  1. Jun 5, 2021 at 9:55 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    What kind of roller did you use? I worked two summers rolling fiberglass glass decks at boat factories. After the hull was glassed using a fiberglass chopper and dried, then I would glass in the wooden deck using sheets of finishing glass. Then afterward we would buff down any imperfections and glass it again to be smooth before installing the upper rail.
    I worked one summer building 21 and 26 ft sailing yachts. They called them cruising yachts. Then a couple of summers later I worked building bass boats. Back then I could always find work building boats to get summer job money.
    The yacht company had their act together for their employees. They worked four ten-hour days instead of five eights. They figured they would lose two hours each day of worker productivity each day for setup, clean-up, and break time. They produced more output with the four ten-hour days. The workers had 3 day weekends.
    I used this type of roller to penetrate the glass cloth to get the air bubbles out.
    The bass boats looked like this. Kind of primitive and simple compared to the monster bass boats of today.
    This is a picture of the 26' sailing yacht. That mermaid was an absolute bitch to get shot with gel coat and then glassed in without any bubbles. A bubble would cause the gel coat to crack or break when pulling the boat from the mold.
  2. Jun 5, 2021 at 10:22 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    As it turns out, you don’t really need one.
    LCA bushings are a bit tight but I could’ve found a way.
    Leafspring bushings were like a hot dog in a hallway
  3. Jun 5, 2021 at 10:25 AM
    JKO1998
    Utah
    I think everything is ready for the truck after it gets out of the shop.
    still don’t think I’ve got to the hard part yet.
    ireymon, Taco critter and Kwikvette like this.
  4. Jun 5, 2021 at 10:44 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    If you saw how I glassed that deck in, you would be extremely offended by how awful I did haha. I could not for the life of me get the recipe for peanut butter down. I had a can of fumed silica/Cab-o-Sil but it didn’t do a good job at thickening so I just cut up the chop strand into little pieces and mixed it in.
    I was using Polyester Laminating Resin with the curing agent and the catalyst. I resin’d the bottom of the deck boards and glassed the exposed parts. I used Great Stuff to fill in the gaps.
    The are bubbles were a pain. The more I tried to roll it flat, I just deformed the chop strand and stretched it. Then again it was the cheap Amazon stuff.
    How hard is it to sand it all smooth? I was just gonna put some kind of flooring over it. I bought marine top coat to paint over the glass.
    CS_AR[QUOTED] likes this.
  5. Jun 5, 2021 at 10:55 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    It's so easy taking pics of truck parts :burp:
    Love the new bushings
    Abeyancer likes this.
  6. Jun 5, 2021 at 11:02 AM
    JKO1998
    Utah
    Mine have all been used a little :luvya:
  7. Jun 5, 2021 at 11:03 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    New engine or new oil pump? It's just a simple way to aid in priming the oil system.
  8. Jun 5, 2021 at 11:04 AM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    :anonymous:
  9. Jun 5, 2021 at 11:05 AM
    JKO1998
    Utah
    I see you too like buying a winch bumper and no winch
    Kwikvette likes this.
  10. Jun 5, 2021 at 11:12 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    My OME springs for my 4Runner are ready for pride month
    Sperrunner and Kwikvette like this.
  11. Jun 5, 2021 at 11:12 AM
    01x4
    Yeah just haven't decided, which is a poor excuse. Between the M8-S or a Zeon. Was hoping memorial day sale would pop up but nada.
    JKO1998[QUOTED] likes this.
  12. Jun 5, 2021 at 11:14 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Gold Country is the foothills of the Sierra-Nevada, sorta like the boonies of Northern California.
  13. Jun 5, 2021 at 11:21 AM
    JKO1998
    Utah
    I understand haha
    01x4[QUOTED] likes this.
  14. Jun 5, 2021 at 11:21 AM
    CS_AR
    We would use grinders (same as car buffers before orbital) with a sanding pad that was like rough sandpaper. We could float the grinder over ruff spots in the decking and smooth it out similar to how a body shop would smooth out Bondo. It created a lot of fiberglass dust and needed to wear face protection.
    Sometimes we would need to go back and repair a spot to make sure the deck and hull would be watertight so no wood would be exposed when people were spilling water in the boat.
    We used fiberglass mat for most of the deck finishing when we were glassing the rail to the deck. Some lower-cost boats would screw the rail to the deck. That looked ok, but the boat would be noisy (creeks and pops) when running through any type of rough water. We would wet the deck with resin, then lay down the mat to soak it up, and then use a paintbrush to put on the final covering.
    After we got the deck smooth and the rail mounted, we would install some type of waterproof carpet
    https://youtu.be/S1RWEGhuQqw
  15. Jun 5, 2021 at 11:23 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :drool:
    Abeyancer and 01x4[QUOTED] like this.
  16. Jun 5, 2021 at 11:23 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That LC tho :burp:
    Speedytech7[OP] likes this.
  17. Jun 5, 2021 at 11:24 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Huh, so a Dyno sets a code for poor road surface and apparently going over 160mph sets a code for plausibility of going too fast lol. I wish it had a code for danger to manifold.
  18. Jun 5, 2021 at 11:24 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    At least we all have parts that exist to take pics of :luvya:
  19. Jun 5, 2021 at 11:29 AM
    01x4
    It's like buying a generator for a house, spending a chunk of money on something you hope you don't need.
    se7enine likes this.
  20. Jun 5, 2021 at 11:30 AM
    JKO1998
    Utah
    Warn Winch 12,000 Pounds & Warn Grill Guard
    https://classifieds.ksl.com/listing/64153603
    If it wasnt steel cable
    CS_AR and 01x4[QUOTED] like this.
