  1. Oct 14, 2020 at 10:43 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Read it again
    Kwikvette likes this.
  2. Oct 14, 2020 at 10:44 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Not talking about sway bars as I easily pulled that off like the Tacoma.
    The running boards use a 13mm socket all around; attached via nut and bolt on each end.
    The fronts have a welded nut in which you remove a bolt. Only way to get to it is with a deep socket which I have but not in 13mm.
  3. Oct 14, 2020 at 10:44 AM
    Running Board Man
    Running Board Man Well-Known Member
    Than just tell me
  4. Oct 14, 2020 at 10:44 AM
    Wulf
    rock raisin
  5. Oct 14, 2020 at 10:44 AM
    Running Board Man
    I have a 4 runner whose running boards I removed
    I used a regular harbor freight 1/2 drive 13mm socket and ratchet, worked fine
    It was also the only time i removed a bolt from that truck that was a 13mm
    Ps why would you take the board off the bracket... than the bracket off the truck
    Just take the bracket off the truck with the board in one sweep....
  6. Oct 14, 2020 at 10:44 AM
    Speedytech7
    Those are some thick splines on that 14bolt
    Wulf[QUOTED] and Kwikvette like this.
  7. Oct 14, 2020 at 11:01 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :facepalm:
    The only way you can remove the board is by removing all 6 13 mm bolts on each side which we have already acknowledged.
    However I cannot remove one of those bolts on each side due to the lack of a deep socket.
    Rather than having running boards hanging by a single bolt on each end, I removed the 2 12 mm bolts from the bracket to the running board and completely removed the running board.
    This way the only thing left connected to the truck are two small brackets held by a single 13 mm bolt which I can remove once I get a deep socket.
    Damn I just felt my IQ drop as soon as I explained all of that
  8. Oct 14, 2020 at 11:06 AM
    Running Board Man
    I was able to remove them in a parking lot the first time i drove with 285/70/17s thinking thats what was rubbing with nothing but a 13mm 1/2 socket and 1/2 drive ratchet...
    perhaps your iq is too low to figure out how to do that
  9. Oct 14, 2020 at 11:12 AM
    Running Board Man
    20201014_132021.jpg20201014_132149.jpg found the sockets my brother lost for me
    Now that menace is in arizona i might be able to keep a set of tools
  10. Oct 14, 2020 at 11:13 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  11. Oct 14, 2020 at 11:16 AM
    Running Board Man
    Holy shit the screwdriver i bought for too much money to adjust my 4 runners headlights has reappeared
  12. Oct 14, 2020 at 11:17 AM
    eon_blue
    Azusa, CA
  13. Oct 14, 2020 at 11:20 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  14. Oct 14, 2020 at 11:28 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Ah yes another 1st version 1st gen vs 2nd version 1st gen problem:rofl:
    Up until 2000 they used the 2 piece rear slider and then switched to the one you have in 01
    I just assumed they'd be the same amount of area but yours definitely looks smaller, which is weird to me
    Running Board Man likes this.
  15. Oct 14, 2020 at 11:29 AM
    eon_blue
    Azusa, CA
    yeah when it's opened up it's only about a 1ft x 1ft square, no way an adult is getting through that lol
  16. Oct 14, 2020 at 11:30 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    When I first saw it, I thought it was an offroading computer game. LOL
  17. Oct 14, 2020 at 11:36 AM
    Speedytech7
    I'd have figured you animals at VatoZone just five finger discounted anything you wanted
  18. Oct 14, 2020 at 11:40 AM
    Running Board Man
    I didnt steal from the front but the tools that people brought in for warentee were good 80% of the time just a loose bolt so i pocketed those
    I have like 5 duralast ratchets and a flex head one that i got for free that were just going to be thrown away, after tightening a screw were perfect tools
  19. Oct 14, 2020 at 11:51 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Oh my welds look awful
    These sliders better not fall off
  20. Oct 14, 2020 at 12:00 PM
    Running Board Man
    More weld than necessary type ugly... should be fine
    If it looks like a cat that ate fabrics shit... not fine
