  1. May 17, 2021 at 7:37 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Buy a 3rd gen
  2. May 17, 2021 at 7:38 PM
    JTFisherman
    JTFisherman Well-Known Member
    Jake
    Texas / Missouri
    4Runner
    4 runner maybe...
    Kwikvette and Abeyancer like this.
  3. May 17, 2021 at 7:43 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Check the ebrake cable where it attaches to the brake drum. If you have any movement you may need new shoes. I had 275,000 on my 5lug axle and never changed the shoes.
    JTFisherman[QUOTED] likes this.
  4. May 17, 2021 at 7:46 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Cool that conversion gives what I want (I think) where RPM x displacement / 231 =GPM
    So having my gear pump with a fixed displacement of .56 in^3 at 1700rpm would yield 4.12GPM. Which coincides with my test stand flow meter reading 4GPM. Therefore with science I can prove my boss bought the wrong pump and it's not something in my plumbing or valve body causing it to underperform
    He wants 12GPM:laughing:
  5. May 17, 2021 at 7:54 PM
    JTFisherman
    Jake
    Texas / Missouri
    4Runner
    Sounds right to me. That seems like wayyy too small a pump to make use of the power of the motor though and that is where my knowledge ends
    Abeyancer[QUOTED] likes this.
  6. May 17, 2021 at 7:56 PM
    Abeyancer
    Jimmie
    PNW
    Doing the opposite math shows that I need a displacement of 1.63 in^3 to achieve 12GPM at 1700rpm. Going through Casappa data sheets they make that exact pump so now I can offer bossman a solution on how we can fix the output without having to run through a shitload of unnecessary tests just because "he needs to see it with his own eyes"
    0xDEADBEEF, CS_AR and JTFisherman like this.
  7. May 17, 2021 at 7:56 PM
    crackedmirror
    crackedmirror Well-Known Member
    Want to buy a 1/2" impact socket set. Shallow, regular, or deep for doing work on the Tacoma?
  8. May 17, 2021 at 7:58 PM
    Abeyancer
    Jimmie
    PNW
    You kinda need a mix of all three, depends entirely on what part you're working on. In my experience buy a complete deep set and then buy regular or shallow independently, depending on when you run into needing em
  9. May 17, 2021 at 8:00 PM
    Abeyancer
    Jimmie
    PNW
    Regretfully we have a customer that was chomping at the bit for a dual circuit pump that could run off either an aux tank or the one apart of the powerpak. He told casappa to just send us what they had in stock because their build time leads were way too long. Not the first time he's shotgun blasted a solution but normally we can pull something out of our assets to make what he buys work.
    This is not one of those times lol
    Thank you for your help with the maths, it's greatly appreciated
    CS_AR and 0xDEADBEEF like this.
  10. May 17, 2021 at 8:05 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I've gotten a ton of use out of my harbor freight, regular depth ones. The deep ones are nice too, but I'd get the regular ones first.
    Abeyancer likes this.
  11. May 17, 2021 at 8:06 PM
    0xDEADBEEF
    3 pumps, 1 belt! :laughing:
  12. May 17, 2021 at 8:14 PM
    Tour991
    James
    South Reno/Tahoe
    Get the regular set 1st and then deep when you can.
  13. May 17, 2021 at 8:17 PM
    Abeyancer
    Jimmie
    PNW
    The boss was in the airforce during Vietnam with the job of sneaking behind enemy lines blowing up our planes and helicopters to make sure tech didn't fall in the wrong hands.
    We've done some "iffy" things in the past to fulfill customer requests lol
    0xDEADBEEF[QUOTED] likes this.
  14. May 17, 2021 at 8:19 PM
    0xDEADBEEF
    The amount of hacked together stuff that is in service all over the world is truly terrifying. And thats just the mechanical stuff, it gets nightmarish once you dive into software.
    CS_AR and Abeyancer[QUOTED] like this.
  15. May 17, 2021 at 8:22 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    @turbodb put together a list of tools. Use that to see what sockets you're likely to need for the work you expect to do: https://www.tacomaworld.com/threads...ckets-and-wrenches-for-1st-gen-tacoma.481748/
    Personally, I started with a vintage Craftsman 1/2" ratchet set (non-impact sockets) and breaker bar I got for a nice price off Craigslist and then added a deep impact socket set.
    I don't have an impact driver right now, but my thinking is that if something's too tight to fit a deep socket, the impact probably wouldn't fit anyway. There are exceptions of course, but that's what individual sockets are for :)
    turbodb, 0xDEADBEEF and Abeyancer like this.
  16. May 17, 2021 at 8:22 PM
    Abeyancer
    Jimmie
    PNW
    I can only imagine :laughing:
    Ignorance truly is bliss
  17. May 17, 2021 at 8:24 PM
    0xDEADBEEF
    Oooh, and in some places, wiring. Oh god the wiring. :laughing:
  18. May 17, 2021 at 8:26 PM
    6P4
    Colorado Springs
  19. May 17, 2021 at 8:28 PM
    Abeyancer
    Jimmie
    PNW
    Having seen what I have seen in construction/mechanical/electrical lines of work it scares me what you programmers could do
    I see wiring as the "explainittomelikeim5" version of stringing code together. And the neglect I've seen in the panel shop from licensed union electricians has me :lalala:
    Makes me want my house I build to be as tech free as it possibly can be lol
  20. May 17, 2021 at 8:30 PM
    Abeyancer
    Jimmie
    PNW
    That place imports the most awesomest vans from Japan.. given their condition and the amount of paperwork they go through to make em US legal "kinda" justifies the price
    That Fire truck is on another level tho
