  1. May 2, 2021 at 9:57 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    And it wouldn't be because they suddenly make your vehicle a gross polluter; Toyota, decided to say fuck paying the extra certification to cover 2003 models (and whatever other models are affected).
    It's the same for handguns in CA and manufacturers not paying their fees to stay on the roster.
  2. May 2, 2021 at 10:20 AM
    eon_blue
    Azusa, CA
    @Kwikvette
    Sesame Street is teaching kids how to make pineapple pizza
    :mad:
    JTFisherman, Kwikvette and FLBAdrian like this.
  3. May 2, 2021 at 10:21 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Gross
    eon_blue[QUOTED] and Kwikvette like this.
  4. May 2, 2021 at 10:23 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  5. May 2, 2021 at 10:23 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Burn it with fire
    eon_blue[QUOTED] likes this.
  6. May 2, 2021 at 10:25 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  7. May 2, 2021 at 10:26 AM
    eon_blue
    Azusa, CA
    As is his MO, cookie monster ate the pineapple too soon and tried putting apples and pinecones on the pizza instead lmao
    Running Board Man likes this.
  8. May 2, 2021 at 10:27 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You shut that Sesame Street off!
    Sofia will not grow up following the ideology of those monsters; pineapple on pizza....disgusting.
    Sperrunner and Running Board Man like this.
  9. May 2, 2021 at 10:28 AM
    Running Board Man
    Running Board Man Well-Known Member
    I found on an mr2 fourm you can put the upper and lower intake manifold off a 3vze onto a 5vzfe
    At that point the only thing would be a dead giveaway is batch fire coil vs distributor
  10. May 2, 2021 at 10:34 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    California has a very detailed process for checking that your engine is the correct engine. They have a fun little handbook with details on every engine for things you should look for to identify it. They would absolutely notice that your ignition type has changed, because part of their process is checking your ignition timing. Not to mention they know what the various gas outputs should be from these engines. If you played mix and match exhaust parts from the older 3.0 to the 3.4 the NoX output and cO would be off by a telling amount
    CS_AR and Kwikvette like this.
  11. May 2, 2021 at 10:43 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Running Board Man he's not even in CA and even he gets it :rofl:
  12. May 2, 2021 at 10:44 AM
    eon_blue
    Azusa, CA
    Fortunately for 2000 and newer they don't require the tailpipe/dyno emissions testing in CA anymore. Just visual and OBDII check
  13. May 2, 2021 at 10:46 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    God forbid you have a car that gets flagged like my Miata way back when for being a 'gross polluter'
    Have to go into a STAR station after that, where they absolutely pick your car apart and find any and every reason to not pass it.
    It was a completely gutted Miata NA with Jackson Racing supercharger; base model so manual everything. Fun as fuck car but I kept it smog legal as long as possible to drive it straight to Laguna Seca versus trailering it.
  14. May 2, 2021 at 10:47 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Laughs in no smog county*
  15. May 2, 2021 at 10:48 AM
    eon_blue
    Azusa, CA
    We have no smog counties but that pretty much means you live meth head county
  16. May 2, 2021 at 10:49 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    *stares at Grass Valley on the map*
  17. May 2, 2021 at 10:50 AM
    eon_blue
    Azusa, CA
    I'm pretty sure Nevada County does smog... Probably not as strict though
  18. May 2, 2021 at 10:52 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I can't see you modifying a minivan enough to make it fail smog :burp:
  19. May 2, 2021 at 10:52 AM
    eon_blue
    Azusa, CA
    Bet
    Kwikvette[QUOTED] likes this.
  20. May 2, 2021 at 10:53 AM
    eon_blue
    Azusa, CA
    Wait...shit
    Kwikvette likes this.
