  1. May 28, 2021 at 6:28 PM
    Wulf
    rock raisin
  2. May 28, 2021 at 6:33 PM
    Wulf
    rock raisin
  3. May 28, 2021 at 6:34 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Well I dun did it.
    I bought a 2002 double cab effectively
    frame toast. 5 hour drive to get it...
    Jase and High Noon like this.
  4. May 28, 2021 at 6:36 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Not really; not like it'll go anywhere :burp:
    High Noon likes this.
  5. May 28, 2021 at 6:36 PM
    Empty_Lord
    Dan
    Probably. It’s the vessel for my old frame.
  6. May 28, 2021 at 6:36 PM
    Empty_Lord
    Dan
    Fuck off.
  7. May 28, 2021 at 6:42 PM
    Empty_Lord
    Dan
    Once the body work is done on the 01 and it’s on the new chassis this 02 will be going on the 01s frame after I repair the control arm mount that’s cracked and the steering rack mount
    In the mean time I’ll try patching up this frame to allow it to move around.
  8. May 28, 2021 at 6:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @JKO1998
    Any Harbor Freight coupons you're aware of?
    Winch is back to $499 for Memorial Day weekend
  9. May 28, 2021 at 6:58 PM
    Empty_Lord
    Dan
    Goal for the body work is to have the body on the new frame by the end of the year or early next. So that 02 frame swap will take a couple days. That’s it.
    the 02 will probably be running around come March I’m guessing if all goes well body work side on the 01.
    the 02 will be getting the armor and stuff.. and some rocker repair + bedliner to hide the rot
  10. May 28, 2021 at 7:02 PM
    Wulf
    rock raisin
  11. May 28, 2021 at 7:05 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    I was gunna make a smart ass that's deep meme
    But that's actually good advice
    ireymon, 0xDEADBEEF and Wulf[QUOTED] like this.
  12. May 28, 2021 at 7:06 PM
    Wulf
    rock raisin
  13. May 28, 2021 at 7:13 PM
    Wulf
    rock raisin
    Here's a hypothetical for ya.
    Do you
    A) install junkyard engine as-is (known to be running) with old carb. Run it for a while then rebuild carb/adjust valves
    B) adjust valves and rebuild carb and hope that everything goes well then install engine. If it doesn't run well when installed have more potential issues to chase
  14. May 28, 2021 at 7:15 PM
    Empty_Lord
    Dan
    Fix the carb and adjust the valves. Trust me, you’ll be happier in the long run
  15. May 28, 2021 at 7:16 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    C) ls swap and send it :burp:
  16. May 28, 2021 at 7:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No but really, the second choice.
    Why stop at adjusting the valves and the carb when you could freshen up a few other things.
    Fuck it, pull the head, go with a slightly bigger cam, replace the chain guides, port/polish the head...go full ham :anonymous:
    Abeyancer likes this.
  17. May 28, 2021 at 7:19 PM
    Wulf
    rock raisin
    Running Board Man and what road like this.
  18. May 28, 2021 at 7:21 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    B for sure, especially if you can do the adjustment before you get it in the bike. I dunno about that bike, but some of them are hell to access with the engine in.
    If its a CVK40 carb like my KLR has, its pretty easy to clean up and once you get it right, it'll stay that way for while.
  19. May 28, 2021 at 7:21 PM
    Wulf
    rock raisin
    Thanks, I probably should bite the bullet. I'm guessing that I need to rejet it for the aftermarket pipes too.
    The idea of making a whole bunch of changes and having errors stack scares me :)
    Running Board Man likes this.
  20. May 28, 2021 at 7:23 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    20r ported head
