  1. Oct 21, 2020 at 1:15 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    We use a really old ticketing program that's based in html (asp) and javascript at my work. Surprisingly no one but me seems to know web development things. So I'm modifying it to suck less, it's open source but long since been deprecated. Only reason I'm not starting fresh is because it has active directory integration and I don't think I could recreate that backend myself.
    CS_AR likes this.
  2. Oct 21, 2020 at 1:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @xtremewlr
    @Empty_Lord
    @Speedytech7
    So my truck got done getting washed, but now my truck won't turn on.
    It cranks but no start.
    It was as if no fuel was getting in but I have half a tank.
    Pulled codes and I have a P0116 Engine Coolant Temp Sensor 1
  3. Oct 21, 2020 at 1:23 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    The only natural enemy of the elusive @esxcli is the rock stack, pictured is the alpha attacking the predator - eliminating the risk of danger.
    Das it mang likes this.
  4. Oct 21, 2020 at 1:24 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Check the big 40/50A fuses in the engine bay box. I've had that exact thing happen to my 5-Lug. Also the EFI fuse.
  5. Oct 21, 2020 at 1:24 PM
    Speedytech7
    Just like your LT
  6. Oct 21, 2020 at 1:25 PM
    Speedytech7
    Did they wash your engine bay? Cause I'd say its time to dry some connectors. You can unplug the coolant temp sensor, it might be shorted indicating the need for full rich.
    xtremewlr likes this.
  7. Oct 21, 2020 at 1:26 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    He doesn’t have time for dreams
  8. Oct 21, 2020 at 1:30 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No, engine bay was not touched at all.
    I swapped the heater relay and efi relay and even though it took a bit to start, it fired up.
    Idling at 750rpm with AC on.
    Going to drive it for a bit since I tried starting it 3-4 times to keep the battery up and then go home and try your suggestion.
  9. Oct 21, 2020 at 1:31 PM
    Speedytech7
    Hmm odd, if it isn't water related then it's a pretty wild guess for much without some diagnostics.
  10. Oct 21, 2020 at 1:32 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I reversed jumped the 5-Lug and it blew the main 40A fuse, and the EFI fuse. It had the same symptoms as you and new fuses fixed it. Get a test light and start checking things.
  11. Oct 21, 2020 at 1:33 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah it's very unlikely that swapping the relays had anything to do with it and more like the five minutes of downtime was enough for it to start again
  12. Oct 21, 2020 at 1:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well reverse jumping it would lead me to believe that a fusible link and other things would go out.
    That was not the case for me.
    My no-start sounded like it was getting no gas
  13. Oct 21, 2020 at 1:41 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Did you hose down the engine as well?
  14. Oct 21, 2020 at 1:42 PM
    Speedytech7
    MY LC did this once, but I had just gone to town on the engine with a pressure washer and gotten water where it shouldn't have been thanks to some missing spark plug boots
  15. Oct 21, 2020 at 1:43 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    This was the direction I was heading, so never mind sine it was already covered.
  16. Oct 21, 2020 at 1:45 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Read above, engine bay was completely untouched and is dry.
  17. Oct 21, 2020 at 1:46 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I washed my 4Runner yesterday after work and hosed down the engine as well. Didn't use any cleaner/degreaser, just low water pressure. I have a hose attachment thing that has a "shower" setting and I used that. Except for all the dust, the motor is actually pretty clean since I did the timing belt and valve covers not too long ago.
  18. Oct 21, 2020 at 1:47 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    :luvya:
    Kwikvette[QUOTED] likes this.
  19. Oct 21, 2020 at 1:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just driving it around and I'm noticing that my RPM is staying at 900
  20. Oct 21, 2020 at 1:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So drove around quite a bit.
    AC both on or off my RPMs are consistently 950.
    In park it jumps up to 1480 and stays there, I don't hear any leaks as I poked my head through the engine bay.
    Coolant levels are good as well, no smoking at all
