  1. Apr 25, 2021 at 9:24 AM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    My mother’s 2020 4Runner limited is dead. Dealer did an oil change Friday (first oil change) and didn’t tighten the drain plug or oil filter. Oil evacuated the engine while she was going 75 on the highway. The dealer had a tow truck out there within minutes of the call. General manager and service manager showed up with a loaner vehicle not long after that.
  2. Apr 25, 2021 at 9:26 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Well that’s a big ol fuck up. Make sure you pressure them into a NEW engine. Not a used engine. Unless said used engine is equivalent or less miles than the old. You can also typically get a longer power train warranty out of this mess
  3. Apr 25, 2021 at 9:29 AM
    Empty_Lord
    Dan
    In all the years at the dealer I’ve only ever seen one 4runner engine die. And it was at 87k miles with its original oil....
  4. Apr 25, 2021 at 9:31 AM
    04Pre_Runner
    Andrew
    Yeah the hard part will be pressuring my parents to pressure the dealer. You can tell the dealer is scared with how quickly they dealt with that.
  5. Apr 25, 2021 at 9:33 AM
    Empty_Lord
    Dan
    Well if they don’t make it right there’s a huge issue of dealer image and of course lawsuits. I’d just make sure they fix it right. It’s a new car. You don’t want to deal with this on a new car and potential headaches from them replacing the motor. A warranty and a new or less than current mileage motor would be the thing that makes it right. We had to eat a motor on a car a couple years back thanks to a lube tech. Guys 10k mile car ended up with a 100k power train warranty and the engine was assembled by yours truely. New head, new short block... new engine basically
    Tour991 and 04Pre_Runner[QUOTED] like this.
  6. Apr 25, 2021 at 9:35 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Todd: "The horns on the 4R aren't that bad"
    The horns:
    https://youtu.be/dyZ0JAVj8s0?t=4
  7. Apr 25, 2021 at 9:45 AM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    Toyota gave me different oil filter, gave me yzzd3 I’ve always gotten yzzg2... after doing some research I find I took an L... oils been drained :facepalm:
    Running Board Man likes this.
  8. Apr 25, 2021 at 9:48 AM
    Empty_Lord
    Dan
    The D3 fits it’s just taller.
    G2 has been phased out in my region and is now the D1
    04Pre_Runner and tymeson[QUOTED] like this.
  9. Apr 25, 2021 at 9:49 AM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    I came across multiple post saying it was for the V8s, maybe I just didn’t go far enough :tinfoilhat:
  10. Apr 25, 2021 at 9:50 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Fits the 4 banger fine
    Abeyancer and tymeson[QUOTED] like this.
  11. Apr 25, 2021 at 9:51 AM
    Empty_Lord
    Dan
    Fits the 3.4 too. It’s what I ran
    Seagull233 and 04Pre_Runner like this.
  12. Apr 25, 2021 at 9:52 AM
    Speedytech7
    Nothing truly fits the 3.4, the oil filter is in the dumbest place and orientation possible.
  13. Apr 25, 2021 at 9:53 AM
    Empty_Lord
    Dan
    Meh. Never bothered me too much. I use use a filter claw under the alt. The part that sucks is the mess it makes
    tymeson likes this.
  14. Apr 25, 2021 at 9:54 AM
    Speedytech7
    It's not terrible on a completely stock truck I guess. Still should be relocated. Changing the BMW oil is easier and that should never be the case lol
  15. Apr 25, 2021 at 9:55 AM
    Empty_Lord
    Dan
    I’ll be figuring out a relocation when I get to that point on the taco. Probably put it in the same location the tundra has it
  16. Apr 25, 2021 at 9:55 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    This...is just fucking sad :rofl:
    *cries in a puddle of used 3.4 oil on the floor*
    tymeson and Empty_Lord like this.
  17. Apr 25, 2021 at 9:56 AM
    Empty_Lord
    Dan
    Poking a hole in the top of the filter then letting the pan drain with the oil cap still on helps mitigate that.
    God forbid you forget to replace the filter after though
    Kwikvette[QUOTED] likes this.
  18. Apr 25, 2021 at 9:57 AM
    04Pre_Runner
    Andrew
    Yup that's me. Replacing the filter after draining the pan. Wasting about 64 shop towels in the process.
    Kwikvette likes this.
  19. Apr 25, 2021 at 10:01 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah, filter always comes last.
    I'll stab a hole through it next time.
  20. Apr 25, 2021 at 10:02 AM
    Speedytech7
    I hate that, it just dumps out right onto everything, no way to really catch it. The cruiser hangs off the side of the block perfectly perpendicular to the engine and it only leaks an easily catchable drop. You can do the BMW filter and oil without spilling anything anywhere.
