  1. Mar 22, 2021 at 8:33 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    tell me that a decade ago
  2. Mar 22, 2021 at 8:34 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Haven’t ever seen that enforced
  3. Mar 22, 2021 at 8:34 AM
    Wulf
    rock raisin
  4. Mar 22, 2021 at 8:43 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Any of yall know how warm a differential should be running? The one in my taco was 109 when I got back yesterday, and it was only 65 outside. I suspect i may have a failing bearing.
  5. Mar 22, 2021 at 8:47 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Seems fine to me, that's not a big temp delta for something thats a high pressure application.
    0xDEADBEEF[QUOTED] and Wulf like this.
  6. Mar 22, 2021 at 8:47 AM
    Wulf
    rock raisin
    I think that's on the low end, I think 150-175 under normal load is acceptable and up to 200 for heavy load is acceptable
    0xDEADBEEF[QUOTED] likes this.
  7. Mar 22, 2021 at 8:50 AM
    0xDEADBEEF
    Ok, thanks! Good to know. 50 degrees over ambient seemed like a lot for the driving I was doing, but I didn't have any real idea what it should be.
    There's been a noise under there that its had since I got the truck and haven't been able to place (might even be the tires). I had the toolbox out yesterday and nothing on the back wall of the cab so any noise coming from under the bed was very noticeable and I began to get suspicious.
  8. Mar 22, 2021 at 8:51 AM
    Wulf
    rock raisin
    is your spare tire all the way up? drum brakes adjusted? carrier bearing tight? u joints tight?
  9. Mar 22, 2021 at 8:51 AM
    Wulf
    rock raisin
    I think temp wise you have nothing to worry about. Here's another data point for you
  10. Mar 22, 2021 at 8:52 AM
    0xDEADBEEF
    Yep, high as it goes.
  11. Mar 22, 2021 at 8:53 AM
    0xDEADBEEF
    Dang. Definitely within range then. We'll see what it does once the weather gets hot.
  12. Mar 22, 2021 at 8:53 AM
    Speedytech7
    It could be bearings, they do get noisy over time, could be gears too, they make a good bit of noise as everything wears in over time and the lash loosens. I wouldn't expect either of those to manifest as a huge temp increase though
  13. Mar 22, 2021 at 8:54 AM
    0xDEADBEEF
    At least until they fail completely, at which point I'd notice for other reasons :laughing:
    Wulf likes this.
  14. Mar 22, 2021 at 8:55 AM
    0xDEADBEEF
    That said, trailer bearings and railcar axle bearings do get hot when they fail.
    Wulf likes this.
  15. Mar 22, 2021 at 8:56 AM
    Wulf
    rock raisin
    have you tried running a heavier weight diff oil? 75W140
  16. Mar 22, 2021 at 8:56 AM
    Speedytech7
    It's a band-aid if it cures the noise, but throw some 80-140 in next time you change the soup in there.
  17. Mar 22, 2021 at 8:56 AM
    Speedytech7
    We on the same wavelength this morning
    0xDEADBEEF likes this.
  18. Mar 22, 2021 at 8:57 AM
    0xDEADBEEF
    Ok, will do. Its what came in the truck, so its about due anyway.
  19. Mar 22, 2021 at 9:02 AM
    0xDEADBEEF
    - yep
    - Mostly, just readjusted them a few weeks ago when i put the axle back together.
    - reg cabs are too cool to have carrier bearings
    - ujoints are tight and greased
    It might be the tires. I've only driven it with these tires on it, and its not any of the usual bad noises I'm familiar with.
  20. Mar 22, 2021 at 9:14 AM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    I don't all my trucks were manual.
    Abeyancer[QUOTED] likes this.
