  1. Oct 15, 2020 at 11:54 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    I do have a non stock intake tube, paired to a stock airbox.
    This job might be above my pay grade, and I don't want to mindlessly through parts at it. He said he would check function of the front A/F and check vacuum leaks. Can MAF be checked for functionality? He has the crazy snap on reader so I assume he can see everything.
  2. Oct 16, 2020 at 12:02 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    It can be graphed. Same for the sensor.
    ignore the rear sensor after the cat, that does nothing except say that your cats working.
    a graph will also show if there’s an exhaust leak before the front sensor. The graph will look rough, a properly working a/f sensor will look like a sine wave
  3. Oct 16, 2020 at 12:29 AM
    Sebz13
    Shane
    Maui Hawaii
    will report back when I meet up with him. I didn't get a chance to visually see if there is a vacuum hose disconnected somewhere so ill check it out.
  4. Oct 16, 2020 at 5:29 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Exactly!
    A whole other world of advertising then
    CS_AR[QUOTED] likes this.
  5. Oct 16, 2020 at 5:37 AM
    My Name is Rahl
    So...with the 5VZ-FE motor...why are there coil-on-plugs on the left side, but only wires to the plugs on the right? o_O
  6. Oct 16, 2020 at 5:42 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    It's Friday and I'm working OT all day. Nothing better
  7. Oct 16, 2020 at 5:43 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Wasted spark ignition. It can use three coils and fire them twice as often, it fire both plugs connected to it at the same time. One on the normal compression (firing) stroke and the other on it's sister cylinder's exhaust stroke.
  8. Oct 16, 2020 at 6:02 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Modern disc brakes in 1963. That was two years before Corvette or Thunderbird.
    Abeyancer likes this.
  9. Oct 16, 2020 at 6:05 AM
    CS_AR
    0xDEADBEEF[QUOTED] and Abeyancer like this.
  10. Oct 16, 2020 at 6:07 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Its Friday and I actually took a day off from work
  11. Oct 16, 2020 at 6:17 AM
    Wulf
    rock raisin
  12. Oct 16, 2020 at 6:24 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Hahaha blast from the past! I used to watch Mr Ed with my mom back in the day on her first "color" television. The greyscale was replaced with a greenscale
    Like how fancy computer monitors used to be able to change the color scale of MS DOS between orange and green letters :rofl:
  13. Oct 16, 2020 at 6:26 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  14. Oct 16, 2020 at 6:26 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    morir rápido
    Wulf[QUOTED] likes this.
  15. Oct 16, 2020 at 6:28 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Mercedes has a crossover with portal axels.
  16. Oct 16, 2020 at 6:30 AM
    Wulf
    rock raisin
    I don't hate it :confused:
  17. Oct 16, 2020 at 6:35 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Its a sketchy feeling
  18. Oct 16, 2020 at 6:36 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Snowflake :rolleyes:
  19. Oct 16, 2020 at 6:45 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Have you pre ordered yours?
  20. Oct 16, 2020 at 6:50 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Who am I? Tyler? I don't pre-order.
    Running Board Man likes this.
