  1. Sep 17, 2020 at 7:02 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Got it. Right on - do a decent amount of those 4th gen guys do that swap? Any able to pull off a whole manual swap? I’d be interested to see if / what interchange there is on 4runners / FJ’s
  2. Sep 17, 2020 at 7:03 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    eon_blue and xtremewlr like this.
  3. Sep 17, 2020 at 7:06 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    I've only seen a handful that have done the swap. Seems like a majority of the 4th gen guys are like 3rd gen Taco owners and pay to have shit fixed. Or an even smaller number go with SAS. The FJ manual transfer case is AWD/full-time 4WD but can't be swapped as it's completely different spline count and the input shaft can't be changed. As for swapping out from auto trans to manual, I hear there are ways to do that (@Empty_Lord knows) but I'm not at that point yet with the 4Runner. I just want 4wd working again so I can actually wheel it properly.
  4. Sep 17, 2020 at 7:14 PM
    Running Board Man
    Running Board Man Well-Known Member
    There's a guy with an fj that goes to our beach meets that has a j shift case and can assure you it's part time 4wd
  5. Sep 17, 2020 at 7:15 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Again, typo. The 6 speed manual FJs are full-time 4wd/AWD only. Only the automatic FJs had the manually shifted t-case with the J shift pattern.
  6. Sep 17, 2020 at 7:16 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    What was Toyota thinking
    Running Board Man likes this.
  7. Sep 17, 2020 at 7:18 PM
    eon_blue
    Azusa, CA
  8. Sep 17, 2020 at 7:20 PM
    Running Board Man
    Doesn't make sense to me either
  9. Sep 17, 2020 at 7:22 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  10. Sep 17, 2020 at 7:23 PM
    Running Board Man
    Something I know is for some reason the tapers on the upper ball joint/spindle is different on tacomas, 4 runners, and fjs
  11. Sep 17, 2020 at 7:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I feel like some here relate to that....
    eon_blue[QUOTED] likes this.
  12. Sep 17, 2020 at 7:26 PM
    eon_blue
    Azusa, CA
    As the tiger maybe
    Kwikvette[QUOTED] likes this.
  13. Sep 17, 2020 at 7:28 PM
    JKO1998
    Utah
    Joe got to you
  14. Sep 17, 2020 at 7:29 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You think pretty highly of yourself :luvya:
  15. Sep 17, 2020 at 7:29 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
  16. Sep 17, 2020 at 7:30 PM
    eon_blue
    Azusa, CA
  17. Sep 17, 2020 at 7:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So you're a Liger
  18. Sep 17, 2020 at 7:32 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You know that won't fry anything right? Totally fine to have the full time diff up there, less parts to fail actually. It's actually preferred
  19. Sep 17, 2020 at 7:32 PM
    eon_blue
    Azusa, CA
    what road and Kwikvette[QUOTED] like this.
  20. Sep 17, 2020 at 7:35 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yeah, I've had opinions go both ways with that. Some say that because the manual FJ tcase was only designed to work in part time 4wd, that running it with the full-time 4wd front axle spinning the chain in there will eventually fry the tcase. Others are of your opinion.
    In the interest of simplicity and time, I'm not going to swap the front diff for the ADD one. I might even skip the twin stick conversion if I can make the J-shift pattern clear the console.
