  1. Apr 30, 2021 at 10:16 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Not unless you're using the small air cut-off tool
    Das it mang likes this.
  2. Apr 30, 2021 at 10:22 AM
    eon_blue
    Azusa, CA
    Speaking of which
  3. Apr 30, 2021 at 10:23 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    To each their own, I found the sawzall wanting to pull and harder to control. If it bit too hard it would push/pull the sheet metal and warp it. Could have been the blades I was using or operator error though :)
    0xDEADBEEF, Das it mang and alee891 like this.
  4. Apr 30, 2021 at 10:30 AM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    I too used just an angle grinder w/ cut offs for both the Tacoma and Tundra. Did enough damage to clear just fine :notsure:
  5. Apr 30, 2021 at 10:30 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    To be fair,
    I'm working to fit 31s on a stock 5 lug. So I'm committed to the dumbassery involved from the get go. If I had access to a sawzall I'd be willing to try it
  6. Apr 30, 2021 at 10:31 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    What about a jig saw?
    Seems like those small teeth would be easy to work with
  7. Apr 30, 2021 at 10:31 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    Like bath water.
  8. Apr 30, 2021 at 10:40 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You just won't get the depth at certain points in the cut. You need to tape off more too cause the base will ride on the fender and can scratch more than most want.
  9. Apr 30, 2021 at 10:41 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Sounds like a bunch of pluses to me:burp:
  10. Apr 30, 2021 at 10:41 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The thing with the sawzall is to make absolutely sure that the material you're cutting stays stationary, and the guard of the sawzall is right up against it. I've had it grab and wiggle sheet metal a lot if I don't hold those rules.
    Jigsaw would work too, same rules.
    The ideal thing to cut this would be a nibbler, but a grindee with a narrow cutoff wheel would be my second choice.
    Wulf likes this.
  11. Apr 30, 2021 at 10:45 AM
    Wulf
    rock raisin
    To be faaaaIiirrrr
  12. Apr 30, 2021 at 10:46 AM
    0xDEADBEEF
    TO BE FAAAAIR
  13. Apr 30, 2021 at 10:49 AM
    JKO1998
    Utah
    Ima just run 33’s and not worry about
  14. Apr 30, 2021 at 10:51 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    They will rub what they need gone. Just get swampers
    Das it mang, Abeyancer and Wulf like this.
  15. Apr 30, 2021 at 10:52 AM
    JKO1998
    Utah
    If I still had two trucks, I would haha
    swampers would fck up some snow
  16. Apr 30, 2021 at 10:53 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    paddles
    se7enine likes this.
  17. Apr 30, 2021 at 10:54 AM
    Wulf
    rock raisin
  18. Apr 30, 2021 at 10:58 AM
    JKO1998
    Utah
    Why do we even did tires?
    rotors and drums
  19. Apr 30, 2021 at 10:59 AM
    Speedytech7
    weld paddles to steelies, thatll fuck up some snow
  20. Apr 30, 2021 at 10:59 AM
    0xDEADBEEF
    I want someone to bolt up some train wheels.
