  1. Apr 7, 2021 at 7:32 AM
    Wulf
    rock raisin
    I didn't pay extra, I got the axle dressed with a spare RCV minus third member for a suspiciously reasonable price.
    That should have been the first clue that I was on track to sink a lot of money
    slander[QUOTED] and Abeyancer like this.
  2. Apr 7, 2021 at 7:33 AM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Does anyone have a link to a good ‘how to’ delete ABS?
  3. Apr 7, 2021 at 7:36 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Kinda depends on your idea of what a delete is. Like removing the fuse stops it from working. Removing all the components and replacing with regular brake lines works too, then you have to yank the dash bulb. You'll never get the light to turn off otherwise.
    Ace115[QUOTED] and Wulf like this.
  4. Apr 7, 2021 at 7:43 AM
    JTFisherman
    JTFisherman Well-Known Member
    Jake
    Texas / Missouri
    4Runner
    Proceeds to check oil with the rear tires 3’ off the ground
    Area51Runner[QUOTED] likes this.
  5. Apr 7, 2021 at 7:45 AM
    Wulf
    rock raisin
    what? there's a pin to keep it from dropping unexpectedly. What more safety do you need?
    :luvya:
  6. Apr 7, 2021 at 7:48 AM
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    I’ve already pulled the dash bulb. I want the space under the hood for other ideas so I’m looking for info on the full delete
  7. Apr 7, 2021 at 7:52 AM
    Speedytech7
    @Blackdawg might know the part numbers for the lines you'll need if you yank out the abs unit
    Ace115[QUOTED] likes this.
  8. Apr 7, 2021 at 7:55 AM
    Wulf
    rock raisin
    Ace115 likes this.
  9. Apr 7, 2021 at 7:58 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's a lot of chocolate
    Das it mang and BartMaster1234 like this.
  10. Apr 7, 2021 at 8:03 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    what road, Kwikvette[QUOTED] and Wulf like this.
  11. Apr 7, 2021 at 8:05 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Damn I missed out on the convo, but yeah either a 6 lug or 8.8 rear is my plan. I don't mind running an extra spare for 6 lug, will just tap my bed on the other side. Main priority is to get 4:10 or 4:30's, and keep it cheep, ill get a spool either way prior to install.
    tires im tossed up between km3s in 33x10.50, or go for 235/85 or 32x11.50 with new rims. Tires will likely be first, unless i get a nice raise in a couple months. Want to do shock relocation anyways and run a 10 or 12 in behind there
    JTFisherman[QUOTED] likes this.
  12. Apr 7, 2021 at 8:13 AM
    Speedytech7
    Can't pull that much travel with 5lug stock setup anyway, so save your pennies until you can do the leafs too.
    Das it mang[QUOTED] and Wulf like this.
  13. Apr 7, 2021 at 8:16 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    why im dragging ass on it and wanna run a welded diff for the time being. If im gonna do it, i wanna do one and done. (the right way) Like my HG and cylinder head
  14. Apr 7, 2021 at 8:16 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    some good ol j59s should do the trick at that time
  15. Apr 7, 2021 at 8:22 AM
    Speedytech7
    I'm pretty sure j59s are for spring over
  16. Apr 7, 2021 at 8:22 AM
    Wulf
    rock raisin
    are you over thinking this? :D those sizes are all pretty close and I think you'd be happy with any of them
    Das it mang[QUOTED] likes this.
  17. Apr 7, 2021 at 8:26 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    *f67's. my 6 lug imposter syndrome kicked in
  18. Apr 7, 2021 at 8:29 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    Im just torn bc the km3s are 230 a piece, the other two sizes I can get around 200 or less a piece, but will have to buy new rims unless i wing the 32x11.50's on the 15x6's. Balling on a budget has me weighing options, but im glad u guys continue to give me more information to help!
    Kwikvette likes this.
  19. Apr 7, 2021 at 8:39 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ending the night with some drinking, definitely sucked waking up early :anonymous:
    Das it mang likes this.
  20. Apr 7, 2021 at 8:40 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    gatorade before bed does wonders, now u gotta do the ol ibuprofen and catch up game with hydration today haha
    Wulf likes this.
