  1. Mar 9, 2021 at 3:26 PM
    Wulf
    rock raisin
    no no 3SGE BEAMS 190hp 4 cyl
    bolts up to toyota W58
  2. Mar 9, 2021 at 3:35 PM
    eon_blue
    Azusa, CA
    Damn, our cats bite me just to say hi
  3. Mar 9, 2021 at 3:37 PM
    Wulf
    rock raisin
    [​IMG][​IMG]
    shitboxes are my MO
  4. Mar 9, 2021 at 4:30 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    It’s fun to play with I guess
    I dunno what to put on it though :rofl:
    Wondering about putting it right above the center vents
    xtremewlr likes this.
  5. Mar 9, 2021 at 4:31 PM
    eon_blue
    Azusa, CA
    Engine temp, slushbox temp (think you need a special code to access it), fuel trims and timing or intake air temp.
    IAT is kind of useless except it gives you an idea of what the outside temp is, poor mans outside temp reading
  6. Mar 9, 2021 at 4:39 PM
    eon_blue
    Azusa, CA
    Fuel trims are good to monitor because if they go whacky out of normal range you'll know you have an issue at hand, rich or lean condition, vacuum leak or bad sensor etc.
  7. Mar 9, 2021 at 4:49 PM
    JKO1998
    Utah
    The right column means almost nothing to me
    CS_AR likes this.
  8. Mar 9, 2021 at 4:54 PM
    BradleyS
    BradleyS Well-Known Member
    Bradley
    03 Toyota Tacoma TRD
    None, yet.
    I think I need some 'Scepter' cans. Can't decide between 2 fuel ones or 1 fuel and 1 water.
  9. Mar 9, 2021 at 4:57 PM
    BradleyS
    Bradley
    None, yet.
    Me too, lol. What did you go with? I want 2 'Scepters' and trying to decide between 2 fuel cans or 1 fuel and 1 water.
    CS_AR[QUOTED] likes this.
  10. Mar 9, 2021 at 5:05 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Bought 2 red gas cans at Tractor Supply. I regret it now. I wish I had bought one water. I may get a 40-gallon fuel tank. Then I won't need a gas can at all.
  11. Mar 9, 2021 at 5:12 PM
    BradleyS
    Bradley
    None, yet.
    That large capacity tank could be the way to go. I hear you about 1 water and 1 gas. I think I'm gonna go for the 2 fuel can mounts, and then modify one slightly as to make slightly frekin' smaller to fit 1 water can in it, so have 1 each.
  12. Mar 9, 2021 at 5:12 PM
    eon_blue
    Azusa, CA
    Your trims look decent at least in that shot, so that's good
  13. Mar 9, 2021 at 5:12 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    It's just really fluffy, that's all
  14. Mar 9, 2021 at 5:13 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Get the oh shit handle mount for it. Also what version UG is it? Some don’t support ATF temp readings.
  15. Mar 9, 2021 at 5:14 PM
    JKO1998
    Utah
    Shorts basically staying at 0 now.
    what should they be?
    I know when I push my brake pedal (known vacuum leak) short jumps to 12
  16. Mar 9, 2021 at 5:14 PM
    JKO1998
    Utah
    EM Plus V1.4c
  17. Mar 9, 2021 at 5:14 PM
    Wulf
    rock raisin
    Spiker Engineering makes a pillar mount. I'd like one because my UG lives in the passenger seat but I don't need it bad enough to justify the $45 after shipping and taxes
    04Pre_Runner likes this.
  18. Mar 9, 2021 at 5:16 PM
    eon_blue
    Azusa, CA
    Want your trims as close to zero as possible. Or at least within -10 to 10. Too high means too lean, too low is too rich
    Wulf likes this.
  19. Mar 9, 2021 at 5:21 PM
    JKO1998
    Utah
    Ah, well long stays at 7. Whatever it was.
    I don’t really wanna spend that on a mount either. I needa try and run that giant ass plug throw the dash somewhere and Velcro the mount somewhere I think.
  20. Mar 9, 2021 at 5:29 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I’ve had nonstop cars coming in the last two weeks, you fix one car and now everyone wants you to fix their car.
    Had a Mazda come in today with a decent coolant leak, the upper union was leaking.
    At least I got the 300zx calipers rebuilt.
    Abeyancer, 04Pre_Runner and xtremewlr like this.
