  1. Aug 24, 2020 at 12:39 AM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Sort of. The alignment cam eliminator plates give you 3 positions. Inboard, neutral, and outboard. When you go to larger tires the goal is to push the tire further forward to clear the firewall. If you look at anyone's alignment the stock cams will almost always be inboard on the front and outboard on the rear. That's how I set the plates. I also have SPC arms. They allow me to adjust caster and camber via the UCA. Here's my numbers after alignment.
    Camber L -.65
    Camber R -.72
    Castor L 2.10
    Castor R 2.27
    I have my camber set negative on purpose. I wheel a lot and my outer lugs are much more useful to me. Setting camber negative puts the wear more towards the inner side. My rig tracks perfectly straight and has no return to center issues. I used to knock my alignment out every time I wheeled. Since putting the plates on 3 months ago it hasn't moved once.
  2. Aug 24, 2020 at 12:47 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Thank you for that extremely informative response! I'm guessing a double benefit is you never have to pay for an alignment lol
    Do you trailer your rig?
  3. Aug 24, 2020 at 12:52 AM
    theesotericone
    Bishop CA
    I drive my rig to the trail and I drive it home. It's been on a flat bed once in 3 years and that was the Claw Hammer incident. I field repaired that lower link with a 16" pry bar my buddy had. Then a few ratchet straps to hold it together. Then a shit ton of gorilla tape. That allowed me to drive 15 miles back to the road. I thought about driving the 200 miles home but if that repair failed it would have been bad. I called AAA and got home via them. lol
  4. Aug 24, 2020 at 12:54 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    It's basically a grade 8 bolt with an offset drilled plate for adjustment. It's not a bad idea but does limit fine adjustment of the alignment that the tradition round cam bolts would provide.
    I think some people might do this instead of using the cam tab gussets or doing both. Definitely would help prevent bending them and losing alignment. Those square plates look to be about 1/4" thick.
    Personally, since I still daily drive my 4th gen, I'd do the cam tab gussets or what I'm actually going to do is the Marlin LCA frame brace that also integrates cam tab gussets. I've already got them, just need to install them. Waiting until I rebuild the front suspension with new bushings and everything else since you need to remove the LCAs so you don't melt the bushings when you weld the gussets in place.
    https://www.marlincrawler.com/axles/front-axle-armor/hd-lca-frame-brace-2003-2009-4runner
    Abeyancer[QUOTED] likes this.
  5. Aug 24, 2020 at 1:30 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    You're Johnny Knoxville?
  6. Aug 24, 2020 at 2:16 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Thank you John!
    Taco critter likes this.
  7. Aug 24, 2020 at 3:24 AM
    CS_AR
    :thumbsup:
  8. Aug 24, 2020 at 3:26 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Wulf, CS_AR and Taco critter like this.
  9. Aug 24, 2020 at 5:03 AM
    CS_AR
    Thank you, Dallas!
    what road[QUOTED] likes this.
  10. Aug 24, 2020 at 6:07 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Thats some hard core getter done monster trail repairs.
    Congratulations.
    CS_AR and theesotericone[QUOTED] like this.
  11. Aug 24, 2020 at 6:30 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    THC is your friend
  12. Aug 24, 2020 at 6:55 AM
    Running Board Man
    Running Board Man Well-Known Member
    2 batteries jumper cables and 7018 electrodes would have saved your ass
  13. Aug 24, 2020 at 7:00 AM
    theesotericone
    Bishop CA
    Would have. At the time I didn't have a field weld kit in the rig. I do now.
    How to fix sheared LBJ bolts the correct way.
  14. Aug 24, 2020 at 7:13 AM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    Anybody know the bolt and nut numbers that go through the front of the leaf's? Gonna try and install my elocker axle I got awhile back soon.
  15. Aug 24, 2020 at 7:40 AM
    Running Board Man
    Oh dear lord
  16. Aug 24, 2020 at 7:58 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  17. Aug 24, 2020 at 7:58 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Naturally, I had to tell Ana first :rofl:
    Gonna need a cardboard box for later per @xtremewlr suggestion :anonymous:
    xtremewlr, CS_AR and Abeyancer like this.
  18. Aug 24, 2020 at 8:29 AM
    paetersen
    paetersen Well-Known Member
    poor diet.
    CS_AR likes this.
  19. Aug 24, 2020 at 8:30 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Happy birthday!!! Make the best of it, have fun! @CS_AR
    CS_AR likes this.
  20. Aug 24, 2020 at 8:31 AM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    CS_AR likes this.
