  1. Apr 25, 2021 at 10:56 PM
    Running Board Man
    Running Board Man Well-Known Member
    If the tie rod mounting is a fraction of a millimeter off where from the old one is in relation to the joint the toes gonna be fucked
    I bought a set of Ac-Delco lbjs for an 02 Tacoma one was made in Italy or Switzerland and one was made in china
    Go back a few months on this thread you'll see where I mentioned not to get Ac-Delco from rock auto because 555 in the picture wasn't what came in the box
    The truck had return to center issues, it would track straight when the wheel was centered because it was aligned, but would hop and chirp the tires at full lock, one side was turning at a greater angle than the other
    The fix till was to put 2 new autozone ball joints from ctr... Got it aligned and it was perfect
    Which I'm glad I did for free because he's given me several side jobs
    Please just try to critically think
    Yeah they're supposed to mirror originals but the aftermarket isn't necessarily known for precision or accuracy
  2. Apr 25, 2021 at 10:57 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    I probably will since I might end up changing the settings on my SPCs which is another question if anyone has experience with... What’s the best position to set SPCs at for better caster. I’ve heard + and - both increase caster from different people lol.
  3. Apr 25, 2021 at 10:58 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    :confused::confused::confused:
    Stop shopping at the fucking junkyard.
    Dude, you are literally talking out of your ass. Give it the fuck up. You sound like a total moron right now. You are nit picking at bullshit THAT MAKES NO DIFFERENCE. 1 out of thousands MIGHT have the issue you are trying to describe here.
    Kwikvette likes this.
  4. Apr 25, 2021 at 10:58 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    that all depends on your lift.
  5. Apr 25, 2021 at 10:59 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I run SPC on my 4Runner. It all depends on the tire size you are running and if you are trying to eliminate a rubbing problem or not.
  6. Apr 25, 2021 at 10:59 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    My SPC ball joints are ruined so I'm about to be figuring that out as well.
    Running Board Man likes this.
  7. Apr 25, 2021 at 11:00 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    How so? I have the full OME kit 882 coils
  8. Apr 25, 2021 at 11:00 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Do you have a rubbing issue at full stuff?
  9. Apr 25, 2021 at 11:01 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Running 285/70/17 and it rubs the driver side cab when reversing
  10. Apr 25, 2021 at 11:01 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    When reversing yes. Already beaten the absolute shit out of the pinch weld
  11. Apr 25, 2021 at 11:02 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Can I fit 33s with no lift and not rub?
    Running Board Man and Logans2001 like this.
  12. Apr 25, 2021 at 11:02 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    I previously had my SPCs set at normal setting and changed it 1 setting and I do t think it made a difference
  13. Apr 25, 2021 at 11:02 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Then you want to add caster in to move the tire forward. That will also affect camber settings and you have to start playing with the LCA settings to correct that.
  14. Apr 25, 2021 at 11:04 PM
    Empty_Lord
    Dan
    typically the stock setting on the SPC arms should get you to a point where further fine tuning on the lowers will get rid of the rub.
  15. Apr 25, 2021 at 11:04 PM
    Empty_Lord
    Dan
    do you own a sawzall?
  16. Apr 25, 2021 at 11:05 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    That’s probably what I’ll do.
  17. Apr 25, 2021 at 11:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No but I've got a pair of those plastic scissors they give you in kindergarten
  18. Apr 25, 2021 at 11:05 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
  19. Apr 25, 2021 at 11:05 PM
    Empty_Lord
    Dan
    ok. now go cut your fingers off so you cant drive anymore and shut it.
  20. Apr 25, 2021 at 11:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Man, you're really short today :rofl:
    Empty_Lord[QUOTED] likes this.
