  1. Jan 5, 2021 at 3:21 PM
    eon_blue
    Azusa, CA
    The worst part about freelancing for me was every year come tax time. In order to not get completely raped, you have to keep meticulous records of every.single.little.thing that might remotely be a write off, it's exhausting. And it's better to do your taxes quarterly rather than annually as a freelancer which makes it even more of a pain. I hated that part of it so much lol. And to have an accountant do the work for you is $$$ too.
    I always seemed to know people in the industry that somehow claimed to never owe a thing on their freelance income because of their write offs, which to this day makes absolutely zero sense to me. No way you can completely write off so much that you keep all your income from the year. Methinks these people are flying under the IRS' radar which is risky business.
    0xDEADBEEF[QUOTED] likes this.
  2. Jan 5, 2021 at 3:21 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  3. Jan 5, 2021 at 3:23 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Absolutely. There are services like Freshbooks that take out some of the pain of the billing, but taxes hurt no matter what. There's the enjoyable work part of the business, the reason why you got into it in the first place - and then it all gets crushed by the reality of running it.
    I'd do it again, but I need more of a plan first, particularly for marketing.
    eon_blue[QUOTED] likes this.
  4. Jan 5, 2021 at 3:26 PM
    eon_blue
    Azusa, CA
    Living in CA of course makes it worse too, CA hates small businesses/freelancers. Talk about getting taxed to death, but that's another topic for another day (and probably a different place lol)
  5. Jan 5, 2021 at 3:33 PM
    0xDEADBEEF
    Yeah state taxes on top of it ... blech. I was in Texas at the time, so that made life easy .
  6. Jan 5, 2021 at 3:36 PM
    1997tacomav6
    Denver
    Yeah, if you don’t fuse it correctly anyhing can cause a fire or cheap parts will do that too
    Running Board Man likes this.
  7. Jan 5, 2021 at 3:38 PM
    Running Board Man
    Running Board Man Well-Known Member
    ... The only people hiring where the ship ports are on LinkedIn is spacex... I'm not quite a rocket welder
  8. Jan 5, 2021 at 3:45 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  9. Jan 5, 2021 at 3:53 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Sleek looking and strong.
    Kwikvette[QUOTED] likes this.
  10. Jan 5, 2021 at 3:55 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Gained like one or two @Empty_Lord worth of ground clearance in the rear
  11. Jan 5, 2021 at 3:56 PM
    0xDEADBEEF
    Not very much then?
  12. Jan 5, 2021 at 3:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I had half a Dan worth of clearance with the stock bumper and tow hitch so yeah I probably gained 5-6 Dans -
    https://youtu.be/xqD9Th8bKsc
    That loud clanking was my tow hitch :anonymous:
  13. Jan 5, 2021 at 4:01 PM
    0xDEADBEEF
    Yeah those hitches getcha. does the new bumper have a receiver that can be added?
  14. Jan 5, 2021 at 4:05 PM
    CS_AR
    You're going to burn in hell for running a lifted suspension according to this Facebook expert's bullshit post below. :rofl::rofl::rofl:
    Suspension lifts are mostly useless on IFS vehicles. They have many more cons and the pros are questionable.
    Cons:
    - No added tire clearance (biggest misconception)
    - Reduced droop travel
    - High CV angle
    - Increased component wear
    - Diff drop reduces ground clearance
    - Lifts use higher rate springs and bars (harsher ride, less articulation)
    - Lots of extra parts needed besides lift (diff drop, tubular UCAS, extended sway links, adjustable rear UCA/LCA/PHB)
    - Lower MPG
    - Higher COG
    Pros:
    - More load carrying capacity? (assuming higher rate springs and net zero lift once loaded)
    - Looks cool when parked?
    - Slight improvement to angles (approach/break over/departure)
  15. Jan 5, 2021 at 4:10 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I'll probably have it done sooner. Just dragging ass getting through this project because as usual I overestimated the rate I'd be able to work on stuff and how much time I would dedicate to working on stuff.
    It shouldn't be too bad. The thing I'm dreading most is putting conduit through the attic and pulling the wire. Got some 0 gauge drop cable which should be G2G
  16. Jan 5, 2021 at 4:11 PM
    Wulf
    rock raisin
    who posted that, Scotty kilmer?
    CS_AR[QUOTED] and Black DOG Lila like this.
  17. Jan 5, 2021 at 4:12 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I assume this is what I was missing.
    Shit bro...
    Wulf likes this.
  18. Jan 5, 2021 at 4:13 PM
    Wulf
    rock raisin
    Silver02Taco and 0xDEADBEEF like this.
  19. Jan 5, 2021 at 4:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Let's be real, that's the only reason why I bought Kings all around :burp:
    CS_AR[QUOTED] likes this.
  20. Jan 5, 2021 at 4:16 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh no worries you're good, appreciate it.
    Meant my recent posts, getting something installed.
    CS_AR likes this.
