  1. Feb 12, 2021 at 8:15 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Even my old 87 300zx had a low coolant sensor, it's not an uncommon feature for cars. BMW has had them standard since the 70s. But I think something about a plastic reed switch so close to 220* coolant is a bad idea. 220* is normal running temp for modern bimmers and I think a float switch would probably survive better in that.
    xtremewlr[QUOTED] likes this.
  2. Feb 12, 2021 at 8:15 AM
    Speedytech7
    Not gonna touch this, contemplate it elsewhere.
    Running Board Man likes this.
  3. Feb 12, 2021 at 8:15 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    A few hours? You lucky sumbish.. whenever I've had a stye develop it has taken a minimum of 3 days to go away on its own
  4. Feb 12, 2021 at 8:20 AM
    Speedytech7
    It always seems to be triggered by allergens, it's annoying temporarily but they do go away.
  5. Feb 12, 2021 at 8:26 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    The swelling already gone down quite a bit, musta just Not drained very good during the night.
  6. Feb 12, 2021 at 8:31 AM
    Abeyancer
    Jimmie
    PNW
    Squeeze it to get the rest of the juices out
    I'm sure you'll be fine
  7. Feb 12, 2021 at 8:34 AM
    JKO1998
    Utah
    Tender as hell, just pop it like a zip it guess.
    right into my eye
  8. Feb 12, 2021 at 8:40 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Naw it ain't one of those "you should or shouldn't" things; don't need to bring that to the LT.
    Just thinking out loud I guess if there's any benefit to it. I got COVID and it felt like a normal day with the only symptoms being loss of taste (an hour or two) and smell (a week and a half).
    Flu? You could be near me with the flu and it still wouldn't hit me.
    SouthernYoder likes this.
  9. Feb 12, 2021 at 8:42 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    On another note; hard finding a welder that isn't more than an hour drive from me around here :annoyed:
    Das it mang likes this.
  10. Feb 12, 2021 at 8:59 AM
    Speedytech7
    You get roughly 90 days worth of immunity from a confirmed case in their estimation, that's what the CDC is going on at least. Might be beneficial if you have any plans to travel cause it sounds like they'll be moving to checking the vaccination record for flight clearance soon.
    Kwikvette[QUOTED] likes this.
  11. Feb 12, 2021 at 9:00 AM
    Speedytech7
    Buy one?
    Abeyancer likes this.
  12. Feb 12, 2021 at 9:02 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I can, and have considered it but it'll just sit in it's respective box.
    Maybe I can just ask for a recommendation on a quality welder to do nothing thicker than say a bumper/sliders which is what 3/16" to 1/4" steel?
    I won't be able to use it until we get the new house; old house doesn't have wiring up the snuff (which is why I never bought one) and apartment welding is a no go.
  13. Feb 12, 2021 at 9:03 AM
    Speedytech7
    Well my day got a lot more boring. Was supposed to rotohammer a 3/4" hole through a brick wall on a genie lift about 18' in the air. But one of our wiring contractors busted the lift... so guess I'm not doing that
  14. Feb 12, 2021 at 9:04 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Good point on the flight clearance part, if that really becomes a thing.
    Apparently having had COVID lends the body to become temporarily immune as well, similar to the shots you guys are taking.
  15. Feb 12, 2021 at 9:04 AM
    Speedytech7
    No 20amp 110v outlets? For that heat range you can easily use a 110v welder. That's what I primarily use in my own garage. It works great, I can easily fire a 1/4 joint still
    0xDEADBEEF likes this.
  16. Feb 12, 2021 at 9:08 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The power is "dirty" as I had to use two nice Furman line conditioners just for the surround sound and tvs in the house. Without anything on, voltage would drop down to "brown out" levels. Using the microwave on the same circuit as something else wouldn't cause fluctuation oddly enough but still, it left me not wanting to really use something as power hungry as a welder.
  17. Feb 12, 2021 at 9:10 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Hell, using the SVS subwoofers were power hungry enough seeing as how they're 14-16hz beasts.
    I haven't fired them up in almost a year and a half now. One is still new (not broken in) and I should sell it already.
  18. Feb 12, 2021 at 9:11 AM
    Speedytech7
    Yeah, that's pretty shitty. I typically use a 20a circuit that comes off my panel by about 1' and we have super solid power here, no voltage dips. I've gotten away with welding on a 15a circuit before, but you know how power works I'm sure, if the voltage drops the amperage pull increases so that would be bad if you're dipping below 100v. Transformer welders make dirty power anyway, but they don't like low voltage.
  19. Feb 12, 2021 at 9:12 AM
    JKO1998
    Utah
    Kwikvette likes this.
  20. Feb 12, 2021 at 9:14 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yep; having done custom audio/video installs and having been an audiophile for many years really makes you look at someone's setup and wonder "what the fuck are you doing" o_O
    It's especially funny in car audio, and the guy running high-current amps with small gauge power cable and a ground a lot longer than 12" suddenly causes his cables to melt and cause a fire in his trunk...I've only seen that once in my life fortunately.
