  1. Aug 22, 2020 at 7:27 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    @Empty_Lord, just thinking about this as someone posted the question on the 4runner forums.
    If I had a bearing failure or some other catastrophic failure with my 2uz, could I just drop in a later model VVTi motor using my existing ECU? I'd probably get the motor wiring harness just because mine has broken clips but could I other wise just drop the later motor in place and be good?
    My thought is yes, it would work just fine.
  2. Aug 22, 2020 at 8:07 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Small business. One main PC that was being manually backed to media and carried offsite. I agree about local NAS storage. It needs some type of off-premise backup.
    I have a buddy who's business caught fire back and quickly burned to the ground one day while everyone was there working one day. Everybody ran out and left the computer backup disks in the office. They lost all accounts receivable records. There was a month old backup at a software developers' place that saved them from completely going under.
    I need to help resolve this one quickly.
  3. Aug 22, 2020 at 8:24 AM
    Running Board Man
    Running Board Man Well-Known Member
    Firm no if it's anything like the cable/ethrottle 5vzfe
    You'd need to swap sensors and such over from the old one onto the new one
    That's because I didn't look at the transmission differences in my scenario
  4. Aug 22, 2020 at 8:27 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    LS swap, 40s and tons
  5. Aug 22, 2020 at 8:28 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yeah, I'd recommend crashplan or backblaze then for secure cloud storage. My choice would be crashplan since I have used them before and they support Linux, along with Mac and Windows.
    CS_AR[QUOTED] likes this.
  6. Aug 22, 2020 at 8:33 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    It's an e-throttle. I already know that the throttle bodies are compatible since I am running the VVT intake with a 2006 throttle body on my 2003. Wiring harness lengths are a little different, with the earlier non-VVT like mine being shorter at the throttle body but all you do is run the TB upside down and it plugs in just like original.
    Transmission is the same, so no worries there.
  7. Aug 22, 2020 at 8:38 AM
    Running Board Man
    I wonder what the vvti phasers are doing, if the engine was at full advance or retard when you pulled it will it stay there as your computer can't control it
    Maybe it would give you a code because it thinks the cams are off timing
  8. Aug 22, 2020 at 8:38 AM
    CS_AR
    Double trouble for the ArkLaTex. Dueling storms. This is a record. I'll have plenty of mud holes and creeks to traverse now. Not looking forward to seeing the disasters down south.
  9. Aug 22, 2020 at 8:38 AM
    Running Board Man
    Louisiana: fucked
  10. Aug 22, 2020 at 8:39 AM
    CS_AR
    Yep.
  11. Aug 22, 2020 at 8:40 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    It's a boot, they can just walk it off.
    what road likes this.
  12. Aug 22, 2020 at 8:45 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  13. Aug 22, 2020 at 9:08 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
  14. Aug 22, 2020 at 9:13 AM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    No power until 6pm. Not sure if I should leave the freezer closed or go fill up a cooler.
  15. Aug 22, 2020 at 9:17 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Go start the generator
    04Pre_Runner[QUOTED] likes this.
  16. Aug 22, 2020 at 9:27 AM
    Abeyancer
    Jimmie
    PNW
    Pack ice into the freezer.. theyre usually better insulated compared to coolers
  17. Aug 22, 2020 at 9:31 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    No, you need the ecu and engine harness
    xtremewlr[QUOTED] likes this.
  18. Aug 22, 2020 at 9:44 AM
    04Pre_Runner
    Andrew
    Wouldn’t that be nice.
    JKO1998[QUOTED] likes this.
  19. Aug 22, 2020 at 9:45 AM
    CS_AR
    Abeyancer and Kwikvette[QUOTED] like this.
  20. Aug 22, 2020 at 9:58 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    OK, thanks.
