  1. Sep 21, 2020 at 7:48 PM
    Running Board Man
    Running Board Man Well-Known Member
    Yeah, I really fucked that one up
    cruiserguy[QUOTED] likes this.
  2. Sep 21, 2020 at 7:48 PM
    Running Board Man
    Yeah fuck that noise
  3. Sep 21, 2020 at 7:49 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Why not just get a selectable locker?
  4. Sep 21, 2020 at 7:49 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They're worth more in the box... we've attributed their shortness to some of the harshness that cracks coil buckets. No matter what your front setup ends up being you need limit straps to avoid ruined buckets and lower shock bolt tab tearing. And you should consider beefing the bucket too
    Running Board Man likes this.
  5. Sep 21, 2020 at 7:50 PM
    Running Board Man
    I don't want to need to switch between traction and turning
    In the 01 4 runner needing to stop press the button go back and forth a couple times did it enguaged did it enguaged am I in awd or 4x4 alright the light stopped flashing cool
    I just want something that when I stomp on the gas sends power to both wheels
  6. Sep 21, 2020 at 7:51 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    You weren't the first and aren't the last either. But yeah it still blows
  7. Sep 21, 2020 at 7:52 PM
    Speedytech7
    Rather just be forced not to turn huh? wheelers rarely need a front anyway, not sure why on a stock ass 4runner this mod is so high up on your list. Get some sliders and sort your suspension out first (instead of some hacked together garbage from another model). If you don't lift a tire you don't need a locker
    Kwikvette likes this.
  8. Sep 21, 2020 at 7:55 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  9. Sep 21, 2020 at 7:56 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Somebody making soup?
    Speedytech7[OP] likes this.
  10. Sep 21, 2020 at 7:56 PM
    Speedytech7
    He'd still be dead, it was a TJ, zero wheel travel cause baby leafs and tiny AT tires hah
  11. Sep 21, 2020 at 7:58 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    YJ actually. TJ had round headlights.
  12. Sep 21, 2020 at 7:59 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Didn’t realize it was for the front
  13. Sep 21, 2020 at 8:00 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    4R has a rear locker already
    Sperrunner[QUOTED] likes this.
  14. Sep 21, 2020 at 8:01 PM
    Running Board Man
    Um, well I do on occasion I've done the gas and brake thing at the same time to get out of stuff 2x
    Well I can't get any more travel out of the front end as the strut maxes out centimeters before the cv starts to bind... No mater what suspention shock/spring combo I have that is the ultimate limitation and I'm kissing it at full droop
    I have sliders, I have uppers and lowers in the front the rear is flexy enough and I'm not high enough to need links so why bother... perhaps just correct the panhard bar than just get a locker eventually
  15. Sep 21, 2020 at 8:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You've got a rear locker?
    If I had none, I'd get one in the rear before I fucked with the front.
  16. Sep 21, 2020 at 8:03 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Nice. Gunna buy chromeoly shafts for the front? Like that other lifted runner dude kn here has
  17. Sep 21, 2020 at 8:04 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Just weld everything
  18. Sep 21, 2020 at 8:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I saw those....$2k.
    I can but I don't see a need to as I don't wheel anywhere as hard like a lot of others do here.
    I'm being realistic with my needs.
  19. Sep 21, 2020 at 8:04 PM
    Running Board Man
    Yeah well the diffs out and appart right now, figured I'd fuck with it now while it's convenient
  20. Sep 21, 2020 at 8:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :welder:
