  1. Sep 24, 2020 at 2:44 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
  2. Sep 24, 2020 at 2:46 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Apparently my iPhone things recirculate means testicular
    eon_blue likes this.
  3. Sep 24, 2020 at 3:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :laughing:
    What a knee slapper!
    what road likes this.
  4. Sep 24, 2020 at 3:07 PM
    esxcli
    esxcli Keyboard Warrior
    Sean
    Reno NV
  5. Sep 24, 2020 at 3:18 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I dig it, I'm not into them but have heard some of their more popular tracks on my station. I will have to check out more of their stuff.
  6. Sep 24, 2020 at 3:19 PM
    Wulf
    rock raisin
    I don't like Avatar at all but this track came on when I was in the garage and it's been stuck in my head
  7. Sep 24, 2020 at 3:29 PM
    Wulf
    rock raisin
    esxcli likes this.
  8. Sep 24, 2020 at 3:29 PM
    Wulf
    rock raisin
    esxcli likes this.
  9. Sep 24, 2020 at 3:37 PM
    Wulf
    rock raisin
    esxcli likes this.
  10. Sep 24, 2020 at 3:38 PM
    Wulf
    rock raisin
    that's nuts
  11. Sep 24, 2020 at 3:47 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Starting to get somewhere.
    Before
    As of today
  12. Sep 24, 2020 at 3:47 PM
    Wulf
    rock raisin
    Tyler is gonna coooom when he sees this
  13. Sep 24, 2020 at 3:49 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    what road, BartMaster1234 and Blue92 like this.
  14. Sep 24, 2020 at 3:53 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  15. Sep 24, 2020 at 3:53 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I wouldn't try to weld on top of it. Do the welding first, then grind and clean it up for painting.
    One of the first ones I cured was on the car. Instead of using an oven, I used 20-minute run cycles to heat up the exhausts.
    Directions for Oven Curing
    1. Paint must be completely dry before curing.
    2. Heat to 250°F (121°C) for 30 minutes.
    3. Cool for 30 minutes.
    4. Heat to 400°F (204°C) for 30 minutes.
    5. Cool for 30 minutes.
    6. Heat to 650°F (343°C ) for 30 minutes.
    I have also used a torch to cure these Y-pipes before installation.
    It was a Y-Pipe cat delete kit that I put on the car. You want to use gloves when installing the painted part to keep from getting grease on the new part.
    When the part is being cured, any grease or contaminate will burn into the paint.
    Before being primed and painted. Be sure to get the part squeaky clean with starting fluid before priming.
    Here's a video about using a torch to cure VHT paint. This works as well. I have used it on the same Y-pipe.
    I've had good success with torching for curing.
    The VHT part of the video starts at 1:00 minute.
    https://youtu.be/h7oBCJjokmM
    Sebz13[QUOTED] likes this.
  16. Sep 24, 2020 at 4:31 PM
    Sebz13
    Shane
    Maui Hawaii
    @CS_AR thank you again. When parts start arriving I’ll show everyone what I’m up too
    Taco critter likes this.
  17. Sep 24, 2020 at 4:31 PM
    Sebz13
    Shane
    Maui Hawaii
    What’s the best price I’m gonna get on o2 sensors I need both
  18. Sep 24, 2020 at 4:32 PM
    eon_blue
    Azusa, CA
    I paid around $100 for a rear o2 sensor (Denso). Probably around the same for a front one I imagine
    I wouldn't go aftermarket
    CS_AR likes this.
  19. Sep 24, 2020 at 4:45 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Words of wisdom
  20. Sep 24, 2020 at 4:52 PM
    eon_blue
    Azusa, CA
    There's more where that came from
    Install your LT
    Sperrunner and Speedytech7[OP] like this.
