15. Aug 17, 2020 at 9:25 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Like broke broke?
  16. Aug 17, 2020 at 9:26 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Ok, I got to go to O'Reilly's later for the tools. And red loctite for lbj bolts yea?
  17. Aug 17, 2020 at 9:26 AM
    eon_blue
    Azusa, CA
    blue unless you want to torch those fuckers next time you need to break them loose lol
    Kwikvette likes this.
  18. Aug 17, 2020 at 9:27 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Yea, swings around like tarzan
  19. Aug 17, 2020 at 9:27 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Lol ok blue it is
  20. Aug 17, 2020 at 9:29 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    What size is the bolt for the front diff?
