  1. Oct 31, 2020 at 9:26 PM
    eon_blue
    Azusa, CA
  2. Oct 31, 2020 at 9:29 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    eon_blue[QUOTED] likes this.
  3. Oct 31, 2020 at 9:39 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    No. But I have old Florida inspection tag
  4. Oct 31, 2020 at 9:40 PM
    Empty_Lord
    Dan
    For now yes. Ideally replace the belt. Do check for pulley play. This can cause belt skip too
    04Pre_Runner[QUOTED] likes this.
  5. Oct 31, 2020 at 9:44 PM
    eon_blue
    Azusa, CA
    Chances are you might not even need to do the seals, but really you don't find out if you should have until after the axle is reinstalled and it leaks or not. Unless the seal is visibly bad when you pull the axle. With it's mileage though it's probably best just to do them while you're in there
    Some people use a seal driver tool to get them in, I tried but didn't have the room to drive the damn thing in hard enough. Ended up just getting the seal in there partially and drove it in the rest of the way with the axle itself
    CS_AR likes this.
  6. Oct 31, 2020 at 9:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Hmm..
    Ordered the other seal already.
    Even though this vehicle was often maintained (especially due to the kind of guy the PO was), I doubt it needs them but they're cheap enough to have on hand if needed.
    I thought people just lightly and 'evenly' tapped them in place...carefully.
    My only concern would be having to buy a 34mm, 35mm, and 36mm as it seems not every one has the same size nut at the end of their axle. Then have those extra 2 sockets I'll never use again like several of my other tools.
  7. Oct 31, 2020 at 9:55 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    I have the air cabin man ebay aisin kit so I'm doing everything but the fan pulley bracket. I just noticed the number 2 idler pulley is bad and has significant play. Camshaft pulleys seem to be fine with just a tiny play back and forth and no side play.
    My roommates throw massive halloween parties every year so thankfully I found a strong enough guy inside to help me hold the pulleys in place while I took their bolts off. No way could I have done that alone without getting really creative. Dude did a great job for being drunk.
    CS_AR likes this.
  8. Oct 31, 2020 at 9:58 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I want that for my fleet!
    04Pre_Runner likes this.
  9. Oct 31, 2020 at 10:00 PM
    eon_blue
    Azusa, CA
    The axle nut should be 35mm, with all the axles I've replaced across different brands (some come with a new axle nut) they're always 35mm.
    As for the seal, it took a lot more than just tapping to even get it partially in lol. That sucker is made to fit in there tight. Helps to put some gear oil around the edges.
    My fear was that the seal is a little fragile feeling and hammering it too hard might damage it. It's just hard rubber really
    The axle seats up against it perfectly center so it just felt better to let the axle drive it in the rest of the way
    Kwikvette[QUOTED] likes this.
  10. Oct 31, 2020 at 10:35 PM
    04Pre_Runner
    Andrew
    The entire disassembly has required cleaning up what's left behind from this trucks mud/water submersion. Really slows things down. A new motor would've been the best choice but something about running this one to death just appeals to me.
  11. Oct 31, 2020 at 10:54 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I scared them away with my boat
  12. Oct 31, 2020 at 10:55 PM
    Running Board Man
    Running Board Man Well-Known Member
    Mine wasn't even near that bad
  13. Oct 31, 2020 at 10:56 PM
    Running Board Man
    I deliver pizza, people certainly were out but nowhere near the amounts as normal
  14. Oct 31, 2020 at 10:59 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Yours was submerged in shit not mud
  15. Oct 31, 2020 at 11:19 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I used my air impact to get pulley bolts off.
    I made the mistake of trying to remove the bolt for the Nissan passenger cam without the timing belt. I spun it with the impact and probably hit the pistons with the valve haha
  16. Oct 31, 2020 at 11:37 PM
    Running Board Man
    I want an agua fresca but it's 1:40 AM
  17. Oct 31, 2020 at 11:52 PM
    04Pre_Runner
    Andrew
    I'm waiting on the right deal on a Milwaukee 1/2 impact. I'd go air tools again (compressor guy at my house never got over what he was mad about) but the right compressor won't be cheap. Sand blasting really pushes you into the commercial grade stuff. That's a big yikes on the Nissan. What's the status on it right now?
  18. Oct 31, 2020 at 11:53 PM
    04Pre_Runner
    Andrew
    Last year it was misting and around 37 degrees. Still more people out last year lol.
  19. Oct 31, 2020 at 11:55 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Status: Boat Anchor
    Haven’t had much time to work on it truth be told. Made a complete stop on it when I got the Boat. Tomorrow is the last time I’ll take it out before the season is over then I can focus on it.
    Unless you’re constantly sandblasting a 60 gallon compressor will do just fine. Tractor Supply had a good deal on a 25 CFM dual stage single phase 80 gallon compressor. That competes with the commercial grade stuff. I think it was $2,500.
    CS_AR and 04Pre_Runner[QUOTED] like this.
  20. Nov 1, 2020 at 12:38 AM
    04Pre_Runner
    Andrew
    Yeah that's understandable. And in Cali you won't be battling the elements working on the Nissan over the winter.
    My ideal compressor is something like that. Another factor is graduation this month. I'm going to hold off on anymore large purchases for now.
