  1. Jun 18, 2021 at 9:10 AM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    0xDEADBEEF and eon_blue[QUOTED] like this.
  2. Jun 18, 2021 at 9:10 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    If you go into it knowing youll have to cut em and are prepared to do so, it wont be bad. Just slice the bolt between the spring and the mount on either side and thats it.
    Kwikvette and 01x4[QUOTED] like this.
  3. Jun 18, 2021 at 9:13 AM
    01x4
    True, its better than just hoping. I'll grab some new blades, I hate having to run out to the store in the middle of something.
    Blue92[QUOTED] likes this.
  4. Jun 18, 2021 at 9:17 AM
    eon_blue
    Azusa, CA
    someone should make a parody of Rick Astley's 'Never Gonna Give You Up' called Never Gonna Air You Down in honor of @JKO1998
    High Noon and Kwikvette like this.
  5. Jun 18, 2021 at 9:18 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    What is “tire gauge”?
    Kwikvette likes this.
  6. Jun 18, 2021 at 9:22 AM
    eon_blue
    Azusa, CA
    I was gonna make it a gif but.. meh
    ireymon, se7enine, 0xDEADBEEF and 2 others like this.
  7. Jun 18, 2021 at 9:22 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Right?
    Freaking neanderthals :burp:
    01x4[QUOTED] likes this.
  8. Jun 18, 2021 at 9:23 AM
    JKO1998
    Utah
    Too much time
  9. Jun 18, 2021 at 9:29 AM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Doesn’t change the fact I have to scrub his paper white driveway lol.
  10. Jun 18, 2021 at 9:33 AM
    eon_blue
    Azusa, CA
    I had a neighbor like that in TX. His driveway was bleached white, his lawn was impeccable. Every day on weekends he would sit on the porch and just stare at all the kids in case any of us stepped foot on his lawn and messed up a perfect blade of grass. If you did, he'd threaten to go grab his shotgun lol.
    04Pre_Runner[QUOTED] likes this.
  11. Jun 18, 2021 at 9:50 AM
    04Pre_Runner
    Andrew
    Easy to get to not to replace. Part Number is 90930-03114. I couldn’t get them to budge last time so I popped the caps off and cleaned them out. Just like my mechanical speed sensor is stuck on this case. R150F+Trans combo are out of a 95 Taco that spent time up north.
    I’ll likely just put one of my clean resealed cases into this truck when I have a garage again. Then go through the case when it’s on a bench. And hopefully not crack the housing.
    Running Board Man likes this.
  12. Jun 18, 2021 at 9:58 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    It should get better once I get settled in. But that could be a minute since the window blinds people are 6-8 weeks out and I dont want to live in a fish tank lol.
    Just been knocking out the small stuff and the cost sure does add up.
  13. Jun 18, 2021 at 10:00 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Failed on being rude on the internet.
    You didn't tell 3rd Genners that buying a $300 shovel doesn't make them an Overlander
    High Noon likes this.
  14. Jun 18, 2021 at 10:15 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @eon_blue
    I'll get a mounted side by side comparison tomorrow but check this out -
    I'm sure once the tire is mounted/stretched around the wheel, it'll sit a bit shorter but still...a huge difference.
    I don't even remember such a difference (even if its 1" larger) when I put the unmounted 33" Cooper next to the 32" Falken -
    Toyo Open Country M/Ts are some fucking tall tires :rofl:
    An3 and Taco critter like this.
  15. Jun 18, 2021 at 10:18 AM
    eon_blue
    Azusa, CA
    Holy crap yeah that tire is way taller...I do remember the Toyos having a slightly larger diameter when comparing them to the STMaxx but not that much. Hopefully it does go down when put on a wheel
    04Pre_Runner likes this.
  16. Jun 18, 2021 at 10:22 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I should run them all the way around; but really the Fresno commute would kill them pretty quickly.
  17. Jun 18, 2021 at 10:29 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So, apparently they're 33.5" tires.
  18. Jun 18, 2021 at 10:31 AM
    eon_blue
    Azusa, CA
    Yeah iirc the STMaxx are listed as 32.8" or something like that. Just a hair under 33".
    But really that's not even 1 whole inch, looks more than that in the pics. But they probably will go down a bit when stretched onto a wheel. Plus one's brand new and the other has some miles on it
    Does make me wonder how safe it would be to run as a spare for more than a short while with the difference in diameter, I'd put it up front to be safe
  19. Jun 18, 2021 at 10:36 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    It's a spare I would hope not to use/need but if so, yeah I'd toss it in the front if I had to lock the rear at any point.
    Imagine changing a tire out if you ran 40s :violent:
    eon_blue[QUOTED] likes this.
  20. Jun 18, 2021 at 10:40 AM
    eon_blue
    Azusa, CA
    I've known a few guys that run 35s that don't carry a spare because it's just too much extra weight, though I dunno how anyone could do a long 4x4 trail without a spare. I don't like tempting fate lol
    Kwikvette[QUOTED] likes this.
