  1. Sep 25, 2020 at 12:10 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Fuel injector cleaner
  2. Sep 25, 2020 at 12:11 PM
    eon_blue
    Azusa, CA
    You still on the stock size/weight tires?
    I mean ~1mpg less than advertised on a 22 year old vehicle ain't bad, those numbers have always been exaggerated to a degree anyway. With variables like driving style, weight, gas quality, elevation/location, etc being only 1mpg off is pretty good imo
    Abeyancer[QUOTED] likes this.
  3. Sep 25, 2020 at 12:11 PM
    Wulf
    rock raisin
    are your ujoints in good shape? CVs? tire pressure good? unless you're certain it's an engine issue I'd be looking at wear/drag items
  4. Sep 25, 2020 at 12:11 PM
    Running Board Man
    Running Board Man Well-Known Member
    I'm down
  5. Sep 25, 2020 at 12:12 PM
    Wulf
    rock raisin
    life is full of ups ands downs
  6. Sep 25, 2020 at 12:12 PM
    eon_blue
    Azusa, CA
    It says Fuel Injector Cleaner but it's probably moonshine
  7. Sep 25, 2020 at 12:12 PM
    Wulf
    rock raisin
    if you really want to work that cat use a quart of ATF
  8. Sep 25, 2020 at 12:14 PM
    eon_blue
    Azusa, CA
    I mean they make this stuff called Cat-a-Clean that you dump in the fuel tank, supposedly works from what I hear. At least as a Hail Mary if you need to pass smog, sometimes
    Abeyancer and Running Board Man like this.
  9. Sep 25, 2020 at 12:14 PM
    Wulf
    rock raisin
    the power to weight ratio will affect things too.
  10. Sep 25, 2020 at 12:19 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Cut a hole in the 4runner.
    Working on figuring out the shifter placement now.
    eon_blue likes this.
  11. Sep 25, 2020 at 12:29 PM
    Abeyancer
    Jimmie
    PNW
    That's fair. I'm just over thinking it then, my tires are 31s and the door card says 225/75 and those are what 28" tires? I need to remember my bed topper is probably 200lbs by itself... and if you had mpg issues with a poor alignment I've got way worse drag than I'm figuring because all my ushings are shot lol it wanders like crazy
    I check tire pressure every other day and run em at 32psi. U joints only have about 5k miles on them cause I rebuilt both driveshafts after the engine rebuild. CVs are stock but they don't click and the boots aren't torn.. planned on rebuild them when I swap gears in the front diff but maybe bow I should do them sooner just because.
    I think youre right, it's a weight thing + my brain issues lol that carbureted 302 in my ol 68 econobox got me all fucked up
    eon_blue[QUOTED] likes this.
  12. Sep 25, 2020 at 12:29 PM
    Abeyancer
    Jimmie
    PNW
    ...... soooooo.. fuel injector cleaner?
  13. Sep 25, 2020 at 12:30 PM
    Abeyancer
    Jimmie
    PNW
    Would having to run the clutch out have any difference?
    These 31s and 3.56 gears don't get along t
    With trying to get going from a dead stop
    Das it mang likes this.
  14. Sep 25, 2020 at 12:32 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Gearing might help, probs not riding the clutch but more so needing to ride gears longer at higher rpms for fair gear shifts
  15. Sep 25, 2020 at 12:34 PM
    Wulf
    rock raisin
    are you correcting for tire size when you calculate MPG? your truck came stock with 235s? 225s?
  16. Sep 25, 2020 at 12:40 PM
    Abeyancer
    Jimmie
    PNW
    Yes I am. It came with the 225s and my speedo is 20% off with the 31s ... i came up with that value by reseting the trip odo and driving exactly 1 mile using interstate markers. Trip odo would read .8 miles
    Then using phone GPS to tell speed and compare to what my dash says corresponds with that 20% discrepancy
  17. Sep 25, 2020 at 12:42 PM
    Wulf
    rock raisin
    Gotcha.
    Having larger tires with those tall gears will kill MPG quickly. You're working the engine harder to accelerate and more likely to be lugging it in gear
  18. Sep 25, 2020 at 12:43 PM
    Wulf
    rock raisin
    FWIW I did get 18MPG once with 3.91s and 35s.... I drove several hundred miles at 55-60 in 3rd gear :rofl:
  19. Sep 25, 2020 at 12:43 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Any idea what gears you have?
  20. Sep 25, 2020 at 12:44 PM
    Wulf
    rock raisin
    read back noob :luvya:
